milan320
Airbus Autothrottles And Landings
Thu Mar 03, 2005 2:00 am
I performed a search, but couldn't find anything substantial. Could any of the Bus drivers enlighten me about auto-throttles and manual landings (non-autopilot).
I know that the throttles should be set to idle just before landing (from what I heard when the verbal RETARD is heard), but what about the final approach?
Is it preferable to disconnect the autho-throttles and control them manually, or can you use them when hand-flying the landing.
/Milan320
I accept bribes ... :-)
744lover
RE: Airbus Autothrottles And Landings
Thu Mar 03, 2005 2:42 am
Hi Milan320,
On my airline, the AP is disconected when you have visual contact with the runway and the AT is left on (leaving the levers on the "CL" postion) until you hear the "RETARD" voice.
This is a good practice 'cause if you encounter variable wind on final, the AT will correct the power to mantain the speed on approach.
See ya,
GHN
milan320
Thu Mar 03, 2005 3:14 am
Thanks 744lover.
That's what I thought, and I figured it's also one less thing to worry about on approach. I wonder if this is standard practice on other airlines.
/Milan320
SlamClick
Thu Mar 03, 2005 4:50 am
It was at my airline too.
As a review; the A/T can control the engine thrust from just above an idle anywhere up to the thrust lever setting which should be CLimb at this point. It can make for lazy piloting because with the A/P disconnected all we have to do is "point" the plane where we want it to go (down a three-degree glideslope, for example) and the box runs the engine power to maintain the approach speed that is commanded. Simple!
In general (non-airline and non-aircraft specific) the good advice is to select an "appropriate" level of automation. That can range from doing everything to doing almost nothing. In the Airbus system it is almost always desirable to leave the A/T connected.
Pihero
Thu Mar 03, 2005 5:22 am
There are a few airlines where manual flying means manual throttles.
I find full manual flying very rewarding on the 'Bus.
After all it's an aircraft like any other.
What about the Boeing drivers ?
Contrail designer
B747FE
Thu Mar 03, 2005 6:35 am
We always use manual throttles, except when flying a CAT II approach.
Not yet a "driver" though. Hopefully soon.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
milan320
Thu Mar 03, 2005 9:01 am
Good stuff, thanks to all of you for the information.
Cheers!
/Milan320
JETPILOT
Thu Mar 17, 2005 3:01 am
Airbus A320,330,340 don't have auto throttles. They have auto thrust. Different system operation than auto throttles.
JET
jonty
Thu Mar 17, 2005 4:45 am
do pilots like to use the A/T to land? Is it not more fun/interesting to do it yourself?
And can you turn that annoying guy off who shouts retard at you? It allways makes me laugh when I hear that, not that I fly like, but when I watch videos!
Jetlagged
Thu Mar 17, 2005 7:36 am
As has been explained above the A/T makes landing much easier, by reducing pilot workload. That's true of any type, whether the throttles move or not. It's not really about fun. The A320 is designed to be flown that way.
I've only flown an A320 simulator (not being licensed to be let loose on the real thing sadly) but I found it rewarding to hand-fly and a great improvement on the traditional yoke style of control. You soon get used to the idea of leaving the throttles at the CL detent, even if "REtard REtard REtard" is a bit annoying.
You can pull a couple of CBs to kill the voice, but why bother. You know it's not a reference to your flying skills or personality Big grin
schooner
Thu Mar 17, 2005 8:22 am
Can only comment on the 757 but Boeing strongly recommend "autopilot out/auto-throttle out" and autopilot in/auto-throttle in". The only exception being during departure when climb thrust is selected you are "allowed" to fly manually whilst leaving the auto-throttle engaged.
Cheers.
Untouched and Alive
Jetlagged
Thu Mar 17, 2005 9:37 am
I'm just lazy. I find using the auto-throttle helps me on manual approaches as a non-pilot in a sim. I wasn't aware of the afore mentioned Boeing recommendation.
I do recall that British Airways 747 Classics were set up so that if you disengaged the A/T, the AP would automatically disengage, and vice versa. This was not the normal 747 config, where an AP mode might disengage as a result of A/T mode changes, but this would not cause a complete AP disconnect.
wing
Thu Mar 17, 2005 3:57 pm
While flying the 737,it was Auto pilot off/Autothrotlle off.That was because of the small speed changes on the final approach(especially in windy and gusty weather) autothrottle gives thrust changes to maintain the final aproach speed set on the speed window,this causes aircraft nose to pitch up and down with the thrust changes(because the engines are wing mounted) and requires trim changes also.So Boeing recomends AP/AT disangage together.(In some really gusty weathers you can see the Airplane goes mad while trying to compensate 2-3 knots excess speed even if it was not said, you feel like you want to disengage the AT anyway to end the stupidity)
But on the Airbus there is a marvel called Fly by wire.This helps reduce the nose pitch up and downs with power application and the airplane trims itself perfectly.Result is you can fly a perfectly stable approach with the "Autothrust" engaged.The retard callout is only a reference, pilot decides when to close the thrust depending on the wind,gust,airplane weight(but there is something you have to keep in mind until you retard the throttles the autothrust will keep the last speed it was maintaining)
follow me on my facebook page" captain wing's journey log"
jonty
Tue Mar 22, 2005 12:45 am
Quoting Jetlagged (Reply 9):
lol.
