Bruce
Eastbound, Westbound, And Fuel Stops
Tue Mar 22, 2005 1:22 pm
I always get them mixed up. Which direction do planes on long haul flights usually need a fuel stop? I want to say eastbound....because I'm thinking there is increased wind and therefore higher fuel burn. But doesnt the prevailing winds flow from west to east? That would give an eastbound a tailwind.
I've seen several flights on the trackers that are able to make long hauls westbound but not eastbound. For example, a flight out of New York can go to HKG non stop but coming back they will probably need a fuel stop. Freighters thatgo between Huntsville and Asia can go westbound non stop but almost always stop in ANC on the way back, with 742's sometimes needing an extra stop.
bruce
PolAir
RE: Eastbound, Westbound, And Fuel Stops
Wed Mar 23, 2005 4:08 am
General direction of winds (round a world I think) is from west to east. Therefore, eastbound flights will most likely fly faster (tail wind) and burn less fuel, therefore not requiring to stop. I hope that helps.
Bruce
Wed Mar 23, 2005 6:03 am
Well that's what I thought too but there are lots of examples of eastbound flights that require a stop. Are the winds at cruise levels different than here on the ground (opposite direction)?
bruce
411A
Wed Mar 23, 2005 6:12 am
Keep in mind that freighter aircraft, when departing westbound from the USA are rather light...ie; not much cargo.
Lighter weights, with jet transport aircraft, result in a much lower hourly fuel burn, headwind or not.
Westbound, from Asia, for example, they are very heavy (lots of cargo) and as a result, a fuel stop might definitely be required, even with a tailwind.
Bruce
Wed Mar 23, 2005 8:16 am
What about passenger flights. I don't think an A340 can go from Hong Kong to New York? But they do fly from New York to Hong Kong.
Cathay-Pacific flies an A340 from HKG to NY with a stop in YVR.
bruce
citationjet
Wed Mar 23, 2005 9:46 am
NYC to HKG is not really a westbound flight. It is more a north-south routing.
Go to Great Circle Mapper http://gc.kls2.com/ and enter JFK-HKG. You will see that the flight goes straight north, near the North pole.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
PolAir
Wed Mar 23, 2005 3:49 pm
Bruce,
I am not an expert, but 90% of time gound speed will be higher eastbound (at higher altitudes). A lot depends if you can catch a jetstream, it will give you hell of a boost, and as far as I know jetstream can head north, east or south but never west ( correct me here).
Like Citation said, HKG-NYC is not really westbound.
Thu Mar 24, 2005 12:23 am
Quoting Bruce (Reply 4):
Depends what version. The 345 could. EWR-SIN is longer.
Users browsing this forum: CosmicCruiser and 1 guest
