Christian
Landing Gear Speed
Sat May 21, 2005 2:29 am
What is the maximum speeds to lower the landing gear on the B-777 and the B-747-400.
I apologies if this have been discussed before, but I have search, and couldn't fin anything.
/Christian
If your pictures aren’t good enough, you’re not close enough
PhilSquares
RE: Landing Gear Speed
Sat May 21, 2005 3:53 am
The 400 is 270 KIAS/.82M for gear extension or retraction. 320/.82M for gear down.
Fly fast, live slow
2H4
Sat May 21, 2005 2:30 pm
....From the internet, so I'm not guaranteeing accuracy here...
777-300:
VLO - Maximum Gear Operating Speed 270 KIAS/.82 Mach
VLE - Maximum Landing Gear Extension Speed 270 KIAS/.82 Mach
2H4
Intentionally Left Blank
tinpusher007
Sat May 21, 2005 7:25 pm
Quoting PhilSquares (Reply 1):
Why is there a second speed for gear down? If you extend the gear, isn't it down? Can this really be done at Mach .82? Or should I focus more on the Indicated Airspeed instead of the Mach number?
"Flying isn't inherently dangerous...but very unforgiving of carelessness, incapacity or neglect."
PhilSquares
Sat May 21, 2005 9:05 pm
If you are doing an emergency descent from 370 or so, your mach will be .85-.86 while your indicated will be around 240 or so. In that case, you have to slow to .82 or less.
At lower altitudes, the indicated speed becomes a factor.
Fly fast, live slow
Christian
Sat May 21, 2005 9:22 pm
Thanks alot for the answers
/Christian
longhauler
Sat May 21, 2005 9:30 pm
Quoting TinPusher007 (Reply 3):
The gear operating speeds, (extension and retraction) are always less then the gear extended (down and locked) speed. This is due to the landing gear door restrictions as the doors open, gear extends or retracts, then close again. Once the gear doors are closed, you may then fly at a higher speed, with the gear extended.
Users browsing this forum: Finn350, trent900 and 1 guest
