Remote Controlled Water Drains
Wed May 25, 2005 9:09 pm
How do Remote controlled water drains work on an A320 Fuel Tanks.
regds
MEL
320tech
RE: Remote Controlled Water Drains
Tue Jun 07, 2005 8:34 am
None of our aircraft has this - any more info? Which airline, which fuel tanks, etc?
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
Tue Jun 07, 2005 4:11 pm
IA A320s,Normally around the Wing Root area.Is there another name for them along with the Normal Drain valves.
regds
MEL
jeb94
Tue Jun 07, 2005 4:41 pm
Are you thinking of a fuel tank sump drain?
Tue Jun 07, 2005 8:50 pm
No Clearly Water Drains.
regds
MEL
VC-10
Tue Jun 07, 2005 9:34 pm
Hawk,
I venture to suggest you are getting confused with indirect (remote) drain valves where the drain isn't at the lowest point of the tank but is connected to some pipework that transports the water from the lowest point to the valve.
Wed Jun 08, 2005 6:04 pm
I spoke to a Kingfisher AME friend,who says the drains are Solenoid operated But Electrically controlled manually selected to drain accumulated water from various areas.The outlets are the Wing root areas near the Fuselage.
regds
MEL
VC-10
Thu Jun 09, 2005 12:50 am
Well that's a new one on me. I can't see the point of it. You can't just drain it into the environment so somebody has to be underneath the drain with a container so what is the advantage?
Just seems like something else to go wrong.
Thu Jun 09, 2005 2:17 am
Quoting VC-10 (Reply 7):
Could it be Fuselage drain Areas.The qty would not be much.
regds
MEL
widebody
Fri Jun 10, 2005 8:40 pm
The fuselage has a few valves to drain the bilge area on take-off and landing on A320's, they open at 2.1psi I think. You can hear the hissing noise in the cockpit on take-off/landing via the door drain grid.
troubleshooter
Sat Jun 11, 2005 2:28 am
The only aircraft with a "remote" fuel tank water drain I know is the Boeing 737. The center fuel tank sump drain valve is operated by a rod mechanism through an access panel on the lower fuselage skin.
This job sucks!!! I love this job!!!
Sat Jun 11, 2005 7:07 pm
Quoting Troubleshooter (Reply 10):
That Drain is Manually Accessable although in a "Remote" location  Smile
regds
MEL
Users browsing this forum: BobPatterson, FAST Enterprise [Crawler], travaz and 1 guest
