visionfusion
777 Take-off - At What Altitude Can I 'relax'?
Tue Apr 26, 2005 9:56 am
hello,
I am very afraid at take-off, despite being a frequent flier. When I fly I try to sit in the same seat/row so the sounds are similar between flights on the same a/c type and I watch the flight progress screens intently on take off.
I'm looking for some tech information that might help me intellectually process my fear...
I have always wondered at what altitude after take off does one pass the 'critical' phase of climb? I suppose I'm asking - at what altitude can the pilot viably turn the a/c around to land if necessary? (assuming they don't go on to the next airport they can land at). Can a heavy jet like a 777 'glide' and if so, at what altitude does this become possible/useful?
Sorry if these are silly questions or if they've been asked before - I've looked, but didn't find any answers so far.
Thank you!
Yikes!
RE: 777 Take-off - At What Altitude Can I 'relax'?
Tue Apr 26, 2005 10:12 am
Quoting Visionfusion (Thread starter):
Hiya Visionfusion: Great Handle! Are you in the cinematic arts? Or is that just another name for tunnel vision? ha ha...just kidding.
The FAA "end of second segment climb" is a minimum of 400 feet above ground level. That is about 15 seconds from when the main wheels leave the ground. It is the mandated height above which the takeoff becomes less critical. Airliners reach this height with their pilots trained to the Max in abnormal circumstances including but not limited to an engine failure, an onboard fire, or a controllability issue (i.e. deployed thrust reverser).
So if you need to be "white knuckled", this is the time. 15 seconds after liftoff from terra firma.
If it's any help, pilots don't get their qualification unless they are able to recover from scenarios like this on a 6 month periodic basis in an FAA or equivalent approved simulator.
Hope that eases the pain...
ArmitageShanks
Tue Apr 26, 2005 10:13 am
The pilot can always turn the aircraft around to land, no matter what stage of flight it's in. You might have to dump some fuel first, but an emergency landing is always an option.
However, I would think the very critical climb would be over a minute or two after takeoff. After that I would think it would not be that much of an issue if a "normal" problem occurred (engine out, pressurize problem, etc).
Pilots are trained to handle problems when they arise and can handle just about anything during any part of the flight.
lowrider
Tue Apr 26, 2005 10:49 am
At rotation. Once you hit rotation, you will know for certain that you are going flying. The possibility of an engine failure has been planned for in the aircraft design and the takeoff planning. At rotation, you will know that the aircraft has suffucient performance to clear obstacles. Maybe not by much, but there will be clearence. In the unlikely event of a dual engine failure, most transport catagory aircraft glide fairly well. Anything that generates lift will also glide. The distance available to glide is a primarily a function of altitude, with other factors such as weight, wind, airspeed, and technique also playing roles. If you think a dual engine failure is a likely possibility for your flight, then go buy a lottery ticket. The odds of your aircraft suffering a dual engine failure in a possition where no safe landing is possible are probably about the same as being stuck and killed by a meteor.
Proud OOTSK member
TheBigOne
Tue Apr 26, 2005 11:43 am
Hi VisionFusion - someone gave me this advice once about flying, and it always helps me relax.
If you think you need to worry - relax all is well.
If you think your going to die - the pilots are well in control of the situation.
If you can't think of anything except your nearest and dearest - start worrying!
Hope that helps you!
Reach for the stars - they are closer than you think!
DfwRevolution
Tue Apr 26, 2005 12:35 pm
If a 777 loses all power at cruise altitude, it can glide for many miles. An A330-200 once lost all engine power over the Atlantic and was able to glide to a nearby airport and land successfuly. Note that the probability for such an event on an ETOPS 777 is statistically impossible within our lifetime...
But if it *did* happen, a 777 at cruise would average about glide about 20 ft forwad for every 1ft in altitude it lost. This translates to about 100 usable miles....
http://www.boeing.com/commercial/safety/flash.html
Remember that modern aircraft have *in-frickin-credible* safety standards and statistics. Not a single 777 has been lost in-service and the airplane is nearly a decade old. Ditto for such airplanes as the A330, A340, and 737NG.
HaveBlue
Tue Apr 26, 2005 1:46 pm
Just a small clarification... the A-330 didn't glide to a 'nearby' airport, but rather one over 100 miles away.
And ArmitageShanks, I think it is a bit misleading to say that pilots 'can turn an aircraft around to land at any stage of flight'. There would have to be a very sufficient altitude for an airliner to have the luxury of turning back towards the airport if something happened right after take off.
