Bruce
Reading A Flight Plan
Mon Apr 25, 2005 5:44 pm
I'm trying to understand flight plans. I think I've got it almost figured out but not sure of a few things. here is a sample flight plan from one of the online flight trackers for a fairly short flight arriving at my home airport:
DTW..LAYNE.DXO006.BNNET.YQG341.DIRKS.J38.GRB/0052
Now I've looked up the navaids and fixes. First of all, what is the difference between one dot and two dots?
Ok. So here goes. Plane leaves DTW flying to LAYNE on the 006 radial of DXO. "LAYNE" is located according to my map in the northern suburbs of Detroit....and DXO is the Detroit VOR near the airport, so it appears that LAYNE is on a heading of 006 from DXO. Is that what it means when there are numbers following a fix?
Then it would turn north and head toward BNNET which is located near Lapeer, MI (according to the lat/long). Then, the plane would turn northwestward onto the 341 radial of YQG which is in Windsor, Ontraio and on to the next point which is DIRKS, which is kind of SE of Saginaw. From there I would guess that it is a straight run? I think that J38 is an airway and seeing how there are no other fixes then they would go all the way on J38? (its 239 miles according to my map).
Now GRB is my airport....but what does 0052 mean? When they approach GRB on the airway they would be going NW...so why the 52 heading? (Or is that a heading?)
bruce
Goldenshield
RE: Reading A Flight Plan
Mon Apr 25, 2005 8:39 pm
If you got it from an online flight tracker, then this is an internal ATC routing. The filed and cleared route is going to be different. Most likely this is an airborne reroute.
LAYNE intersection is a fix on the PALACE 2 departure out of DTW. Most likely, the route was filed via another fix, and ATC decided to change that plan (as they often do.)
The 0052 is the time enroute using the given route and filed true airspeed.
OPNLguy
Mon Apr 25, 2005 9:31 pm
Quoting Bruce (Thread starter):
A single dot is used between disimilar elements, and two dots ("direct") are used between similar elements, all for ATC computer requirements.
Examples:
VORs- PNH..GAG
VORs/Radials- TTT171..CLL334
VORs/Radials/DMEs- PGS085100..VIH261145
Airports- IAH..HOU
Intersections- STELL..DONIE
Victor Routes (Low altitude)- V123..V456
Jet Routes (High altitude)- J123..J456
All the above are similar elements, so there are two dots. The single dot is used when connecting two elements that are different from one another (from the above list) and are also used for SIDs/DPs and STARs.
DP/SID- DFW.JPOOL3.WINDU
STAR- SGF.TRAKE8.STL
As Goldenshield mentioned, 0052 is the enroute time. The two digits on the right are minutes, the two on the left are hours. Thus 0052 is 52 minutes, 0152 is 1 hour and 52 minutes, and 1052 is ten hours and 52 minutes.
Hope this helps...
3201
Tue Apr 26, 2005 2:39 am
Quoting Goldenshield (Reply 1):
Careful -- it is indeed the planned time enroute, but it's as calculated and supplied by the operator when filing the plan. It should actually not match up with the planned distance and the filed initial cruise TAS, unless you plan to climb and descend as fast as you cruise.
7 hours aint long-haul
Bruce
Thu May 26, 2005 12:31 am
Ok, another question. What does the numbers mean that are next to a VOR? For example, part of a flight plan:
DLH231140..GRB288082
bruce
Woodreau
Thu May 26, 2005 12:48 am
Hi Bruce,
It's probably a Place-Bearing-Distance Waypoint.
So in your case
DLH231140
DLH (Place) 231 (Bearing) 140 (Distance)
So from the DLH navaid (probably a VOR)
on the R-231 or 231 degree radial (magnetic)
140nm
Same from GRB288082
GRB vor - R288 - 82nm
Bruce
Thu May 26, 2005 1:05 am
Could it possibly be the other way around? DLH = Duluth, MN. The Distance from Duluth to here in Green Bay is way more than 140 miles - in fact, it is 245 on my map which is pretty close to the "231" part of the number...
so that would make "140" as the heading??? I can see that. We are SE of Duluth.
but in the next number I don't understand. The next waypoint after my example was ECK which is Peck, Michigan - and that is about 280 miles straight from here which is close enough to the "288" part of the number. But "082"??? On the map Peck seems to be southeast/east of here, not an 82 degree heading. 82 is just slightly north of due east.
bruce
bond007
Thu May 26, 2005 1:16 am
It is VOR, Radial, Distance and defines a waypoint.
You are getting mixed up with Radial and Heading, and also GRB288082 is specifying a location (waypoint), not that you should be 'flying' the 288 radial for 82 miles.
