JAGflyer
How Many T/R On The A380
Thu Apr 28, 2005 9:06 pm
From all the pics I have seen they only have or use the inboard thrust reversers (engine 2 and 3). Does the A380 only have them on those engines or did they just use the inboards in all those photos?
Support the beer and soda can industry, your recycle old airplanes!
ZBBbird
RE: How Many T/R On The A380
Thu Apr 28, 2005 9:32 pm
As far as I know they only have thrust reverse on the inboard engines. The reason being that with the A380's large wingspan their would be more danger of the outboard engines ingesting FOD as they would be at the edge or over the edge of the runway.
sabenapilot
Fri Apr 29, 2005 12:42 am
Just before you ask:
Reversers are not taken into account is the calculation of the stopping distance of a plane. On modern planes, the pilots simply select a deceleration rate of the plane upon landing and an automatic system does the rest. Should they decide to use some T/R, all that would do is to put less braking force on the brakes, but the plane would not stop on a shorter distance.
FDXmech
Fri Apr 29, 2005 1:48 am
Quoting Sabenapilot (Reply 2):
Not because thrust reversers provide a negligable slowing force rather these calculations are based on only basic equipment -brakes. And not based on new brakes able to absorb lots of kinetic energy but worn down to the limits.
The T/R's when using auto-brakes are an added component used to reach a desired deceleration rate. Not a good criteria to say T/R's don't affect stopping dx.
What about without auto-brakes, OFF?
What about on wet runways?
Though thrust reversers aren't used in determining stopping distance, the plane can't be dispatched with more than one inop.
If the A380 only has two T/R's, it was to address a weight problem.
And that's fine with me. Two less T/R's to break.
[Edited 2005-04-28 18:55:04]
Fri Apr 29, 2005 2:07 am
Quoting FDXMECH (Reply 3):
Really, for the FOD problem as well.
MrChips
Fri Apr 29, 2005 3:17 am
Not only that, but consider the noise issue. Many of the airports the A380 will operate out of, such as LHR, have severe noise restrictions and quotas, meaning that many operators choose to forego the use of reverse thrust anyways.
Time...to un-pimp...ze auto!
MERSPACE
Fri Apr 29, 2005 5:41 am
Can the A380 make use of a single T/R, or is there an asymetry issue with
only one T/R --Engine thrust so far from centerline ?
MERSPACE
FDXmech
Fri Apr 29, 2005 7:52 am
Quoting MrChips (Reply 5):
I sincerely doubt it. If noise is that large an issue at certain airports, then simply don't use reverse thrust.
I believe leaving off two T/R's is simply a weight savings issue. Anything else is a public relations ploy. Spin if you will.
I don't see or hear many foreign operators negate the use of reverse thrust here at EWR.
MrChips
Fri Apr 29, 2005 9:53 am
How is what I said "spin"?
I was simply stating that many airports that the A380 may operate out of have severe noise restrictions...much more strict than any airport here in North America.
Therefore, if its not going to be used, or is restricted in use, why include it in the airplane?
I think what happened here is a "cause-effect" situation...I had a potential cause, and FDXMECH another congruent cause as well:
Cause - noise restrictions, ever-pressing need to save weight,
Effect - delete T/R from engines #1 and #4.
I can imagine that deleting the reversers goes a ways to reduce complexity as well.
Fri Apr 29, 2005 12:44 pm
Quoting FDXMECH (Reply 7):
I think its mainly an FOD prevention Issue,due to Wing span of the A380.
regds
MEL
FDXmech
Fri Apr 29, 2005 8:55 pm
MrChips;
In no way do I consider your suggestion, "spin". I apologize if you thought as much.
But if Airbus uses that reasoning, than I do consider it spin.
Sat Apr 30, 2005 7:26 pm
Any Pics with the T/Rs deployed.
regds
MEL
Jamie757
Sat Apr 30, 2005 8:45 pm
Surely thrust reversers would reduce the distance taken for a plane to stop?
"I feel like a turkey who's just caught Bernard Matthews grinning at him!"
air2gxs
Sat Apr 30, 2005 8:55 pm
Quoting Jamie757 (Reply 12):
If the auto-brake system is not used, the reversers will aid in slowing the aircraft and decrease stopping distance. If auto-brakes are used, the stopping distance will not change. The deceleration rate is set by the flight crew and maintained by the computer. Any added effect from the thrust reversers would be added to the equation and the braking action from the brakes would be reduced. Thus, stopping distance is un-affected by the reversers.
Jamie757
Sat Apr 30, 2005 9:15 pm
Quoting Air2gxs (Reply 13):
I understand now, thanks for the simpletons guide!! Lol  blush
Jetlagged
Sat Apr 30, 2005 10:19 pm
There is an exception to this, where the autobrake has a MAX position. In that case the brakes will be applied fully, with no demanded deceleration rate. Thrust reverse in this case will reduce stopping distance.
FDXmech
Sat Apr 30, 2005 10:36 pm
This according to Airbus.com.
