trex8
Belly Cargo/luggage
Tue May 17, 2005 11:15 pm
is there a general rule of thumb about how many LD3 containers will be needed for a certain number of passengers on a flight?
pogo
RE: Belly Cargo/luggage
Wed May 18, 2005 2:14 am
Best person to answer this would be a flight despatcher, but there must be an average. In most systems like gaetan during the check in the system update itself all the time, eg. on an AF flight there is an EBW (expected baggage weight) and actual weight. Bags can also be broken down into direct and transit.
Not the best answer, like I said you need a despatcher.
When in doubt give it a clout
Goldenshield
Wed May 18, 2005 2:43 am
For a full flight, the number would be dependant on whether it's domestic, or international. I only worked with domestic flights back when I was a ramper, but I seem to remember that it was only about 4-5 LD2's for a 767. This out of 32 positions for a 767-300. We were only alotted 16 for cargo, which, I believe, was just in case baggage was more than intended.
744rules
Wed May 18, 2005 3:27 am
1 ld1/45pax or 1ld3/40pax should give you a pretty good idea.
GZIP: Off
