AirWillie6475
Can A LearJet Land And Takeoff On A 2500 Foot Runway
Wed Feb 16, 2005 1:37 pm
I heard some stories so is it possible?
2H4
RE: Can A LearJet Land And Takeoff On A 2500 Foot Runway
Wed Feb 16, 2005 1:43 pm
Well, Learjets range in gross weight from 12,500 lbs to over 23,000 lbs. Weather conditions play a large part, as well. You'll have to be a lot more specific if you want a reasonably accurate answer.
2H4
Intentionally Left Blank
2H4
Wed Feb 16, 2005 2:40 pm
Ok, I looked at some Learjet data, and it appears the short answer is probably not...particularly in a legal, safe manner. I'll let someone more qualified give you a more thorough answer, though.
2H4
AirWillie6475
Wed Feb 16, 2005 3:11 pm
I'm talking about a Learjet 31A.
2H4
Wed Feb 16, 2005 5:12 pm
Nope, the 31A can't do it. Not legally, anyway.
2H4
learpilot
Thu Feb 17, 2005 12:35 am
For a Lear 31, I do believe you can legally get one into a 2500' strip (part 91 that is - charter requires more runway), but the conditions must be right and the pucker factor would still be very high. Getting out is another story. You would have to be extremely light with only enough gas to get you to a very close airport and no passengers, it would have to be at a low elevation, and it would have to be cold. I know a guy who landed a 25 on a 2800' strip. If he can get one of those in there, you can get a 31 into 2500'. Barely.
It's been a while since I've flown a 31 so I can't remember any exact numbers off the top of my head.
I don't think I'd want to try it, though.
Heed our warnings or your future will be underpant free!
2H4
Thu Feb 17, 2005 2:10 am
Thanks for clearing that up, Learpilot. I based my previous post on performance data in AWST's purchase planning handbook, which must not have fallen under part 91.
2H4
timz
Thu Feb 17, 2005 2:42 am
In case the original poster doesn't know what the guys mean by "legally":
If you're asking, can a Lear lift its wheels off the pavement less than 2500 ft from the start of takeoff roll, in favorable conditions with both engines working, then the answer likely is yes. So the question is: are you willing to bet your life both engines will work?
longhauler
Thu Feb 17, 2005 4:17 am
I used to fly a Lear 25, and anything less than 5000' required attention, special procedures, and a sharp look at the performance tables.
learpilot
Thu Feb 17, 2005 6:53 am
Quoting 2H4:
That's what I'm here for.  Big grin
What you may be seeing in AWST probably are the part 91 numbers under typical conditions with a couple of passengers (of course I can't tell you that until I were to see it myself). It takes into account crossing the threshold at I think 25 feet (I forgot the exact number - someone help me out). But to plop one into a 2500' strip definitelly wouldn't fall under "normal conditions". If you're 25' over the threshold, you better go around and try again - lest you end up in the grass at the far end of the runway.  Wow!
Users browsing this forum: aaway and 2 guests