_________________________________________________________________
Environmental Friendliness
The A380 will help cope with growing passenger numbers without negatively impacting the environment, thanks to significantly reduced noise and emission levels. In spite of its higher weight and thrust requirements, the A380 will make less noise than its closest competitor, while carrying 30 to 50 per cent more people. Current noise certification rules (ICAO "chapter 3") will be met by significant margins and the A380 will be compliant with the strictest local noise regulations, classified QC2 for departure from London's busy airports and QC1 for arrival.
For ground operations, the A380 can taxi with only two engines if required, will use only two thrust reversers and will employ a low-noise auxiliary power unit to help eliminate any noise concern.
Putting a pleasant face on weight reduction.
fergulmcc
Tue Nov 15, 2005 10:19 pm
Quoting HAWK21M (Reply 11):
Here is one,
Photo © QIU CHENG
Take care
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
Tue Nov 15, 2005 11:16 pm
Quoting Fergulmcc (Reply 17):
Here is one,
Wow.Old thread.Any Offical data on the T/Rs
Thanks.
regds
MEL
Sun Nov 20, 2005 3:09 pm
If autobrakes are used maximally yes, but reversers can still not be used for the calculated stopping distance. That is, they are a bonus, but your calculations have to assume they don't exist.
474218
Mon Nov 21, 2005 1:12 am
Quoting Jetlagged (Reply 15):
What about anti-skid system it has to be taken into consideration?
Quoting ZBBbird (Reply 1):
So you must have at least two different spare engines, 1 inboard and 1 outboard, another added expense to an all ready expensive aircraft.
Mon Nov 21, 2005 10:45 am
Quoting 474218 (Reply 20):
Not really. Most of the components of the engine are identical. It's only some parts of the bypass duct that change.
OldAeroGuy
Mon Nov 21, 2005 5:46 pm
Quoting Starlionblue (Reply 19):
On icy runways, most pilots are happy to have all the reverse thrust they can get.
Mon Nov 21, 2005 7:23 pm
Quoting OldAeroGuy (Reply 22):
I get that, but you can't really "count" on them in your calculations. This doesn't mean they won't be used of course  Wink
Pihero
Tue Nov 22, 2005 12:27 am
We seem to forget the A-380 dimensions, here.
To put things into perspective, the centreline of the outer engines are some 52 meters apart. That means that with the engines' diameter slightly less than four meters, each outer engine hangs only two meters inside the width of a 60 m runway. As the 744 manual states that at take-off power, the suction volume extends more than 35 feet around the engine, the likelyhood of ingestion appears quite real (I safely assume that the 380 ingestion volume will be a lot greater on 380 engines.)
On the weight question :
FedexMech, I think we need to qualify your observation :With the outer engines hanging that far out on the wing, I would also think that the wing bending relief they bring could mean a lot of weight saving on 1/ the wing structure and 2/- on the wing-to-fuselage attachment. How much compared to a T/R installation, I don't know but with such dimensions, I would bet on a lot.
A totally unconfirmed rumour last year was about AI needing to harden the airplane's structure as the whole airframe was close to a 1hz resonnance frequency, which was prejudicial to the occupants comfort, hence the fattening up of the aircraft. I happen to believe that rumour.
On the necessity of T/Rs :
The debate is wide open. What I can say is that I've seen airplanes dispatched with inoperative reversers -yes, a twin-engined aircraft can be dispatched without T/Rs except on contaminated runway take-offs - and that in Europe, local noise limitations prevent their use outside an emergency.
Let's not also forget that the 380 braking efficiency is greater than a 744's, because 1/-the landing and take-off speeds are much lower and 2/-the braking energy is distributed on a greater number of brakes (20 iso 16).
Just my two cents.
Contrail designer
Boeing Nut
Wed Nov 23, 2005 2:18 am
There was another post on this sometime back and I was certain that the A380 had four reversers. In fact, I was very bullheaded about it. Until that is, I was "handed my ego" when a few member posted not only pics but links that stated that only two exist.
I had a nice merlot with my crow that night.  footinmouth
Turns out, that A.net actually can be educational.
 wave
Tristarsteve
Wed Nov 23, 2005 2:28 am
No, The thrust reversers are in the C (orD) ducts which are part of the airframe. When you change an engine you open the C ducts and lower the engine out between them. They stay behind. This applies to most Wide body jets, except the RB211-524 on the B767 and B747 (and TriStar) where the reverser is part of the engine.
Wed Nov 23, 2005 3:44 am
Just to clarify, the risk of ingestion on the outboards is of course there during takeoff as well, but any ingested turf or other junk would just be blown out the arse of the engine, not potentially bounce against the fuse or wing if it rocketed out of the reverser..