So...this waypoint is (as already correctly mentioned), a point on GRB 288 degree radial, 82 nm out.
Remember, not that it is relevant in this case, but if you are actually tracking the 288 degree radial inbound, you are heading 108 degrees!
Jimbo
[Edited 2005-05-25 18:20:09]
Lemmy
Thu May 26, 2005 1:20 am
Obliquely related question about STARs:
Let's say I'm filing a flight plan from BOS to JFK, and I'm going to fly the Kennebunk 4 arrival into Kennedy. The problem is that the beginning of this STAR is 90 miles in the opposite direction from my departure point.
I'm assuming that I can jump into the STAR at some intermediate point (PVD, perhaps). If so, how do I notate that in a flight plan?
I am a patient boy ...
OPNLguy
Thu May 26, 2005 1:28 am
No.
"DLH231140..GRB288082" is direct from one point-in-space to another point-in-space.
The first point is 140NM (not SM) from Duluth on their 231 degree radial.
The second point is 82NM (not SM) from Green Bay on their 288 degree radial.
...is immaterial, since you're not measuring the distance from DLH-GRB, just two points that -reference- both DLH and GRB.
Example: ABC and XYZ are exactly 200NM apart, ABC on the west, XYZ on the east. If your flight plan overflies them using a segment identified as ABC270050..XYZ090050, the difference between those two points-in-space is -300NM-
Bruce
Thu May 26, 2005 2:13 am
Ahhhh that makes more sense, now if I extend the line made by connecting those 2 points it is basically right over Peck (ECK) which is the next waypoint.... very interesting stuff.
bruce
Woodreau
Thu May 26, 2005 2:29 am
Quoting Lemmy (Reply 8):
You probably aren't going to use the Kennebunk STAR as it's probably meant to be used for flights coming from over the North Atlantic. There is a notation on the Kennebunk arrival that inertial navigation equipment is required.
Instead for a flight that short, if you filed IFR, you'd use the TEC (tower enroute control) routes or you would use the low-altitude preferred routes.
I don't have an Northeast AFD handy, the TEC and preferred routes are in there.
[Edited 2005-05-25 19:33:53]
Goldenshield
Thu May 26, 2005 4:03 am
After doing some research, I've found what they want you to file.
BOS LUCOS SEY067 SEY PARCH CCC ROBER JFK
Now, whether or not this is a TEC route, I can't tell, as there is no TEC assignment to it.
Lemmy
Thu May 26, 2005 5:04 am
Quoting Goldenshield (Reply 12):
That makes more sense. I've never looked through the AFD, but I'll find one and check it out.
Thanks for the info!
ZID
Fri May 27, 2005 1:25 am
To clarify OPNLguy's dot explanation somewhat. He is right about two dots between similar elements and one dot between dissimilar elements. But the two types of data connected by dots are any and all fixes (where you're going to or coming from - airport, VOR, waypoint, radial/DME fix, or an intersection) and any and all routes (how you're getting there - airways or radials). Of course if you're going direct then there is no "route" per se, so you'd just have you're two fixes separated by two dots.
So not only would you need two dots between two NAVAIDS or two airways but also between a NAVAID and an intersection, or between a radial/DME fix and any waypoint, or between an airway and a VOR radial. You would also just need one dot between an intersection and an airway, or between a radial/DME fix and a radial.
Examples:
SDF..IIU.V4.HYK..VXV.MACEY2.ATL
Louisville International Airport (FIX) .. Louisville VORTAC (FIX) . Victor 4 (ROUTE) . Lexington VORTAC (FIX) .. Volunteer VORTAC (FIX) . MACEY2 Arrival (ROUTE) . Atlanta Hartsfield/Jackson International Airport (FIX)
LEX..HYK.HYK190..V310.LOZ.V97.WEEDY..VXV330015.VXV330.VXV..TYS
Lexington Bluegrass Airport (FIX) .. Lexington VORTAC (FIX) . Lexington 190 degree radial (ROUTE) .. Victor 310 (ROUTE) . London VORTAC (FIX) . Victor 97 (ROUTE) . WEEDY Intersection (FIX) .. Volunteer VORTAC 330 Radial 15 DME Fix (FIX) . Volunteer VORTAC 330 Radial (ROUTE) . Volunteer VORTAC (FIX) .. Knoxville McGee Tyson Airport (FIX)
I'm not joking! This is my job!
OPNLguy
Fri May 27, 2005 6:19 am
ZID, you are, of course, correct. For some reason, I didn't list any examples of dissimilar dot use, other than the SID/DP and STAR examples...
Thanks for clarifying...
Users browsing this forum: Flow2706, parapente, Starlionblue, zeeth and 5 guests