I don't have the magic number Vision on when you should feel relaxed, but the higher you are the more options the pilot has at his disposal. By 10,000' you are pretty golden imo.
[Edited 2005-04-26 06:51:07]
Here Here for Severe Clear!
727EMflyer
Tue Apr 26, 2005 3:57 pm
Quoting HaveBlue (Reply 6):
Visionfusion,
Welcome to A.net! Hopefully we can come together and help you allevieate some of your fear.
As HaveBlue said, you can't really turn around. If there is a problem (100% engine failure) immedieately after take off that warrants landing it is near impossible for the pilots, no matter how skilled, to get the plane back down on the runway they just lifted off from, and trying to would likely be more detrimental than if the pilot just flew straight. That is exactly what your flight crew would do, continue on and set the plane down on the most likely piece of real estate in front of you. Pilots are taught from day one to start looking for an emergency landing site, and there are more ideal places out there than you might imagine! And as others have said, the government regulations and airline industry standards have so many checks built in that should trouble arise it will be spotted early enough that no harm will come to anyone. Next time your flight is delayed due to a burnt out light bulb in the cockpit you can rejoice! That light bulb probably illuminates an indication that will keep you safe and the crew will never chance not KNOWING that you will be safe.
Now that I've rambled, how about a suggestion that can conquer your fear for good! It will take a lot of courage from you, but go visit your local flight school and ask for an introductory flight. It costs very little, is fairly quick, and can be a real eye opener. Tell ask for an instructor who is accustomed to dealing with folks who are a little unsure. You will see the airplane, see how everything works, sit in the pilot's seat and best of all, you will make the airplane take off. It can be an eye opener that will set you at ease when you see how easy it really is. But make sure it is something you can handle before you try.
Good luck and happy flying!
buckfifty
Tue Apr 26, 2005 8:11 pm
Nowadays, unless if you're flying a single, chances are, most airliners will be able to continue a takeoff past V1 with a failed engine, climb, dump fuel, and turn back. No such thing as a golden altitude involved.
However, failures occur in a variety of ways at different altitudes, with different survivability rates. I agree with Yikes' assessment on this matter. As long as you can get airborne past V2, things generally are a lot easier to deal with.
Kay
Tue Apr 26, 2005 8:31 pm
I am glad to see the correction of the last posters regarding turning around and landing. When low in altitude, on failure of all the engines, turning around is never an option.
Regarding airliners (the original question), there is no real danger since none are single engine aircraft (or light piston twins). That is where turning around *is* possible. If one engine fails after a specific speed in the take-off roll, take-off will be continued, sufficient climb will theoretically be possible, followed by dumping fuel and coming back. In real life, this has happened many times and the success rate is probably more than 75%, with the exception being hot airfields in disadvantageous conditions (I think of a 737 on one engine that had to do an unsuccessful ditching when back on downwind, a few years ago).
However, in General Aviation, things are different, and I consider the biggest overlooked threat to pilots to be the danger of an engine failure after take-off.
As opposed to many many other scenarios, an engine failure on climb-out leaves the best pilot with no options. If it happens at less than a comfortable altitude (perhaps 400~500 feet?) any attempt to turn the aircraft back will end up in a spin and crash because of the loss of altitude related to turning without power. The only possibility is to steer the aircraft a maximum of 15degrees either left or right, towards the emergency landing site of choice...
As I read once: "after taking off, be amazed that the engine did not fail".
But all this is about single-engine aircraft (and probably light piston twins, where the possibility of flying one engine is many times purely hypothetical).
Regarding the original question: there is almost nothing to worry about.
The best way to master the fear of flying is to do a PPL. Just focus your enthusiasm for aviation into the best investment you will ever do in your life.
Kay
futureuapilot
Tue Apr 26, 2005 8:45 pm
Hey Visionfusion, whelcome to Airliners.net
First off, I was scared of flying when I was littler, and Takeoff scared me the most of all. After joining A.net I talked to some people here and they helped me get to the source of my fears. At takeoff, the reason it makes people nervious is because their enviorment around them has changed: it is suddenly louder, your moving faster, the aircraft may shudder and vibrate, but that's no different than driving your car down the highway at 60mph as opposed to 25mph. One of the facts I learned was this: Immagine that you were crusin down the highway, at a high speed, and a child ran accross the road. You would slam on the breaks and probably swerve off the road. It could turn out to be a serious accident. Now imagine what would happen if you had the ability to practice everything beforehand. Multiple times. You would be able to control the vehicle and know exactly how to react. Now immagine if you had to do that every year perfect or you would loose your drivers licence. This is what pilots do, if they can't do it right, then they don't fly at all. Any situation and obsticle they have had practice for. Hope this helps!!!
