lazybones
A380 Wing Bending Tests
Tue Feb 15, 2005 11:31 am
Fresh off the Airbus website are some new pictures of the A380 structural testing. Someone mentioned on a previous thread about how much wing flex they would expect to see on the A380 on take-off.
Hopefully not this much...
PapaNovember
RE: A380 Wing Bending Tests
Tue Feb 15, 2005 11:43 am
Wow! How many feet above normal rest is that? Looks like the wingtip is above the top of the fuselage! Will they stress the wing until it breaks? How many feet of "flex" is considered to be acceptable? Are there actual flight situations during which the wings would flex that much?
Wow - four questions in one paragraph! Hope they don't make me sound like too much of an idiot.
Phil...
DLKAPA
Tue Feb 15, 2005 11:46 am
There is some famous footage of the 777 wing test where I believe they brought it to about 23 degrees above normal before the wing snapped, and yes, Airbus will test it to its breaking point.
PHXFLY
Tue Feb 15, 2005 11:50 am
I remember seeing the Boeing test on the documentary about the 777 development. Wasn't that one of the largest deflections that had ever done? I remember it bent petty far before breaking. I imagine the sound when that wing gave was just extremely loud!
DLKAPA
Tue Feb 15, 2005 11:55 am
When the wing spar finally gave, the entire hangar shook very violently, you could see it on the test. Also the noise would have probably been almost deafening.
DAYflyer
Way too cool of a photo. I didn't know you could do that with a plastic wing!  Wow!
No I'm not that stupid, just kidding. I wonder how much stress this test is creating on the new composite wing root box?
For those interested, the 777 test was 23 FEET above normal, not degrees.
One Nation Under God
DLKAPA
Tue Feb 15, 2005 12:00 pm
woopsy I knew "23" and "feet" were in there somewhere, just didn't know they were together  Smile/happy/getting dizzy
lazybones
Tue Feb 15, 2005 12:03 pm
That answers that question. I have some video which features a wing bending test. But it doesn't say who, what or where. But yes the sound is loud and painful!!! I'll see if I can dig that out...
NoUFO
Tue Feb 15, 2005 12:49 pm
Here's a video - not of the 777-wing, though. DG-1000 is a glider.
http://www.dg-flugzeugbau.de/videoclips-e.html
BTW, it doesn't go like "the more the wing can flex - the better". Rather, aircraft manufacturer have to comply with the requirements plus and want a safety margin in case they increase the MTOW of the aircraft in question.
If the wing could withstand even higher forces, it would mean that the wing is heavier than necessary.
[Edited 2005-02-15 05:09:21]
I support the right to arm bears
A350
Tue Feb 15, 2005 3:44 pm
The POOOOOOOOOR plane  Crying
A350
Tue Feb 15, 2005 5:32 pm
How long does this test take.How gradual is the Wing Bent till it breaks.
regds
MEL
knoxibus
Tue Feb 15, 2005 11:34 pm
This test (2nd February) brought the wing 6.80 meters above rest position, that is 22.3 feet I believe.
The above load was what is called the "Limit Load" i.e. what the aircraft is expected to experience at worst in real flight conditions. That is scary!
On the 3rd, they put the same load on the wing for 45 minutes but with the ailerons and spoilers actually operating normally, but they were not loaded aerodynamically of course.
No matter what anybody tells you, words and ideas can change the world.
UA772IAD
Wed Feb 16, 2005 10:04 am
I'm confused. Someone mentioned plastic... is that a composite model, or is it metal? And, what do they do, just build a wing and brake it (I've heard of wing stress tests, but have never seen pics). What do they use, a jack like thing to bend it up? Or do they add weights to the end, and weigh it down? Also, what are the built in safety constrainsts? Is it designed like a car, where the pieces will fall out neatly, and not shatter/potentially destroy the fuselage?
Sorry for all the ?s  Big grin
ZRH
Wed Feb 16, 2005 10:32 am
Quoting UA772IAD (reply 12):
I don't know how much of the 380 is composite and how much metal. But I think I read about 30-40%, but I am not sure. I only know that the main frame is made out of a very new kind of aluminium-sandwich-structure, which is much lighter than the older materials. Perhaps you can find more on the Airbus page.
lightsaber
Crew
Wed Feb 16, 2005 11:05 am
Wow! I'm not sure I want to see my wing flex 6.8 meters... that probably means I'm bouncing back the same amount in the other direction!  Nuts
Did anyone see the video of the similar F-14 Tomcat wing test? When the wing broke, it launched the aircraft up to the hanger roof!
NoUFO is absolutely correct in that any extra flex beyond the requirements is extra weight that just won't benefit anyone over the life of the airframe (except OPEC). I'm posted before that an airframe is worth $500/kg less to an airline for every extra bit of mass that isn't adding value to a customer.
Good topic lazybones.
Lightsaber
Wed Feb 16, 2005 12:44 pm
The wing spars are metal, and they're all that really count here.
They build a whole plane apart from the engines and various hydraulic/electrical parts, then stress test it.
They actually use dozens of points along the wings and pull at them with jacks. At the same time, the fuse is held still with large hold-downs. The wings are flexed up and down repeatedly and finally pulled to breaking point.
If 1 is the absolute max that the plane is expected to experience in service (really bad turbulence/windshear), the structure has to hold up to 1.5 (50% stronger), and typically there is a bit more margin built in.
Seeing as this will never actually happen in service, the wing spars break catastrophically when they do break. The engineers can predict rather accurately at which load they will break, and along which cross member.
Cessnapimp
Wed Feb 16, 2005 1:01 pm
Am I the only that thinks the test is more to impress the maintream media than to actually confirm that the wing is indeed solid. I mean, it's a pretty cool show but... you know...