but doesn't using all this auto stuff just mean that you do even less actual flying, as in at takeoff you pop it into TO/GA and the computer does it, you lift off, and then pop the A/P on and let the computer do the rest, then come in to land, and have the A/T on so the computer does that, and then when it shouts retard you do that and then the plane can stop its self (I think - using autobrakes that the computer decides how much to use of - is that right?). Don't you just end up sitting there and watching a computer do your job?
Tue Mar 22, 2005 12:53 am
Quoting Jonty (Reply 13):
You can trace the increase in automation and ease of flying very far back. I'm sure pilots balked at the prospect of not sitting in an open cockpit. But that's progress.
If you Airbus pilots most of them they don't feel this way. The job of the airline pilot is to stay as close to the center of the envelope as possible. If you want to fly on the edge and really "pilot" by the seat of your pants, you should stay in the military.
wing
Tue Mar 22, 2005 6:08 pm
Thats not quite correct,being in the center of the envelope is being to far behind the aircraft and it is not desirable.A jet pilot should be way ahead of the airplane and should anticipate what the airplane will do next as a reaction of your command and you should plan accordingly.Most of the times we even anticipate what an ATC will ask us next even if you are not familiar with the area.(You expect a late descent clearence when hearing another traffic comming towards you at a lower alt than you are,or when you see there is surrounding terrain which prevents the ATC to clear you lower,you have see and anticipate this before hand.If ATC gives you late descent and you keep flying with .79M(since you are in the center of the envelope) when you recieve the clearence you will be very high and struggle to descent and reduce speed all the way down,and if there are other traffics and speed restrictions you put yourself in a highworkload situation.
Jonty;
There are many people thinks that the airline pilots are actively manupulating the controls of the airplane to fly the airplane.Thats not quite the way in most of the "normal day"operations.
I can define an airline pilot as a chief of symphony orchestra.You never see a maestro play an instrument but because of him a whole bunch of instruments create a very harmonic music.
As an airline pilot thats what we do.When you buy a ticket to travel from point A to B a whole team of people works to make this travel possible and the captain is the maestro of this orchestra,providing the operation goes smooth and on time.
Inside the cockpit its the same.This time the orchestra is not the humans but the instruments inside the cockpit and the others around you.The state of the art "auto stuff" is so dumb that it doesnt even know where it is unless you tell it .You have to be ahead of everything to make precise and timely decisions(which is the number 1 job of the pilot,flying the controls comes later)As an example you wake up to a sunny day in Antalya,you come to the dispatch office see that its raining with very low visibility in London.Can you land there,what if you divert,how much fuel extra you need?What will you do the pax?take them to a hotel or drive then with a bus?Who will arrenge the bus?Will this effect the publicity of the airline?Do you have an handling agent on the alternate airport?who will bring the stairs?How much will this diversion cost to the company?
Now you have to decide for something which will happen 5 hours later.And this is what you will be doing constantly during the next 5 hours.Be infront of the game decide accordingly.Flying the airplane is a big extra load while doing that,thats why the engineers work very hard to reduce this load from the pilots shoulders,so the human can make more healthy decisions.
While I was flying the 737400 the min AP engage alt was 1000',on the 737800 it was better at 400 ',Now in the A320 its 100 feet or 5 secs.It constantly reduces my manual flying time but does this makes me a lesser good pilot?Ofcourse not.Flight training will never end even if you are the chief pilot himself,we all practice manual flying skills with all the chances we have. And in the simulators too.
And during the normal day operations do what we are supposed to the "make decisions" and let the dumbest pilot in the cockpit fly the airplane which is also called as the "Autopilot"  Smile
Tue Mar 22, 2005 11:23 pm
Quoting Wing (Reply 15):
I meant it as "not straying towards the unsafe edges of the envelope".
speedracer1407
Wed Mar 23, 2005 2:31 pm
Inside the cockpit its the same.This time the orchestra is not the humans but the instruments inside the cockpit and the others around you.The state of the art "auto stuff" is so dumb that it doesn't even know where it is unless you tell it .You have to be ahead of everything to make precise and timely decisions(which is the number 1 job of the pilot,flying the controls comes later)
This is part of Wing's interesting analogy that piques my curiosity about the younger generation of Airline pilots. Seems to me like a young airline pilot experiences way more automation than those who sharpened their teeth on 707s and the like. Which, of course, isn't to say that such younger pilots are less safe or less capable, but rather, masters of a different kind of flying. Certainly a young pilot doesn't need to know the "feel" of the hydraulic/mechanical tanks of yore. But what IS the feel of modern FBW planes? When a pilot hand flies, is he now calculating speed, thrust, angles of attack, and such, then making the necessary inputs on a lifeless stick? Or does he still "drive" the plane, in part, from the seat of his pants?