-Sam
The Pilot is the highest form of life on Earth!
visionfusion
Wed Apr 27, 2005 2:47 am
You guys (and gals) are fantastic - what a great group - thank you so much!
Looking at the variety of great comments, it looks like there's no golden rule, but that makes sense - it's like it gets better the further/higher you go without problems. Would it be something like this for loss of engine power?
V1 - okay if your pilot aborts promptly
VR - not good
V2 - very bad news indeed if you're under 400ft (before about 15 seconds from lift-off)
1000ft+ altitude looking better all the time the higher you get
10,000ft+ - enough altitude for more viable options.
My next related question to all this is:
V2 - what kind of speed range is that for a 777?
I know this will depend on the weight, but it would be good to know the ballpark - speed is one of the things I look at anxiously on the monitors during take off - terrified that the speed will start to drop while climbing...
I'm flying tomorrow on a 777 out of LGW, it's a trip I do many times a year, but it never gets easier until we're level, the seatbelt sign is off and I can see the clouds beneath us!
Thanks again everyone - and stand by for some really silly landing questions at some point soon  Smile
Visionfusion
Wed Apr 27, 2005 3:01 am
Quoting Visionfusion (Reply 11):
VR - not good
The worst time for engine failure is anytime between V1 and 400ft. But I wouldn't call it "very bad news indeed" unless the wing was also on fire or something. If there is something pilots are trained to do, it's handling engine failures on takeoff. Remember that quite a few of the systems redundancies and handling procedures are aimed at minimizing risk in this phase.
Note that even an emergency event before V1 may not warrant emergency braking. Typically, if anything untoward should happen under 80 knots, the pilots will stop the takeoff. Between 80 knots and V1, they will only stop for engine failure, fire and a couple of other things. Braking when above 80 knots has dangers in itself. Not critical, but it's still usually less dangerous to continue the takeoff. Above V1, you only want to stop if you have serious doubts the plane will fly, knowing that the aircraft may run out of runway, not to mention set the wheels on fire. I say "may" because the numbers are always quite conservative and have at least a 33% fudge factor.
I fly several times a week and used to be a bit of a white knuckle flyer (not anymore) so I know exactly how you feel. What helped me back in those days was telling an F/A that I was a bit of a nervous flier and asking if the pilots had time to say hi for a very short visit. On long haul, a 15-30 second visit to the cockpit can normally be squeezed in. Calmed me right down. You don't even have to talk about fear of flying. Just ask them which way we're flying out, what kind of speed rotation is at today, etc... Knowing that they have full control, and being aware of which direction the first turn is likely to be, gave me back the illusion of control. Just knowing what they looked like made me confident.
Have fun on your next flight!
Barring that, there's always alcohol  Wink
EMBQA
Wed Apr 27, 2005 3:19 am
..the second you lock your car and walk into the terminal..!!! You are thousands of times more likely to be in an accident while driving to the airport then you are in any stage of flight. Period and of story..facts back this up.
RaginMav
Wed Apr 27, 2005 3:48 am
I read a great article in Business and Commercial Aviation a couple weeks ago regarding High-Speed Rejected Take-offs. I don't recall the percentages, but in business jets a large portion of RTO's were actually caused by traffic conflicts on the runway, as opposed to the engine failures that the pilots train for (I think it was a study of reports in the ASRS database). I would assume a similar percentage for airlines, as they largely use the same airports as the business jets.
And yes I agree with the 80 knot rule. Is anyone familiar with the Hawker 800? I was told that RTO above 80 kts in that aircraft means a mandatory brake inspection!
Quoting 727EMflyer (Reply 7):
What about the L-1011 in New York (JFK??) that was off the ground, told he was on fire and put it back down on the runway? I can't remember the details, anyone else know details?
I think the most comforting thing about riding in the 777 is the obvious experience of the crew. Last week I took (and passed!) my private pilot check ride (YIPEE!!!!!). The examiner: a UA 777 First Officer. This guy is the definition of professional pilot, as far as I'm concerned. He knows his stuff up down left and right (obviously), as do all pilots at that level!
