A318 Height Comparative With Family
Sat May 28, 2005 8:50 pm
Is it true that the A318 stands higher than the A319/20/21s.If so why.
regds
MEL
aerlingus330
RE: A318 Height Comparative With Family
Sat May 28, 2005 9:03 pm
Yes, Its True...
A318-12.76 m
A319- 11.76 m
A320- 11.76 m
A321- 11.76 m
It is only about 1m, so Im not too sure why
Hope this helps,
AerLingus330
Aer Lingus Airbus A330-300
doug_or
Sat May 28, 2005 10:05 pm
Taller vert stab. Needs to be bigger to allow for engine out stability. Since the fues is shorter, the vert stab is clsoer to the engines and has a shorter arm.
(see also 737-600)
When in doubt, one B pump off
doug_or
Sat May 28, 2005 10:07 pm
... and A330-200, I'm trying to think of other shrinks that have this feature, but thats all I'm getting. Pretty sure L-1011-500, 735, And A340-200 all kept their original tails. Any other shrinks I'm missing?
2H4
Sat May 28, 2005 11:23 pm
747-100 and 747-200 - height 19.33m (63ft 5in)
747-300 - height 19.33m (63ft 5in)
747-400 - height 19.41m (63ft 8in)
747SP - height 19.94m (65ft 5in)
2H4
Intentionally Left Blank
dan2002
Quoting Doug_Or (Reply 3):
747SP
-Dan
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
pilotsmoe
Sun May 29, 2005 4:10 am
737-600 has a bigger vert. stab, too. The 737-600 looks like a football with wings  airplane
doug_or
Sun May 29, 2005 6:43 am
Ah! the SP. THe dimesnions don't do it justice. Becuase the fues slopes down rather strangely, you get much more than surface area than those 2 feet of height would suggest.
Sun May 29, 2005 5:51 pm
Quoting Aerlingus330 (Reply 1):
A318-12.76 m
A319- 11.76 m
A320- 11.76 m
A321- 11.76 m
So the difference in height is mainly by the taller Vertical stablizer.Is the MLG height the same for the entire family.
regds
MEL
Mon May 30, 2005 10:05 am
Quoting HAWK21M (Reply 8):
I would guess that it is the same since the wing is the same and it would be a lot of trouble to change the gear for one version, especially a niche version.
Mon May 30, 2005 1:58 pm
Is the A321 Wingspan larger.
regds
MEL
doug_or
Mon May 30, 2005 11:32 pm
Only diffrence on the 321 wing I know if is the flaps.
ZRH
Tue May 31, 2005 2:37 am
Usually shorter aircrafts have to have larger vertical stabilizers. The 318 is higher than the 319/320/321. The 737-600 is higher than the -700/800/900. The 747SP is higher than the -100/200/300/400. The 380 has is also quite high in comparison to its length (the -900 will probably have a smaller rudder). I think this has to do with the leverage.
Pihero
Tue May 31, 2005 8:38 am
HAWK21M, Doug_Or,
The 321 wing has in fact a deeper chord than the 320, giving it a marginally bigger wing area.
The interesting bit is that the increased wing surface is not for heavier weight reasons (as Doug said,that is taken care of by the new, more lift producing flap system ) but for handling reasons i.e. the risk of tail strike on takeoff rotation.
Contrail designer
Tue May 31, 2005 10:27 pm
Quoting HAWK21M (Reply 10):
regds
MEL
As Doug_Or and Pihero point out, the wing is basically the same, so same span. - - Slightly deeper chord (didn't know about that!)
- Addition of double slotted flaps allows for the same low speed performance.
Quoting ZRH (Reply 12):
Exactly. The torque is proportional to the length of the lever and the size of the force. Larger rudder=larger force to compensate for the shorter lever. Of course, the plane does get heavier with length, which explains why the 340-500/600 has the larger fin/rudder from the 330 despite being longer.
