undies737
? For Pilots Of 4 Engined Aircraft
Sat Feb 26, 2005 8:03 pm
a question i have never got around to asking our pilots, during the last 4 years i've been maintaining 4 engined aircraft...
i am aware that during your aircraft conversion course (type rating), you are trained to handle the aircraft in most abnormal flight conditions.
with how many engines inoperative at any one time do you routinely practice? 1,2, maybe 3 in worse case scenario?
i have encountered 1 and only occasion.
enroute; malaysia-darwin where an engine (#2eng) was shut down. after i discussed with the loadie & captain how minor that "visible fluid leak" was, it was shut down in accordance with company policy and diverted to bali.
i thought nothing of it but there were many blank looking faces (infantry soldiers do have fears too). like the typical general public, they thought the worst when 1 of 4 eng was shut down in flight.
the term "loiter shut down", i have heard of it but cannot imagine shutting down an engine in flight to save fuel, after all a plane's performance and fuel economy is designed to be at its best when all engines are operating?
correct me if i'm wrong
thanx for any feedbacks
undies737
RE:? For Pilots Of 4 Engined Aircraft
Sat Feb 26, 2005 8:21 pm
A 4 engined aircraft with 3 inop engines will not be able to maintain altitude.
A one engine out scenario during the takeoff roll after V1 is the worst case engine out scenario, whether the plane has 2, 3 or 4 engines. If one more engine should shut down on a quad, IIRC the certification rules state that the (comercial) plane needs to maintain altitude, and this is a problem is you are on the runway on your way into the lights. So even if two engines out are worse than one, your options just went from some to "absolutely nothing I can do". If you are at altitude, your options are of course better.
1 engine is routinely practiced. If 2 engines out on a quad are I do not know.
"Loiter shut down". As you say, quads are built to cruise most economically with four engines turning. The exception is certain long range patrol aircraft like the Orion that gain more range at moderate speeds with two engines shut down.
Pihero
Sat Feb 26, 2005 11:35 pm
Undies737,StarlionBlue,
Yes,airlines do routinely train for engine failures.
The engine failure at V1 is part of the JAR andFAR requirements.
The cruise single and double failures are generally part of a loft training.
The triple failure scenario involves a light airplane,close to an airfield, therefore a very quick fuel dumping reaction from the crew is required as well as a continuous descent into landing as the altitude capability is severely reduced.
A very sporty proposition as the dissymetry is drastic,the approach speed very high, and the flight control situation could be difficult,depending on which engine is left ,whether the APU could be made available and so on...
Contrail designer
PhilSquares
Sun Feb 27, 2005 1:31 am
On the 744 a two engine approach and landing is required on every 6 month check. In addition to that, a 3 engine approach to a landing and a go around is also required.
On the 744/747 the APU isn't available for start in flight.
Depending on the gross weight and altitude the 744 can maintain the same flight level. But generally speaking, you are going to have to do a driftdown. Several techniques are available for that, but you would descent down to your optimum 3 engine altitude. On a 3/4 engine aircraft you can certainly continue to your destination. The FARs and JARs don't require a divert as they do in a two engine aircraft.
Flying a two or three engine approach is really no big deal. There is some asymmetrical thrust issues but it is very controllable with rudder. The worst case would be a go around at light gross weight. The 744 is very stable at high gross weights and actually easier to fly. (personal opinion).
Fly fast, live slow
LeanOfPeak
Sun Feb 27, 2005 2:02 am
The difference between the loiter shut-down scenario and an unplanned shutdown in cruise is twofold.
1) The altitude is set by the mission, i.e. electronic reconnaissance, subchasing, or SAR, so the aircraft is not flying at optimal cruise altitude regardless of the number of engines in operation. Engines derate with altitude, which is why you can run all the engines at a high power setting at altitude. When the aircraft is being operated at low altitude, there is considerably more power available, and, since the engines generally operate more efficiently at wide open throttle, it reduces fuel flow in specific circumstances to run half the engines wide open compared to running all the engines "half open."
