JAM747
Difference Between Flaps And Slats?
Sat Apr 02, 2005 1:36 am
What is the difference between flaps and slats. Does it depend on the size or type of aircraft or do all aircrafts have both.
FredT
RE: Difference Between Flaps And Slats?
Sat Apr 02, 2005 1:40 am
Do a search. The subject has come up in several incarnations here over the last few weeks.
The terminology is somewhat confused. My definition is that slats (and slots) are leading edge devices while flaps are trailing edge devices.
Fred
OPNLguy
Sat Apr 02, 2005 1:55 am
Quoting FredT (Reply 1):
It gets more confusing because Boeing uses leading edge Krueger flaps. MEL deferrals on L/E indication systems can get challenging sometimes because of the phonetic similarity between flaps (not deferrable) and slats (deferrable, with exceptions), and one has to annunciate very clearly.
Sat Apr 02, 2005 2:23 am
Slats are usually mounted on the leading edge. Slats extend the edge and sit like a glove on the edge.
Flaps are usually mounted on the trailing edge but can be mounted on the leading edge. They extend the edge but are not mounted like a glove. They either pivot only (simple and split flaps), extend and come down (complex and slotted flaps) or extend and camber (Krueger flaps). There are other types as well.
411A
Sat Apr 02, 2005 7:27 am
Not forgetting 'droops'...as on the first civil jet transport aircraft to achieve complete automatic approach/land certification...the HS.121 Trident.
A superb achievement, at the time.
Left the yanks FAR behind in automation.
And, I admire 'em greatly...even as a yank. Smile
UAcsOKC
Sun Apr 03, 2005 9:54 pm
Quoting 411A (Reply 4):
Also had problems with deep stall, associated with the droops. guess nobody's perfect....
I love the rumble of a 727 takeoff in the morning!
411A
Mon Apr 04, 2005 6:24 am
Yes, nobodys perfect, UAcsOKC, especially the First Officer, who altho confused, nonetheless, retracted the droops far too soon.
Gotta watch these contrary co-pilots.  Wink
dubliftment
Thu Jul 17, 2008 2:37 pm
as far as I know, "slats" is an abbrevation for "slotted flaps", meaning they have a nozzle like slot between the high-lift device and the wing. on the contrary, krueger flaps do not have this slot.
474218
Thu Jul 17, 2008 9:08 pm
Quoting JAM747 (Thread starter):
Photo © Mint Photography Ltd - Kevin Minter
retracted slats
Photo © Sam Chui
extended slats
Photo © Walter Wilson
flaps retracted
Photo © Peter Kesternich
flaps extended
avioniker
Thu Jul 17, 2008 9:15 pm
Very simply put (and there are exceptions) Flaps are an extension of the wing and may or may not affect the aerodynamic chord length and angle.
Slats are more akin to an additional wing, forward of the wing, and act more to add lift than drag. Of course many aircraft have slats with more than one selectable position that may or may not be sealed to the wing in partial extension. So they act as flaps or slats depending on position.
Both flaps and slats act to lower the stall speed of the aircraft and provide enhanced low speed maneuverability.
I personally like the "slotted flap" explanation/definition. It makes sense and is easy to visualize.
 Smile
tdscanuck
Fri Jul 18, 2008 1:37 am
Quoting Avioniker (Reply 9):
Slats do very little to add lift directly. Their main contribution is to allow an increases angle of attack prior to stall. It's the increased AoA, not the slat itself, that generates the extra lift.
Tom.
WPIAeroGuy
Fri Jul 18, 2008 2:29 am
Flaps, slats, kreuger flaps, etc. all work by increasing the camber of the wing, which allows for a higher AoA and increased drag. Some flaps also increase the chord.
Slats have a gap between the slat and the LE, airflow through the slot is redirected over the top surface of the wing, increasing airflow over the wing which increases lift. Slotted flaps work on the same princicple, the slots in the flaps allows for the airflow to remain stay attached through higher angles of attack, ergo creating more lift.
I know the Bf-109 and F-86 had leading edge devices that responded automatically to prevent loss of lift in high AoA situations. I believe the F-22 has similar devices though I may be very wrong.
-WPIAeroGuy
wingscrubber
Fri Jul 18, 2008 2:41 am
JAM747, Flaps are trailing edge lift aids/drag inducers, slats are leading edge lift aids/drag inducers. Flaps are on most anything that flies with some exceptions, but slats are generally only prevalent on bigger aircraft, but there's exceptions to that too.
This is my favourite wing design ever - achieves fantastic STOL. Big fat camber with fixed slat and flaperon. Brilliant.
Resident TechOps Troll
Zuluaviator994
Mon Jul 21, 2008 12:41 am
Quoting Wingscrubber (Reply 12):
Wingscrubber
What plane is that?
If Speed is life, Altitude is life insurance. No one has ever collided with the sky.
Mon Jul 21, 2008 12:46 am
I disagree. There are plenty of flaps on leading edges, for example on the 747 and the 737.
boeing767mech
Mon Jul 21, 2008 1:13 am
Quoting Starlionblue (Reply 14):
Don't forget the CV-990A
David
Never under-estimate the predictably of stupidty
wingscrubber
Mon Jul 21, 2008 4:46 am
Thats the Zenith CH701/801 wing. Sorry should have said what it was...
Pihero
Mon Jul 21, 2008 10:36 am
....and really nothing new since the Fieseler Storch .
From Wiki :
" Penned by chief designer Reinhold Mews and technical director Erich Bachen, Fieseler's entry was the most advanced in terms of STOL performance, by far. A fixed slat ran along the entire leading edge of the long wings, while the trailing edge, inspired by earlier 1930s Junkers aircraft wing control surface designs, including the ailerons, was a hinged and slotted flap. The wings could be folded back along the fuselage, allowing it to be carried on a trailer or even towed slowly behind a vehicle. "...
"The first Fi 156 V1 prototype flew in the spring of 1936. It was powered by a 180 kW (240 hp) inverted-vee Argus As 10C V8 engine, which gave the plane a top speed of only 175 km/h (109 mph), enabling the Storch to fly as slow as 50 km/h (32 mph), take off into a light wind in less than 45 m (150 ft), and land in 18 m (60 ft). "
Contrail designer
MD-90
Mon Jul 21, 2008 11:33 am
Never going to win any races, however.
Mon Jul 21, 2008 2:37 pm
Quoting MD-90 (Reply 18):
If they had a STOL competition.  Wink
Nicoeddf
Mon Jul 21, 2008 5:22 pm
And speed is not always your friend...lift is...in the air...and in the bed... Big grin
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
Tristarsteve
Mon Jul 21, 2008 8:07 pm
Quoting Tdscanuck (Reply 10):
My recollection is that the droop leading edge on the Trident 1 increased the lift by 40pc. When the pilot retracted the droops the plane stopped flying.
The original Trident design had two levers, a droop lever and a flap lever. After this accident they were interconnected with a baulk system, and from that day (1968) all aircraft had a single lever.
Later Tridents had slats instead.
MD-90
Tue Jul 22, 2008 2:40 am
Quoting NicoEDDF (Reply 20):
haha good one. I hear that the Zenith 701/801 series fly well. They certainly seem to be popular with homebuilders.
Users browsing this forum: andrewfarmer, kalvado and 2 guests
