jumbojim747
Presurising On The Ground Why?
Sun Jun 19, 2005 6:29 pm
Why do the pilots pressurize the aircraft on the ground.?
Wouldn't it be too early to do so as they would have a fair amount of time to do it while airborne.
Im thinking maybe it would be a bad idea for the aircraft as it sometimes needs to go back to the gate for different reasons and then it has to be un presureized again.
Why not just do it while say at climb.
On a wing and a prayer
Jetlagged
RE: Presurising On The Ground Why?
Sun Jun 19, 2005 9:08 pm
It's done automatically as soon as throttles are advanced to takeoff power on most modern airliners, not a pilot action.
All this does is pre-pressurise the cabin to about 200 feet below aircraft altitude so dumping this for an immediate landing is not a problem.
In the case of an aborted takeoff, the cabin would automatically depressurise on closing the throttles.
Pre-pressurising puts the outflow valves in a controlling mid position, rather than fully open. This helps smooth out cabin pressure bumps which might occur on rotation. It also means the crew can't forget to start pressurising the aircraft during the climb  Smile
On older, three crew aircraft such as the 747-200 it was usual to take off unpressurised, with the packs being switched on one at a time during initial climb. A two man crew would not necessarily have the time to carry out this procedure properly.
Sun Jun 19, 2005 9:13 pm
In ref to Pressurisation in case of Chapter 21.On the B737 pre pressurisation is carried out to prevent a pressure bump inside the cabin when the Aircraft gets Airborne.Its a matter of a flick of a switch & is not a lengthy process.
If "Presurisation" refers to the Chapter 29,Hydraulic system,then its to check for leaks & any warning lts.
regds
MEL
SlamClick
Sun Jun 19, 2005 10:22 pm
It is not pressurized to the full allowable differential, but just to maybe 200 feet below field elevation - a fraction of a pound per square inch.
In addition to the benefits above, relating to the outflow valve, consider this: A small amount of pressure will seat the plug-type doors and windows fully. Also, a slightly pressurized fuselage tube is stronger than an unpressurized one. Open an aluminum beer can some time. As soon as you break the pressure seal the sides become really flexible. Metal is the same thickness as before, the difference is a very small amount of internal pressure, or simply, resistance to compression.
thegreatchecko
Sun Jun 19, 2005 10:55 pm
When I fly the King Air, we pressurize it for the above reasons, but also because it provides for a slightly quieter cabin due to the better gap seal. It provides for a slightly more comfortable cabin for the passengers and thats what its all about!
GreatChecko
"A pilot's plane she is. She will love you if you deserve it, and try to kill you if you don't...She is the Mighty Q400"
Jetlagged
Mon Jun 20, 2005 2:04 am
Slamclick, you jest surely?
Aluminium beer cans don't have ribs and stringers.  Smile
I doubt 0.1 psi differential would strengthen the structure noticeably.
jumbojim747
Mon Jun 20, 2005 6:56 am
Thank you all for your help.
All the points make sense here i appreciated very much
SlamClick
Mon Jun 20, 2005 7:44 am
Quoting Jetlagged (Reply 5):
Absolutly not.
Of course a pressurized tube is stronger than a non-pressurized tube. (So long as the amount of pressure applied is not, itself, a strain on the structure.)
XFSUgimpLB41X
Mon Jun 20, 2005 10:36 am
the CRJ does the same as the 737 as SlamClick described...It's only when power is advanced for the takeoff roll, not during taxi.
Chicks dig winglets.
Jetlagged
Tue Jun 21, 2005 8:26 pm
Quoting SlamClick (Reply 7):
Stiffer yes, stronger no. It will fail in tension at the same load. So it won't flex as much but will only support the same bending moment from the tail for example.
If an aircraft fuselage required pre-pressurisation to be strong enough it shouldn't be flying.
lightsaber
Wed Jun 22, 2005 1:25 am
Quoting Jetlagged (Reply 9):
Stronger from a buckling standpoint, an important criteria with aluminum aircraft.
True. But it might minimize fatigue and thus reduce life cycle costs. (I'm speculating... )
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
SlamClick
Wed Jun 22, 2005 3:03 am
I'll keep that in mind next time someone tries to pull my airliner in half. Smile
FDXmech
Wed Jun 22, 2005 12:32 pm
On a different note, the DC10 pressurization schedule maintains field elevation until 5000 feet. This mode in case the aircraft needs to return to the airport.
XFSUgimpLB41X
Wed Jun 22, 2005 1:53 pm
On the CRJ, if we begin a descent before we reach 6000 feet the airplane automatically thinks that we are returning to the field and sets cabin elevation for where we just departed from.
2H4
Wed Jun 22, 2005 9:13 pm
Quoting XFSUgimpLB41X (Reply 13):
What constitutes a descent to activate this? If, for example, you have to level off at 5000 feet for traffic, and during your level-off you sink 30 or 40 feet, does that set cabin elevation to the departure airfield?
2H4
Intentionally Left Blank
XFSUgimpLB41X
Thu Jun 23, 2005 3:27 am
Don't have my manuals with me..but i believe its a 500FPM descent.
Jetlagged
Fri Jun 24, 2005 6:27 am
Quoting Lightsaber (Reply 10):
So perhaps the wings and tail should be pressurised too? Big grin
Pressurisation cycles decrease fatigue life.
Users browsing this forum: asqx, CS500, longhauler, meecrob and 18 guests
