EK156
Engines On The Tail Like MD 11
Sun May 22, 2005 8:36 pm
What major difference does a tail engine do, like the ones on the MD 11?
I always liked the look of these engines on the tail. But why not just have them under the wing like airbus and boeing?
Can you anyone help?
air2gxs
RE: Engines On The Tail Like MD 11
Sun May 22, 2005 8:56 pm
Because the manufacturer wanted a 3 engine aircraft and centerline thrust is the best way to do that. Where would you put the 3rd engine if not the tail?
dtwclipper
Sun May 22, 2005 8:59 pm
Take a look at the history of the A/C!
"The initial specifications were set by American Airlines, who required the new aircraft to be a large capacity, short-to-medium range twin-engined jetliner capable of taking off from smaller airports, with New York's La Guardia being mentioned specifically. The initial design had seating for 250, a maximum gross weight of 300,000 pounds (136,000 kg), and a range of 1,850 nautical miles (2,990 km) with two 50,000-pound-thrust (223 kN) turbofan engines. However, Lockheed was eager to establish a more broader basis for its overall design. Eastern Airlines favored a trijet configuration, as much of their longest routes were overwater, and it was still an era before ETOPS (Extended Twin-engined OPerationS). Trans World Airlines also favored a trijet as they intended the new aircraft to fly U.S.Midwest-to-West Coast segments where the Rocky Mountains were a concern. After discussions with several airlines went on, most of them started to favor a three-engined configuration, although adding a requirement of having a transcontinental range for greater flexibility.
Appearances of the L-1011 and the DC-10 became very much alike, as they were built to meet the same requirements: a 300-seat airliner with a Mach 0.8 cruise and operations from a 9,000 ft (2,700 m) runway on a hot day. However, the most difficult specification to meet was no doubt the capability to operate within the restrictions of La Guardia. Performance parameters were strongly influenced by the airport's geometric and dimensional restraints as well as runway length and a limited maximum gross weight of 270,000 pounds (122,600 kg), although this limit has since been extended. However, though these two are similar, they are not at all identical. When distinguishing the two, the most noticeable difference is the position of the aft engine, or otherwise called the No.2 engine. McDonnell Douglas opted for a straight-duct configuration with the engine mounted on the tail in order to optimize engine performance. On the other hand, Lockheed allocated the third engine in the rear fuselage with the air intake on top of the fuselage. This arrangement is commonly known as the S-duct. This is more similar to that of the Boeing 727 than the DC-10. A series of experiments showed efficiency loss of the engine to be negligible and also showed significant gains in directional stability and maintainability of the engine. In addition, the aft fuselage placement resulted in an improved aerodynamic aft-fuselage configuration, which in turn allowed the fuselage to have a wider aft cabin layout, meaning better comfort for the passenger."
http://flytristar.tripod.com/page/history.html
BTW....there is a thing callled "GOOGLE" and you will find a lot of information there!
Compare New York Air, the Airline that works for your Business
HaveBlue
Mon May 23, 2005 1:31 pm
Excellent description Dtwclipper. However, I take exception to everyone quoting the 'Google' and 'Search' in reply to threads. If everyone Googled and Searched their answers, there would be little to nothing going on here at the forums. I for one am glad to see questions answered that I might not even have thought to ask, and to see different peoples perspectives and wisdoms, be that from an airliner pilot, CFI, ATC'er, or enthusiast.
Just a thought.
Here Here for Severe Clear!
Mon May 23, 2005 1:40 pm
Quoting EK156 (Thread starter):
Ironically, the tail mounted engine in many ways became the undoing of MD. The MD-11 duct was very expensive to develop, and planned stretches (sometimes known as the MD-12 or MD-XX) came to naught in large part due to the expense of the duct.
Trijets are cool but putting an engine backthere is not an optimal solution on a large jet unless you have to meet very specific performance and dimension targets, like the LGA thing. Nowadays, engines are powerful enough that twins (330, 767, 777) can manage the same job. Any plane large enough to need more than two engines (in theory, three engines could power something in the 744 weight class) would make a middle engine placement far too expensive and complex, so it's easier just to make a quad.
Although Boeing did toy with this:
http://www.rosboch.net/various/B747-300_Concept_with_three_engines.jpg
Stealthz
Mon May 23, 2005 7:38 pm
The MD-11 duct was very expensive to develop...
What was so complex about the DC-10/MD-11 duct, seems like a fairly straight forward concept apart from carrying the tail structure around it?
Chris
Mon May 23, 2005 11:24 pm
Quoting StealthZ (Reply 5):
As far as I can figure, the expensive bit was twofold, but I'm sure someone has better info:
- The darned engine had to be cantilevered up there with the so called "banjo fitting", a rather expensive thing to design and build. Essentially you're putting this enormous heavy blob away from the fuse or the wings, and you have to transfer the forces somehow.