I suppose questions like these are eternally nagging ones for those of us "wish-we-were-pilots" enthusiasts, but I'm curious about the differences in skills that pilots of very modern planes must master, versus those of older ones.
O
wing
Wed Mar 23, 2005 9:55 pm
Starlionblue ,
I misunderstand the word "envelope",my mistake,sorry.  Smile
Speedracer1407,
I don't know how to start(I m in a hurry for an afternoon flight)but I like to make my words a little clearer for you.
No matter what equipment they fly and no matter what generation they come from,every pilot has to have certain level of "basic flying" what we say "stick rudder" which does not involve any level of automation.
As I wanted to explain above the the state of the art Automation and the Autopilots are nothing but a tool which helps to reduce your workload,therefore increase safety.I have never seen any autopilot which knows where we are on the ground,which airport we are flying to before I come in an load it.In every day operation any kind of automation is there for you to use it,using it doesnt make you a lesser good pilot.The automation started in the very early days of the aviation as is going on still.The 707s youve mentioned had the autopilots,and they had the flight engineers to make the calculations instead of FMS like we have today.The main idea on the other hand has never changed,the airline pilot was an orchestr chief then and still is now,and will be in the future.Only the stick in his hand that controls the players is getting better but still does the same job.
If you want to keep your skills sharp we always fly some manual stick,throttle flying same as we flew the C172 years ago.We practice every sort of emergencies(including single and dual engine failures,hydraulic failures,total electric failures etc.)You can not occupy the seat if you can not demonstrate the skills in the check flights.
As a result any pilot(young or veteran) on newer or older airplanes flies with the same mentality of the flying,still with the basic T instrumention,and power pitch rules are still the same.I hope that makes sense.Best wishes.WING
milan320
Thu Mar 24, 2005 3:55 am
Wing, great posts. Welcome to my RR list.
Cheers!
/Milan320
IFIXCF6
Thu Mar 24, 2005 12:40 pm
Wing,
Post 15:
caused concern to me.
Post 18 alleviated my worries.
In one of our aircraft is the placard: "IN AN EMERGENCY...FLY THE AIRPLANE"
As a mechanic, I thought it was clarifying: don't be destracted by unnecessary thoughts.
Mike
mandala499
Thu Mar 24, 2005 5:12 pm
In an emergency, fly the airplane... once you have control of the plane, diagnose, solve.
If solved, then think where to go.
If not solved, think where you can go before U can't go anywhere...
 Smile
Sorry, just throwing a pun here  Smile
Mandala499
wing
Mon Mar 28, 2005 2:26 am
IFIXCF6;
There is nothing to worry about what I said,I was speaking about a decision made at the dispatch office,not in an emergency situation.
What you called unnecassary thoughts are the everyday work of an airline pilot,making decisions at the dispatch office,while accepting the airplane from technic,during cruise,in an emergency and it goes until you leave the airplane.
jonty
Wed Mar 30, 2005 9:36 am
sorry to drag this out even more, but if one day a pilot decided he wanted to fly higher thatn 100 feet in his A320 would it be frowned upon if he didn't engage the autopilot and flew for a bit by himself?
wing
Wed Mar 30, 2005 6:29 pm
No you can hand fly the airplane as much as you want,my company "encourages" to handfly until 10000 feet on departures and from 1000' to landing.But anytime you want more go ahead,do it.(you should consider the workload it creates to the PNF though,he does the PNF duties,talk to ATC and the things you can not do while you are hand flying),so in very busy environments its better to use the AP and reduce the workload in the cockpit.
XXXX10
Fri Apr 01, 2005 8:44 pm
Does all of the above mean the Bus (or any other a/c) cannot be dispatched if the Autothrottle is not working?
Fri Apr 01, 2005 8:50 pm
Quoting XXXX10 (Reply 25):
I don't know, but I would imagine you can't dispatch a 737NG without the A/T working wither. Just a guess.
wing
Sat Apr 02, 2005 12:32 am
You can dispatch the airplane with AT inop also you can dispatch the airplane with the A/P inop but certain conditions may apply depending on the company SOP.
ba299
Sat Apr 02, 2005 3:48 am
On the 777 we fly every approach with A/P off and A/T on. The A/P normally are disconnected when we are established on the ILS.
Users browsing this forum: LY777 and 20 guests