XFSUgimpLB41X
Wed Apr 27, 2005 4:59 am
VR - not good
The above is 100% incorrect actually
After V1 we are commited to takeoff. You don't abort after V1 unless you like visiting gas stations across the street a la Southwest (that wasn't an abort..but you get the idea). The airplane is guaranteed to be able to accelerate and climb out with required obstacle clearance with an engine failure after V1.
In othe words... in a jet... an engine out really isn't a big deal. She climbs a bit slower (it actually slows things down to a bit less of a mind numbing rate haha)... and you're gonna be making an early visit back to the airport (no fuel dumping in the CRJ.. just go through the checklist and land).
I'll put it this way...we can actually have a thrust reverser deploy at V1 and continue with required climb performance.
Chicks dig winglets.
flyf15
Wed Apr 27, 2005 5:05 am
Unless you look out your window and see something like those Air France Concorde passengers saw...I wouldn't worry about it too much.
AirWillie6475
Wed Apr 27, 2005 7:15 am
Takeoff is the easiest part for the pilots but for the passengers it is the worst part. On the other hand landing is the best part for passengers but it is the hardest for pilots. As long as you are in the air you can control the plane. The most difficult circumstance is engine blowing after you have to takeoff but you are still on the ground. Depending on the condition it might be hard for the pilots to recover on take-off. Chances of all these elements occuring at the same exact time are low so enjoy the flight.
zotan
Wed Apr 27, 2005 2:00 pm
Always remember that the plane is designed to fly, its wants to stay off the ground. A quick talk to the pilots up front before the flight can do wonders also. Asking if you will first turn left or right can really help out. I used to be a nervous flyer, and one thing that really helped was talking to the pilots before the flight.
flymia
Thu Apr 28, 2005 10:17 am
Remember the chances of dual engine loss must be atleast 1,000,000,000 to 1. A single engine failure is not a major problem. Before V1 pilots abort. After V1 pilots fly and than land. After around um lets say 5,000ft you should calm down.
Also when you start hearing the engines clam down a little. Thats when I know everything is going good.
Msl747
Thu Apr 28, 2005 11:21 am
From Boeing:
U.S. traffic accident fatalities in 2000: 41,800
Commercial airplane fatalities in 2000: 878
Look, the chances of anything going wrong are astronomically high, and even *if* something should happen, the pilots are incredibly well trained, and the aircraft is put through extreme testing before it is even allowed to fly. So sit back, relax, and enjoy your flight! airplane  bigthumbsup
-Msl747
Commercial Pilot Certificate: Single and Multi-Engine Land; Instrument Airplane
TimT
Thu Apr 28, 2005 3:47 pm
Just listen for the sounds and feel of the landing gear retracting- at that point the aircraft has established a positive rate of climb. Personally, after the door is shut I seem to always fall asleep.
jwenting
Thu Apr 28, 2005 5:34 pm
Why worry? If anything happens there's nothing you can do about it anyway.
There's highly trained professionals up front who have years of training and experience between them including every scenario that ever happened or someone could dream up as possibly happening at some point in the future.
I wish I were flying
Thu Apr 28, 2005 6:44 pm
It's funny how many here quote stats and safety records. If you've been a white-knuckle flier, you will know this may help, or it may not. Having a lot of knowledge frequently makes the situation worse. It's not logical.
Quoting XFSUgimpLB41X (Reply 15):
Well, if all engines fail after V1 you will probably brake in any case  Wink
chazzerguy
Thu Apr 28, 2005 9:57 pm
Quoting Lowrider (Reply 3):
I'm no aviation expert or engineer, but I don't think you are neccessarily "in the clear" once you rotate... The Chicago DC-10 that crashed managed to rotate and get airborne, only to crash moments later... The MK 747F that crashed up in Canada late last year managed to rotate, but did not get significantly airborne, if at all... The NWA DC-9 that crashed in Detroit after the flight crew forgot to set flaps managed to rotate, but only got a few feet off the ground... But perhaps I am misinterpretting what you are saying.
Visionfusion, my wife is petrified of flying and you can ply her with all the stats and probabilities in the world, and it makes no difference... So I think I know where you are coming from... But I believe statistically speaking the overwhelming majority of accidents occur either on airport property or within a very few miles of airport property... So in my layman's mind I would say once you are 30 seconds off the ground, you are statistically very unlikely to crash.
Kay
Thu Apr 28, 2005 10:09 pm
I once thought take-offs are more scary than landings as well, because as someone mentioned before, there is a big change in the environment.