Jetlagged
Wed Nov 23, 2005 3:49 am
Quoting Pihero (Reply 24):
I think that off runway FOD is much more of a problem to the A380 in the takeoff case than in the reverse thrust case, for the reason you give (the suction volume in front of the intake). Airflow and suction is higher at takeoff than in reverse and takeoff thrust is applied at very low speed, whereas reverse thrust would be cancelled by 80 knots or so. Having the engine over the runway edge means some more debris will be thrown up but that doesn't necessarily mean more will be ingested as long as airspeed is high enough. Overall, the weight reduction theory seems a bit more plausible to me.
I would guess most pilots would prefer to have a reverser on each engine. What about a max weight RTO, where one of the inboard engines has failed, especially on a wet runway? With a twin you would have to deal with asymmetric reverse thrust, but on the A380 in addition to thrust asymmetry the outboard engines are still producing significant forward thrust, reducing deceleration.
Were there are any early Airbus concepts showing the A380 (or A3XX) with outboard reversers? That might shed some interesting light on the question.
OldAeroGuy
Wed Nov 23, 2005 6:21 am
Quoting Starlionblue (Reply 23):
No longer true and it never was true for UKCAA regulations.
With the advent of FAR25 Amendt. 98, the FAA and EASA (formerly JAA) now allow the use of reverse thrust for calculating certified takeoff performance on a wet runway.
From a practical standpoint, this helps twins more than quads for takeoff since quads are more frequently limited by factored all engine takeoff distance.
You're right for certified landing performance, but from a practical standpoint, alot of airline operations departments do calculate landing performance on wet, slushy and icy runways taking reverse thrust into account.
The low level of reverse thrust on the A380 may create some interesting real world landing issues on contaminated runways.
474218
Wed Nov 23, 2005 6:46 am
Quoting TristarSteve (Reply 26):
Thanks TristarSteve,
I remember that now, all my engine experience (which is very limited) was on J-58's and RB-211's.
Pihero
Wed Nov 23, 2005 7:28 am
Quoting Jetlagged (Reply 28):
That is an interesting discussion !
Contrail designer
474218
Wed Nov 23, 2005 7:44 am
Quoting Pihero (Reply 31):
No problem, Airbus has said they have triple computer backup on all systems?
Pihero
Wed Nov 23, 2005 8:03 am
So has Boeing.
Then what is your point ?
Contrail designer
474218
Wed Nov 23, 2005 8:55 am
Quoting Pihero (Reply 33):
Is it not Airbus philosophy that there is no problem that three computers can not get you out of, or better yet, not let you get into.
Jetlagged
Wed Nov 23, 2005 8:59 am
Quoting 474218 (Reply 32):
Quoting 474218 (Reply 34):
Any number of computers won't stop an engine failing.
777236ER
Wed Nov 23, 2005 9:18 am
Small point, but generally the MAX autobrake setting still commands a deceleration rate. The maximum braking strength can be achieved using full manual braking, or the RTO setting.
Almost certainly the lack of thrust reversers was because of weight concerns. The FOD issue is real. Someone said the greater suction at t/o power will be more of a FOD hazard than reverse thrust, but that's not really the case. While reversing the bypass air, there's significant disturbance to FOD on the ground, someone of which can be blown forward into the fan. With the engine running at ~60% N1 (say) and with 87% of inlet air reversed, there's a greater FOD potential during reverse.
That being said, it would have been easy to limit the use of outboard engines to wide runways and emergencies.
Jetlagged
Wed Nov 23, 2005 11:34 am
Quoting 777236ER (Reply 36):
The someone was me. The point I was making was that while reverse thrust can certainly kick up FOD, potentially for ingestion, takeoff thrust will also suck it up from the grass, purely due to the suction of the intake air. So if reversers over the runway edge are a problem, so is full thrust at low forward speed. Perhaps I shouldn't have claimed it was more of a problem, but problem it is.
In my view the chances of FOD damage in reverse is no greater on the A380 than any other type, so long as you keep out of the FOD re-ingestion envelope.
Wed Nov 23, 2005 12:47 pm
Quoting Jetlagged (Reply 37):
As I said, if you have FOD during forward thrust, it'll probably just go out the back unless it's something large (planespotter holding camera).
But if you're in reverse, the FOD may end up rocketing out of the reverser and embed itself in something important, like the wing of the fuse or the other engine. Oops.
Wed Nov 23, 2005 5:10 pm
Considering the Angle created by the Deflected Reverse thrust to that by the Suction at the Inlet.I don't think they can be compared.The Reverse Thrust covers a wider angle & hence more prone to FOD.
regds
MEL
Jetlagged
Thu Nov 24, 2005 1:39 pm
Quoting Starlionblue (Reply 38):
Good point, but unless it's something large it won't do much damage, in which case the engine will suffer too.
Jetlagged
Thu Nov 24, 2005 2:11 pm
Not on any Airbus, nor on the 747, at least.
Thu Nov 24, 2005 4:02 pm
Quoting Jetlagged (Reply 41):
Whats the Exception like.
regds
MEL
Users browsing this forum: B737200, Baidu [Spider], David L and 18 guests