2) Loiter means loiter. Optimal endurance is achieved at a lower speed than optimal range and is optimized differently.
undies737
Sun Feb 27, 2005 7:54 am
thanx everyone for all your informative feedback.
having only a student pilot licence, all my 4 engine experience came from flying the C130J,B707 simulators i have at work. whenever i get a chance for a play, i usually make a point of practicing assymetrics with an outboard engine out or even 1 outboard & 1 inboard (1&3 or 2&4) inoperative.
got any pointers/tips?  Big grin
dave
raggi
Mon Feb 28, 2005 9:04 am
Quoting PhilSquares (reply 3):
If on a quad you lose both engines on one side, is this statement still true? Which engines are normally simulated out on training? I remember my groundschool teacher told me stories from training when he flew the C141, and losing engines 1 and 2, or 3 and 4 was apparently a "big deal"...
raggi
Stick & Rudder
PhilSquares
Mon Feb 28, 2005 7:08 pm
On the 744, there is no real "critical" engine side. Although, having the upwind side with the engines does make is slightly more challenging, but it's no where near being a big deal.
Fly fast, live slow
lyzzard
Wed Mar 02, 2005 7:53 pm
All engine flame out scenarios are often practiced during conversion training. This is a possible occurence should an aircraft encounter flight into an area of volcanic ash.
And in addition to 2 engine approaches (on a 4 holer), 2 engine go-arounds are sometimes practiced too. It's quite a dicey maneouver but is possible with practice.
I'm not sure of the term "loiter shutdown". Perhaps the only instance, which I can think of, in which an engine would be intentionally shutdown would be on the taxy segment. Oftentimes, company procedures might allow 3 engine taxi (on a 4 holer) in order to save fuel in case of a long taxi route or delays.
LeanOfPeak
Thu Mar 03, 2005 1:52 am
Loiter shutdown is not generally referring to a civil operation. I know it was done in PBY's doing low-level missions in WWII. I also believe it has been done more recently in P-3's.
411A
Thu Mar 03, 2005 6:28 am
Some years ago DanAir, when they were operating deHavilland Comet 4 aircraft, applied to the UK CAA to be able to shut down one engine in cruising flight, so as to improve operating economics....the Comet 4 being somewhat overpowered as it was.
The CAA replied...absolutely NOT. And, so they should have.
A daft idea, for civil ops.
Military ops, on the other hand, are a different kettle of fish.
undies737
Fri Mar 04, 2005 6:58 pm
Yesterday, I had the opportunity of doing some asymmetrics 800ft over Hong Kong in a B707 sim (#3,4 out). Directional control is not much of a problem at 290KIAS & the instructor restored pwr on #3,4 soon as I picked up the dead wing.
Another question I have; what type of "run up" checks are done on a turbofan/jet before takeoff.
is there a reason I've never heard a jet spool up for such pre-takeoff checks. whereas a piston will have a mag check & turboprops have a prop overspeed governer check.
thanx again for all the insight
Is there any a.netters from australia (sydney) who could show me through some widebody Boeing/Airbus simulators, please drop me a line.
undies737.
707greasemonkey
SQ325
Sun Mar 06, 2005 3:13 am
Hey
On the RJ85 we do 2 engine approaches landings and go arounds every 6 month!
We also simulate a double engine failure shortly after V1 especialy in airfields like florence this is a pretty tough thing!
If we have a flame out on one engine we don't even declare emergency!
And we can maintain a safe altitude with 3 engines and also with 2 engines!
J32driver
Sat Mar 12, 2005 2:00 am
Flew the 146 for a while. Every sim ride we saw a V1 cut, bring it back around for an approach, go missed, lose the 2nd engine as you shoved up the power for the missed approach. Then flew 2 approaches on 2 engines only (either 1 &2, or 3&4).
Users browsing this forum: akiss20 and 1 guest