The only solution is becoming comfortable in the air, becoming comfortable with bouncing around, being comfortable with the idea that just a few feet below your legs is emptiness for many many miles (unlike your car, your house etc etc), comfortable with the sounds, turbulence etc.
some people are like that at birth but for those who aren't, short of PPL, the only solution is knowing how everything works. I often advised my brother to take the ground school classes of the PPL. when you learn how everything works in so much detail, at least your mind will know what's going on at every stage. But your body will still be scared though.
I did a PPL. bouncing around is second nature, zero-Gs with a full stomach, sliding the plane, climbing hard, descending stalls and even spinning once, all these slowly enter under your skin (requires many hours), but once they do, nothing will scare you.
Kay
lowrider
Thu Apr 28, 2005 11:48 pm
Quoting Chazzerguy (Reply 24):
The DC10 did fly, but I submit that that they would have probably crashed from almost any altitude. So in the case of that aircraft, there was no "safe" altitude. I don't know that the final report on the Mark Air flight is out yet, but I have been told that a contributing factor was an incorrect flap setting.
To get back to the original question, which asked about a "critical altitude", I stand by my answer. Once the aircraft rotates, you, as pax, know it has passed V1 and will continue, regardless of engine fire, failure, or system malfunction. All other things being equal (i.e. properly set flaps, not losing large pieces of the airplane) the aircraft has sufficient performance to climb, clear obstacles and return to the airport of departure or takeoff alternate once passing V1. The fact that the examples you brought up span over 35 years demonstrates the rarity of these catastophic failure cases.
Proud OOTSK member
Fri Apr 29, 2005 2:13 am
Quoting Lowrider (Reply 26):
This is not so. The DC-10 accident at ORD was quite survivable, but the plane was damned by the absence of slat retraction sensors (yes, among other things). When the engine sheared off, it took with it the hydraulic lines for the slats. Without pressure, the slats retracted, increasing the stall speed for that wing. This would have been ok had the pilots known about it, but the sensor feeds were also cut so... In the end, the pilots did everything by the book, but their climbout speed was calculated based on the dirty wing in takeoff config. With a higher stall speed, the damaged wing stalled, the plane rolled towards it and became unrecoverable.
And now we're being really nice to our white-knuckled thread starter Big grin
Jetlagged
Fri Apr 29, 2005 6:26 am
I'd say once the flaps are retracted and the aircraft starts to accelerate you can be sure nothing has gone wrong and relax. However, I'd recommend relaxing beforehand takeoff and visualising a safe flight and arrival.
V2 is not a milestone to worry about. It is the engine out takeoff safety speed, and may well be achieved before the aircraft is truly airborne. V2+10 is the initial target climb speed, but you would reduce speed to V2 if an engine failed.
Single failures do not usually lead to accidents. It's an unfortunate combination of failures and circumstances that sometimes does. The Chicago DC-10 is a good example, as is the Paris Concorde and the Kegworth 737-400. Reading about such accidents might help you realise just how unlikely they are.
Learn to enjoy the sensations of takeoff, like the surge of acceleration and then the rapid climb out. Look out of the window and watch the ground disappear beneath you, rather than stare at the seat back video and worry.
Fri Apr 29, 2005 12:46 pm
With Todays Aircraft build to have Backups systems,The probability of something going wrong & not tackable is very rare.
Enjoy the ride.
regds
MEL
mirrodie
Fri Apr 29, 2005 11:38 pm
One of the Av magazines that I read shows a monthly report of recent accidents. Most of the underlying cuases of these accidents are invariably pilot error.
Now, I understand that CRM is used to curtail pilot error in cockpit decisions. What else is used to ensue the pilot error does not occur?
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
Sat Apr 30, 2005 12:57 am
Quoting Mirrodie (Reply 30):
Training, training, training and more training. And then some more training. It's quite spectacular what kind of weird emergencies pilots train for (and train and train and train).
Past accidents are also studied in depth, and there's of course the psych exam and flight physical.
BTW am I the only one who always read the safety card, pays at least vague attention to the briefing, and never takes his shoes off before flap retraction?
Jetlagged
Sat Apr 30, 2005 1:01 am
Training, training and then some more training. Where pilot error is a factor, the reason why and the correct action needs to be taught during recurrent simulator sessions and by standards set by the senior pilots within each airline.
This is a bit of a generalisation. However it is true that as aircraft have become much safer by design, the Mark 1 human pilot has not really evolved much, so the proportion of accidents due in part to pilot error has increased. CFIT is the current hot topic which EGPWS is supposed to reduce. In the end good airmanship is the key, but under extreme stress anyone can make a wrong or ill-informed decision, or just simply be unlucky.
