Sul
Engine Start Up Noise
Sun May 01, 2005 11:04 pm
Hello all,
Ive noticed that when some older jet engines are being started (specifically PIA 747-300s!), they rev up with a high pitched noise and then a deep drone starts to happen. Its also apparent at the point where a bit of white smoke is exhausted. There also seems to be hot air coming out the back from the moment the front fan spins. I was under the impression that fuel only goes in once the fan is spinning fast enough, so where does the heat come from?
So my question is what is the deep drone?
and
What is the white smoke?
Cheers.
USAFMXOfficer
RE: Engine Start Up Noise
Mon May 02, 2005 12:11 am
Quoting Sul (Thread starter):
I believe this would be the starter just beginning to come up to speed
This would be the inertia to overcome rotating the core of the engine from a standing start.
Just a guess but I think this would be initial ignition burning off some residual fuel....
Once the engine is rotating at a certain RPM (15% on the old TF33's I used to be engine run qualified on) the ignition sequence starts, so that is when the "hot air" you see coming out. We used to just "motor" an engine without ignition by pulling the ignition circuit breakers and using the starter to motor it---could leak check certain components that way.
44th Fighter Squadron Vampire Bats - 63 years of history
air2gxs
Mon May 02, 2005 12:38 am
How long has the engine been shut-down? What is the ambient temp? Engines do not cool down uniformly. Ambient conditions such as temperature, sunlight and wind factor into how fast the core assumes ambient temperature. You will sometimes see heat distortion on start-up because the core engine has not reached ambient yet. Fuel isn't introduced until N2 (N3 on RR) reaches the appropiate speed, usually between 20% & 25% but max motor is common. Fan speed is not factored into ignition on a normal start.
If you are hearing the drone when the "smoke" appears, you are hearing the start of the combustion process. It's kind of hard to explain, but different types of fuel nozzles and/or injectors produce a different sound when the fuel is accelerated and ignited. The difference is pronounced if you ever listen to a CFM equipped DC8. Engine with fuel nozzles are quiet when they start. Engines with injectors have a deep rumble that you can feel when they start. (Or the opposite, I could never keep it straight.) As the engine increases in speed and the airflow through and around the core increases the sound disappears.
There is debate as to what the white smoke is, some say water vapor, but it is fuel that has not been involved in the combustion process. The fuel is not ignited all at once. There are only 2 ignitors in the combustion chamber. Some engines/airframes only use one at a time. The combustion at the point of ignition is instantaneous and complete (hence no black smoke), but the flame takes a few seconds to propagate around the combustor. The white smoke you see is unburned fuel from that process. I'd wager that the more heat distortion you see out the exhaust at starter rotation, the less fuel vapor you see at light-up. A warm core engine facilitates propagation. Cold weather starts are notorious for fuel vapor out the exhaust.
The high pitched noise is the starter.
sulman
Mon May 02, 2005 1:02 am
This is particularly distinctive on CFM56 engines on the 733 and A320, not just from startup but also when power is set from idle - for a brief moment you do get that raspy groaning sound. I think it's great!
Airplanepics
Mon May 02, 2005 1:23 am
Quoting Sulman (Reply 3):
When you get right next to them, the earth shakes and you get a weird feeling in your chest. I agree. a fantastic experiance!  Silly
Simon - London-Aviation.com
tinpusher007
Mon May 02, 2005 3:58 am
On the MD-88's that I work around, the JT8D's produce an almost muffled explosion sound right at "light off". If inside the terminal, it actually does sound as if something exploded outside....just the engines getting ready to handle business. I love that sound.
"Flying isn't inherently dangerous...but very unforgiving of carelessness, incapacity or neglect."
Goldenshield
Mon May 02, 2005 4:15 am
Tin --
Turboprops sound the same way from the inside, except that once the prop gets up to speed, it tends to drown out the exhuast.
CCA
Mon May 02, 2005 10:04 am
Quoting Air2gxs (Reply 2):
Photo © Shotaro Shimizu
Photo © Sven De Bevere
Photo © Zhang Yun Zhe
Photo © Jussi Kettunen
I couldn't agree with Air2gxs more, just to add that deep drone is also very particular to the Rolls Royce RB211-524 which are on the ex CX 743s of PIA.
I must say it's a great sound.
Rgds CCA
P1 in A330, A340, A346, B742, B744, B748.
twincommander
Tue May 03, 2005 9:19 am
Quoting Goldenshield (Reply 6):
that depends on what turboprop engine your running.
Garret and Pratts dont have any growl to them on start up, all you hear is the ignitors clicking and the low "pop" when combustion begins. Any other noise is the intake with the incoming airflow, or on a garret, the internal gears whining.
IFIXCF6
Tue May 03, 2005 12:43 pm
Try an L-1011 on a cold day for hum and smoke!!!
Mike
dairbus
Tue May 03, 2005 1:30 pm
Quoting TinPusher007 (Reply 5):
I love that sound on the MD88's as well. I also love the fact that you can hear the engine spooling up to a certain rpm and then seems to just hang there for 3-4 seconds before your hear the "poof" of ignition and the engine starts accelerating again.
"I love mankind. It's people I can't stand." - Charles Shultz
Tue May 03, 2005 4:37 pm
The B732 driven JT8Ds also have that particular interesting Small Explosion at light up,followed by the Acceleration to self sustaining speed.Sounds good.
regds
MEL
C133
Tue May 03, 2005 11:04 pm
Quoting IFIXCF6 (Reply 9):
Yes! A frosty cold RB211 smokes like crazy for a minute or so, and they really have a hum to them at initial idle all the time. It's just the nature of the beast.
Fine: Tax for doing wrong. Tax: Fine for doing well.