- The intake was aerodynamically tricky, especially in a crosswind.
prebennorholm
Tue May 24, 2005 7:22 am
Quoting Starlionblue (Reply 4):
Dear Stallionblue, some thirty years ago I read the opposite, that Douglas chose the fin mounted #2 engine in order to save development money, and development time - to get ahead of the competing L-1011.
(We are of course talking about development of the DC-10. The MD-11 must be considered sort of "DC-10NG" just like the DC-3 is a DC-2NG).
It was at that time well known that early B727's frequently suffered #2 compressor stalls during rotation when the high angle of attack created turbulence on top of the fuselage. And the new high bypass ratio engines were supposed to be even more prone to compressor stall than the old JT8D. (Later 727's had the S-duct changed so compressor stalls became much less frequent - most noticeable difference is a more oval intake).
Lifting the engine out of that turbulence freed Douglas from lenghty wind tunnel tests to get the internal shape of the S-duct right.
They knew that the high engine would mean a structural weight penalty, but also a slight engine efficiency gain due to the absence of the S-duct.
I don't see why the high mounting should be any more expensive. It is after all only an ordinary wing mounted engine pylon mounted upside down. And then structurally dimensioned to carry a vertical fin on top.
MD11Engineer
Tue May 24, 2005 9:00 am
Quoting Prebennorholm (Reply 7):
The No. 2 engine is not mounted upside down. In fact it is hanging from a pylon jutting out after from the rear banjo fitting (there are 4 of them).
Jan
flybyguy
Tue May 24, 2005 11:48 am
Not to hijack this thread... but I think this question is relevant without having to create a new thread on the topic...
When pilots inspect a tri-jet during their walkaround is there any special procedure for visual inspection to ensure that the #2 engine has not encountered FOD ingestion such as a bird strike or any other potentially detrimental damage.
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
GQfluffy
Tue May 24, 2005 3:19 pm
The 727-200s and -200 ADV had circular intakes. The 27-100 had the oval intake.
fluffy
This isn't where I parked my car...
Tue May 24, 2005 3:42 pm
Yes well I will agree it's probably cheaper than the Tristar mounting in many ways. However it's still an expensive way of doing things compare to a quad or a twin. The tail gets complicated if you put an engine there, regardless of fin or fuse mounting.
eilennaei
Tue May 24, 2005 4:25 pm
Makes me wonder if the DC-10-40 and MD-11 have the common construction of the #2 installation? The intake's shape is different from the earlier DC-10 models, deflecting inwards in the middle. Something related to a redesign of the intake adapter ("bellmouth")?
See discussion on p. 15 of
http://216.239.59.104/search?q=cache...ir_Cargo.pdf+dc-10+bellmouth&hl=sv
From what I can judge, servicing the tail engine seems to be arranged just like the other engines once you have got up there. For the parting of the engine the inner sections of the elevators seem to have a "resting" facility to make space for the engine and for the temporary cable runs, which will be long.
The design is a "straight-through" one. In terms of aerodynamic efficiency this must be close to the optimum solution.
-Eilennaei
[Edited 2005-05-24 09:28:31]
[Edited 2005-05-24 09:30:30]
EK156
Thu May 26, 2005 2:48 pm
Quoting Flybyguy (Reply 9):
You are soooo right Flybyguy... How can a Pilot do his checks on a Triengine plane when one of the engines is all the way up on the tail??? Do they get him a big ladder??? Curious to know!!!!
Thu May 26, 2005 3:07 pm
Quoting EK156 (Reply 13):
I suppose the Mx would have done this Already.But a very good question no doubt.
Anyone with Trijet Experience.
regds
MEL
FDXmech
Thu May 26, 2005 10:45 pm
No. #2 engine intake is usually inspected using a cherrypicker and walking down the intake to inspect the blades. And even that is only done on "A" checks and higher (depending on carrier).
Of course during deicing operations, the engine is inspected after each spraying.
FDXmech
Thu May 26, 2005 11:51 pm
But on the other hand a pilot doesn't check the #2 engine of a 727 either. Or (depending on carrier) can't look into the intake of 1 or 3 as well. Yes, I know about the aft entry doors of the 727.
airxliban
Fri May 27, 2005 11:31 am
Hmm, a cutout drawing of the L-1011 would be nice. I tried our friend Google but wasn't sure what to call it. Anyone know where we can find one?
Fri May 27, 2005 12:48 pm
Quoting AirxLiban (Reply 17):
Flight International has a lot of Cutaway drawings.
regds
MEL
Users browsing this forum: AAairplane, B777LRF, Google [Bot], vc10 and 13 guests