It's rare that pilot error is the sole cause of an accident, but airlines and their lawyers like it as usually the person blamed is unable to answer back.
Pope
Sat Apr 30, 2005 3:11 am
Remember this, any time after you hit V1, the airplane has enough power to take off even if the engine failed at that moment. That implies that on a twin, you've got a 100% reducancy factor.
Hypocrisy. It's the new black for liberals.
C133
Sat Apr 30, 2005 7:31 am
Quoting Pope (Reply 33):
Every transport aircraft is certificated to stop within the remaining runway from any speed at or below V1 and to complete take-off successfully with an engine failure at V1 or above.
Fine: Tax for doing wrong. Tax: Fine for doing well.
AsstChiefMark
Sat Apr 30, 2005 10:40 am
Quoting Jetlagged (Reply 28):
That's what I go by. I watch the slats, too.
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
jake056
Mon May 02, 2005 5:26 am
I am a nervous flyer, no doubt about it. Best experience I ever had was in a prop regional plane. I don't remember the name of the airline or the a/c. It was a long time ago. Flight was from Charlottesville, VA to Pittsburgh, PA. The plane carried maybe 20 pax. 2 single row of seats down the aisle.
Anyway, the pilots left the door open to the cockpit and just seeing them "being normal" gave me tremendous confidence even though we had a lot of turbulence. I kept thinking it must be ok, because they didn't seem worried.
I still mentally think of that whenever I fly and try to relax.
jwenting
Mon May 02, 2005 5:31 am
I've survived Aeroflot and before that a crash landing (OK. so it was a glider), what is left to be nervous about?
CRJ200Mechanic
Mon May 02, 2005 5:38 pm
I used to be terrified to fly. You know what I did. I became a mechanic. Now I understand them more, so when I hear noises, I usually know what it is. Flying doesn't bother me a bit anymore. I enjoy it now. I had to fly to JFK for business purposes about two weeks ago and was riding an American 757. I heard a few things I didn't recognize, but I didn't care. I was riding in first class for my first time. I was enjoying my Miller Lite and frosted flakes at 8 in the morning.
Always remember the responsibilies you hold with an A&P license
Mon May 02, 2005 6:45 pm
Quoting CRJ200Mechanic (Reply 40):
Like what.
regds
MEL
CRJ200Mechanic
Mon May 02, 2005 6:53 pm
Quoting HAWK21M (Reply 41):
Like what.
It was a thump noise under me feet right after rotation. I was sitting in 6E first class on a 738
9VSRH
Mon May 02, 2005 6:59 pm
135-150 knots (not sure MPH or KMPH)
Mon May 02, 2005 10:23 pm
Don't the flakes get soggy when you pour Miller on them?
Woodreau
Tue May 03, 2005 12:22 am
Quoting 9VSRH (Reply 43):
It's neither...  Smile a knot is 1 nautical mile per hour, so its not MPH or km/h.
Tue May 03, 2005 12:26 am
Quoting Woodreau (Reply 45):
If I remember this correctly:
- The nautical mile is related to degrees of arc.
- The statute mile derives (a long time ago) from the milia passum (1000 strides) measurement the legions used.
- The kilometer is 1/10000th of the distance between the north pole and the equator along the Paris meridian.
Convert here: http://www.onlineconversion.com/length_all.htm
[Edited 2005-05-02 17:26:46]
XFSUgimpLB41X
Tue May 03, 2005 9:04 am
1 knot is 1.15 statute miles per hour.
CRJ200Mechanic
Tue May 03, 2005 4:32 pm
Quoting Starlionblue (Reply 44):
I didn't pour them into the frosted flakes, I still used milk. I just enjoyed the miller on the side
Jetlagged
Wed May 04, 2005 11:19 am
Quoting Starlionblue (Reply 46):
A nautical mile is equivalent to 1 minute of latitude at the earth's surface. So there are 60 nautical miles for every degree of latitude. Traditionally a nautical mile was 6080 feet.
Wed May 04, 2005 5:59 pm
Quoting CRJ200Mechanic (Reply 48):
You use Sugared Flakes or Plain  Smile
regds
MEL
CRJ200Mechanic
Wed May 04, 2005 6:06 pm
Quoting HAWK21M (Reply 50):
Sugared Flakes
They were frosted
Users browsing this forum: Afstand, StereoTechque and 1 guest