...like the frozen-chicken-blasted-into-engine test... Great show I say.. but how many frozen chickens will an engine ingest in it's natural life? Granted, chickens WILL be frozen at 30 000 feet and up? How many african families are in dire need of those chickens? They would thaw pretty fast down there...
I say used the frozen chicken cannon where it is more needed in others parts of the planes... like those tray-table latch-thingies... or lavatory doors (Push...dumbass...push...).
Can a qualifiied tecunician pleez anwer the questionz???
DfwRevolution
Wed Feb 16, 2005 1:22 pm
Knowing the structural limits of the wing is an extreme way to confrim the accuracy of your design team. It also gives valuable data as to the exact load limits of the wing, which can later dictate growth variants of the aircraft (i.e A388F, A389)
I think for the 777, engineers were within a few centimeteres of the exact point where the spar fractured.
Composite = any fiber layered with a resin. This is not plastic, but people call it plastic because they are ignorant  Big grin
I believe the A388 wing is an aluminum-lithium alloy, while the fuselage is an aluminum-fiberglass hybrid called GLARE.
The wing literally explodes... very violent afair. Hence why no one is allowed near the aircraft during the test, and those conducting the test are practically in a bunker.
Crosswind
Thu Feb 17, 2005 1:13 am
I believe when they tested the B767's wing, it was so robust that the fuselage structure failed before the wing spar did - which they didn't manage to break in the test!
CROSSWIND
scbriml
Thu Feb 17, 2005 2:27 am
That wing may have been a tad over-engineered then  Smile
NoUFO
Thu Feb 17, 2005 5:14 am
Quoting Cessnapimp (reply 16):
Ever heard of bird-strikes during take-off or landing? And an engine can suck up other things than birds.
No, I don't think it's show. How many newsstations cover those chicken or wing tests?
Quoting Crosswind (reply 18):
When they tested the wings of the Lancair Columbia 300, the test construction that pulled at the wing broke, not the wing itself.
daedaeg
Thu Feb 17, 2005 5:25 am
Knoxibus, have they done an Ultimate Load test as well? What sort of fatigue and damage tolerance tests have they done on the 380 at this point?
Everyday you're alive is a good day.
FredT
Thu Feb 17, 2005 6:51 am
The frozen chicken story is just that, a story. A funny one though.
The bird ingestion test birds are thawed before being shot into the engine. There are other tests as well, such as blowing off a fan blade.
Yes, airframes are stress tested. This is done both for fatigue, where cycles are simulated with applied loads and pressurisation of the fuselage. Great care is taken to get a representative sample of load cycles for these tests. It takes decades to run these tests, they are running while the aircraft are in service. The point is to have any fatigue problems show in the fatigue test rigs before they show up in operation aircraft, so that you can take preemptive measures on the operational aircraft. You also use the results of these test to successively extend the fatigue life of the airframes.
Then you have the limit load tests, which are not staged as media events at all. Finally, you break the structure to see how well it corresponds to your predictions. At times, artificial damage is introduced beforehand to verify the effects on the breaking loads.
It has happened more times than mentioned here that the test equipment gave in before the structure being tested.
2H4
Thu Feb 17, 2005 7:17 am
I can't wait to see the "Building of the A380" and Building of the 787" documentaries, should they ever produce them.
2H4
Intentionally Left Blank
Thu Feb 17, 2005 7:33 am
Not the case. The tests are necessary for certification. They also confirm the calculations made. Sure, the computer model told you x, but what if your model is incorrect? Going out there and bending metal is the only way to really know.
Klaus
Thu Feb 17, 2005 7:46 am
The ultimate stress testing frame and the fatigue testing frame are both assembled by now as far as I know... And both are fully manufactured airframes, just without any non-structural systems or elements (no engines, landing gear, hydraulics, electric systems, cockpit or other interior). In exchange for that, they´ve got a huge number of additional stress simulation attachment points and a ton of sensors (quite possibly literally a ton of them...)  Wink/being sarcastic
I´ve read that the ultimate breaking point is expected when A380 wing tips will have been pulled up by about ten meters!
One of the things to be tested will be the stability of the (first ever) composite center wing box to which the wings are attached... I have no doubts that it will hold until the wings break, but it has to be verified nevertheless...
Stoney
Thu Feb 17, 2005 7:48 am
Do you think a video of the breaking of this wing will be available publicly, or do the manufacturers keep it secret. Let's look at the situation where average Joe sees a video of a wing breaking and almost exploding. I don't think he'll ever feel safe again on a plane.
It would be really cool if they would make highspeed-films (or whatever you call these) of the moments the wing breaks available, that would be cool, seeing frame for frame what happens.
Greetz
Stoney
BAZL - Bundesamt gegen Zivilluftfahrt - royally screwing around with swiss aviation
airgeek12
Thu Feb 17, 2005 7:53 am
wow! I can't wait to see the videos on FlightLevel380 of the A380 take offs and landings and see all the amazing wing flexs!
2H4
Thu Feb 17, 2005 7:54 am
Quoting Stoney (reply 26):
Check out "21st Century Jet". It's a PBS documentary about the building of the 777. In it, they show exactly what you're talking about....and if I remember correctly, they even replay it in slow-motion.
2H4
Klaus
Thu Feb 17, 2005 8:04 am
People know what it looks like when cars crash into each other... but it still doesn´t deter them - some even still refuse to buckle up!
I don´t think a wing breaking after it had been flexed way, way beyond anything they´ve ever seen on a flight would seriously faze the travelling public...
Users browsing this forum: ARNPEK, Starlionblue, T1a and 1 guest
