Doona
707 Heavy?
Thu Apr 07, 2005 5:41 pm
I'm listening to the Okinawa Approach frequency, and the American controllers keep referring to C-135s from the airbase at Naha as heavies. Does the 707 qualify as a heavy? And if so, does the DC-8 aslo fall under that category? (At least the stretched series would...)
Mats
UAcsOKC
RE: 707 Heavy?
Thu Apr 07, 2005 7:14 pm
Depends on the gross weight of the aircraft. Some can be "Heavy" but not always qualify.
I love the rumble of a 727 takeoff in the morning!
C133
RE: 707 Heavy?
Thu Apr 07, 2005 9:43 pm
300,000 pounds and above, if I remember correctly, is designated as "heavy". 707-100 series, no, 300 series, yes. KC-135s? Didn't know they were that heavy, but you're hearing it.
Fine: Tax for doing wrong. Tax: Fine for doing well.
miamiair
RE: 707 Heavy?
Thu Apr 07, 2005 10:32 pm
The 757s are also considered heavies for traffic separation purposes. But the magic number is 300K.
sanjet
RE: 707 Heavy?
Thu Apr 07, 2005 11:13 pm
Quoting Miamiair (Reply 3):
True, the 757 does have a MTOW less then 300,000lb but is considered heavy because of the wake turbulence it creates to allow speration.
The 707-320 does have a MTOW more than 300,000lb so yes and all dc-8 have a MTOW of more than 300,000lb so yes it's a heavy also.
Will Fly For Food!
OPNLguy
RE: 707 Heavy?
Thu Apr 07, 2005 11:56 pm
In the US, the threshold for a "heavy" was 300,000 lbs. for a long time, but was lowered to 255,000 lbs several years ago.
Some 757-200s have MGTOWs of less than 255,000 and are not technically heavies by definition, but are treated as such for separation purposes. Some customers took their 757-200s with optional MGTOWs above 255,000, and these, plus the 757-300s are technically heavies, but again, all 757s are treated as such.
Doona
RE: 707 Heavy?
Fri Apr 08, 2005 12:21 am
Thanx for all your speedy replies!
Mats
N766UA
RE: 707 Heavy?
Fri Apr 08, 2005 3:18 am
I don't know why people keep saying this. The 757-200 is given special attention by controllers for wake turbulance but it is not considered a heavy. Only ATA's 752s are heavies as they exceed 255,000 lbs. The 757-300 is, however, a true heavy.
This Website Censors Me
timz
RE: 707 Heavy?
Fri Apr 08, 2005 7:50 am
"and all dc-8 have a MTOW of more than 300,000lb so yes it's a heavy also"
Maybe-- but a few years ago DC-8-51s were still flying, and they were less than 300K. Maybe they still are?
N766UA
RE: 707 Heavy?
Fri Apr 08, 2005 8:18 am
Quoting Timz (Reply 8):
There aren't exactly a whole bunch of -51s left, but if they're over 255,000 that's all that matters.
C133
RE: 707 Heavy?
Fri Apr 08, 2005 1:12 pm
Quoting OPNLguy (Reply 5):
To further complicate the issue, a working 777 captain friend just advised me that yes, the crossover point within the U.S. is 255,000 pounds, but everywhere else it's still 300,000. Next, someone will say that the U.S. is the only country that isn't metric!
Stealthz
RE: 707 Heavy?
Fri Apr 08, 2005 3:51 pm
Quoting C133 (Reply 10):
A whole new can of worms!! Don't get me started on that one. LOL
Chris
Lt-AWACS
RE: 707 Heavy?
Sat Apr 23, 2005 3:33 pm
the C-135s are not 707s (pet peeve), they are just a tad "thinner" and shorter, but your question/point is taken.
In the E-3 (707-320) we are well over 300,000 and are always "Heavy" ditto the E-6 TACAMO, and E-8 J-STARS-- listening to various 135 tanker/tower ops I can honestly say I have heard "Heavy" for some but not all, so it is an interesting question on the weight. I will venture a guess the fuel offload inflight might play a part but don't know for sure.
Ciao, and Hook 'em Horns,
Capt-AWACS, Houston-first word spoken from the moon
Io voglio fica ogni giorni da mia bella moglie!
learpilot
RE: 707 Heavy?
Sun Apr 24, 2005 6:10 am
Quoting N766UA (Reply 7):
Isn't the whole point of the classifying of aircraft as "heavies" due to increased wake turbulence separation afforded to aircraft following them in the terminal area? Therefore the 757-200's that are below 255,000#, while not being a heavy by definition, are considered heavy in the way they are handled by ATC.
It shouldn't matter what weight you are currently operating at. The determining factor is your max takeoff weight.
[Edited 2005-04-23 23:17:34]
Heed our warnings or your future will be underpant free!
gigneil
RE: 707 Heavy?
Mon Apr 25, 2005 9:55 pm
Quoting Learpilot (Reply 13):
Unless its an ATA 752, you'll never hear "airline blah blah heavy" for a 757-200.
N
jfkaua
RE: 707 Heavy?
Tue Apr 26, 2005 6:44 am
why do ata's weigh more?
OPNLguy
RE: 707 Heavy?
Tue Apr 26, 2005 7:56 am
Quoting Jfkaua (Reply 15):
In some ways, buying airplanes is like buying cars. There are standard features, and there are options. One of the opions available on the 757-200 was the ability to operate it at higher weights than the "standard" 757-200. Some airlines ordered theirs this way, and some didn't. Some operators may have some of both in their fleets....
learpilot
RE: 707 Heavy?
Tue Apr 26, 2005 11:35 am
Quoting Gigneil (Reply 14):
That's correct. Once again, they do not use "Heavy" in their call signs (I'm talking about your generic 757 like United and AA's), but ATC treats them like they are a heavy. For example, where a Regional Jet would only be required to follow a DC-9 or a A-320 by 3 miles, it would have to follow a 757-200 (non-heavy), as well as a heavy 747, ATA 757-200, 757-300, 767, 777, A-340, etc...all by 5 miles.
kc135topboom
RE: 707 Heavy?
Wed Apr 27, 2005 12:23 am
The KC-135R/T has a MTOGW of 330,000 lbs. The KC-135E has a MTOGW of 315,000 lbs. The KC-135A/Q has a maximum ramp weight of 301,600lbs, for a MTOGW of 299,600.
Users browsing this forum: AAairplane, GloomyDe and 1 guest
