futureuapilot
KLM MD-11 Gear And Roof Questions
Sun May 08, 2005 6:20 am
Hey, what's the little thing sticking out horizontally tward the nose in this picture? Is it supposed to be there? Also, what causes those black streaks on the roof by the windows and door? Thanks!
Photo © Florian Kondziela
-Sam
[Edited 2005-05-07 23:25:34]
The Pilot is the highest form of life on Earth!
EMBQA
RE: Thing Sticking Out Of The Strut.
Sun May 08, 2005 6:24 am
Nose Steering Actuator....If you'd look, nearly every single aircarft with nose steering has a design simular to it.
The black streaks are caused by dirt and the airflow over the fuselage.
[Edited 2005-05-07 23:31:50]
futureuapilot
RE: KLM MD-11 Gear And Roof Questions
Sun May 08, 2005 6:47 am
Quoting EMBQA (Reply 1):
When I had a chance to walk around a CO 777 i didn't see that little thing, was i just blind? What does the Nose Steering Actuator do?
-Sam
EMBQA
Sun May 08, 2005 6:52 am
Nose...Steering...Actuator...
It steers the airplane through moving the nose wheels....hence the name.
Klaus
Sun May 08, 2005 6:53 am
The steering actuator normally consists of a pair of hydraulic cylinders which turn the nose wheels into the desired direction. In most cases I´ve seen pictures of, the cylinders are mounted behind the strut, however.
EMBQA
Sun May 08, 2005 6:56 am
Your just blind......although a slightly different design, the actuators are clearly visable on the Boeing 777.
Photo © Rhys Dudley - TeamJetspotter
[Edited 2005-05-08 00:00:51]
futureuapilot
Sun May 08, 2005 7:52 am
Ah, ok, thanks.. I see it now.  Yeah sure
Quoting EMBQA (Reply 3):
Sorry, Actuator is a new term, English isn't my native language...
-Sam
amtrosie
Sun May 08, 2005 12:01 pm
The black streaks are a combination of dirt/water that is forced out of various crevases when the A/C is pressurized. It is also a good indication of a presurization leak, however small.
Sun May 08, 2005 6:22 pm
Nose Wheel Steering Actuators.
The Black streaks are caused by Dirt flowing over the Aircraft.
regds
MEL
helsin99
Mon May 09, 2005 10:22 am
On the first picture of the KLM MD-11, does anyone have any ideas about what that hatch that appears to be open under the first window in the passenger compartment is or does? Is that the valve that release cabin pressure?
EMBQA
Mon May 09, 2005 11:28 am
If I remember correctly it's an outflow for the ACM Packs. Notice the two inlets on the forward side of the nose.
Mon May 09, 2005 2:38 pm
Quoting Helsin99 (Reply 9):
Are you referring to the Landing Light.
regds
MEL
MD11Engineer
Mon May 09, 2005 7:54 pm
Quoting HAWK21M (Reply 11):
It is a retractable landing light in the extended position. The thingies sticking out from the NLG are the two steering actuators and two small glide path antennas below them. The things pointing foward under the nose are the three pitot tubes.
Jan
helsin99
Tue May 10, 2005 12:16 pm
Thanks for the information. Now that I look at it again, I can see that it is a light. I didn't know that they retracted. That's what I like about this forum, always learn something new.
h99
Tue May 10, 2005 6:00 pm
What are the Marking in Black for.
Near the AOA sensor & beow the Entry door.
regds
MEL
MD11Engineer
Tue May 10, 2005 8:50 pm
Quoting HAWK21M (Reply 14):
regds
MEL
We don´t have them on our freighters, but I assume KLM put them there as a guidance for the airstairs / jetway operator.
Jan
Wed May 11, 2005 5:43 pm
Seen the same markings in Orange on the New 9W A343 yesterday.
Any Idea how is the refrencing done.
regds
MEL
MD11Engineer
Wed May 11, 2005 9:06 pm
I assume that they are used by operators of airsairs which are mounted on a truck. From their cab they can´t see the door opening if the stairs is close, so they´ll orient themselves by the markings.
Jan
Users browsing this forum: flymia, MPadhi, mwalker89, Starlionblue and 3 guests
