Mr Spaceman
Questions About The Horizontal Tail On A CRJ?
Wed Jun 22, 2005 2:55 am
Hi guys.
What are the 2 white boxes that can be seen in this photo inside the top of the tail of this CRJ-100 used for? (due aft of the leading edge's top). They look like small actuators that are connected to the larger round disc shaped objects below. Is that what they are... actuators?
Photo © Stephan Kruse
It appears to me from looking at outside photos of CRJ's tails that the horizontal stabilizer's angle of incidence is variable. Are the white boxes/actuators in the photo above what moves this surface?
Photo © Jerry Search
All of the CRJ aircraft versions appear to have a horizontal stabilizer that can move, and an elevator. How do they work regarding pitch changes & trim?
Does the elevator control pitch changes via the cockpit control columns, and the horizontal stab controls fine trim adjustments during cruise flight ....for example?
I'm a little confused about how some airliner's T-Tails work. Especially after reading posts about how the "flying tails" on MD-80 series jets work.  scratchchin
Chris  Smile
XFSUgimpLB41X
RE: Questions About The Horizontal Tail On A CRJ?
Wed Jun 22, 2005 3:09 am
Those look like the stab trim actuators. Just a guess.  Smile We have two stab trim channels, which are electrically driven...so it would make sense.
Chicks dig winglets.
Mr Spaceman
Wed Jun 22, 2005 3:20 am
Hello XFSUgimpLB41X.
Thanks for your reply. Big grin
OK, so it sounds like it is the horizontal stabilizer that's used for trimming pitch (via those 2 actuators)....and not a trim tab on the elevator like in a little Cessna-150.
Chris  Smile
XFSUgimpLB41X
Wed Jun 22, 2005 3:38 am
Oh yeah..forgot to mention.. the entire plane of the stabilizer moves when we trim, unlike a cessna.
Mr Spaceman
Wed Jun 22, 2005 3:44 am
"Oh yeah..forgot to mention.. the entire plane of the stabilizer moves when we trim, unlike a cessna."
Thanks for clearing that up for me. Big grin It was just one of those things I wasn't sure about.
Chris  Smile
radialman
Wed Jun 22, 2005 6:43 am
There are actually 4 white boxes.2 for left hand side elevator and 2 for right hand side.The top little box is the pitch feel linear actuator and the bigger one below on the same side is the pitch feel simulator unit.
The pitch feel simulators supply the pilots with the necessary positive feel force to help control the aircraft. Its basically the feel the pilot gets when he/she moves the control column to move the elevators for a pitch up or pitch down movement.
The horizontal−stabilizer control−surface system contains the horizontal stabilizer. The horizontal stabilizer supplies longitudinal (pitch) trim to the aircraft, and is moved up or down by the operation of the horizontal stabilizer trim actuator (HSTA).
The range of horizontal stabilizer movement is from +2 degrees (leading edge up)to −13 degrees (leading edge down).
Operation
A. When the HSTA is operated, the driven nut of the HSTA moves the horizontal stabilizer up or down in relation to the horizontal−stabilizer pivot axis. The operation of the horizontal stabilizer causes a pitching movement of the aircraft to occur. When the leading edge of the horizontal stabilizer moves up, the nose of the aircraft moves down.
When the leading edge of the horizontal stabilizer moves down, the nose of the aircraft moves up.
B. Movement of the horizontal stabilizer is transmitted to the input linkage of the elevator power control units (PCU). These elevator PCU inputs occur because of the geometric relationship between the horizontal−stabilizer pivot axis and the input linkage of the elevator PCU. The movement of the elevators increases the performance of the horizontal stabilizer.
Hope this helps.
PM me for more details if needed.
DC8FriendShip
Wed Jun 22, 2005 9:35 pm
Quoting Mr spaceman (Thread starter):
Most large jet aircraft today have the "flying tail" as a means for controlling the trim of the aircraft. this allows for greater flexibity in CG area, and allows the controls to stay streamlined to reduce drag.
Come fly the Friendly Skies of United
Mr Spaceman
Fri Jun 24, 2005 2:08 am
Hi guys.
>> Radialman, that's excellent information. Thank You, for explaining how the two sets of boxes up there in the tail work, etc.
Quoting Radialman (Reply 5):
It's interesting to learn that the forces the pilots feel through the control column during pitch changes are not based on just natural aerodynamic forces on the elevator, but are aided by the pitch feel simulators. I guess other airliner types use this equipment too.
>> Dc8friendship .........
Quoting Dc8friendship (Reply 6):
Thank You, for your explanation. You have me wondering though, by "large jet aircraft", do you also mean airliners with conventional type tails at the back of the fuselage .... not just large T-Tail aircraft?
Chris  Smile
jeb94
Sat Jun 25, 2005 7:48 pm
If you take a close look at even conventionally tailed aircraft you may be able to see little rub marks where the horizontal gap seals are rubbing on the empennage. Normal and harmless but gives a great clue as to the normal movement range of the horizontal. Even on the old DC9 family the pilots don't feel the natural forces on the tail. Douglas used 'Load Feel' springs to allow the pilot to feel a load. The rudder, elevator, and aileron controls all have these. Again, the entire horizontal moves with the use of the infamous jackscrew driven by electrical motors coupled through a gearbox.
Mr Spaceman
Sun Jun 26, 2005 11:54 am
Hi guys,
After reading Dc8friendship's words .....
"Most large jet aircraft today have the "flying tail".
As well as Jeb94's words .........
Quoting Jeb94 (Reply 8):
...... I did a photo search and gave up on trying to find a modern airliner that doesn't have a "Flying tail", whether or not the aircraft's Horizontal Stab is in a conventional location or it has a T-tail.
>> Jeb94, Thank You, for your very good info. Big grin
Photo © Tom Mousel - Luxembourg Aviation Photography
Photo © Jerome Zbinden
Photo © Simon Nicholls
Photo © André Costa - Lisbon Spotters
Photo © Emmanuel Perez - Luxembourg Aviation Photography
Photo © Jason Nicholls
Radialman, explained the CRJ's Horizontal Stab's range of movement in degrees in this statement ....
It appears that all airliner's Horizontal Stab's leading edge can move down a lot more than up ...... which makes perfect sense to me based on how much Stab deflection is needed to either help an airliner oppose gravity or fall with it.
The ERJ-175's Horizontal Stab in the one photo above seems to have an almost equal range of movement up or down (according to the leading edge degrees markings), unlike the A319 in this photo ......
Photo © Michael Carter
Chris  Smile
aeroweanie
Tue Jun 28, 2005 11:51 pm
One tiny correction Mr Spaceman: In your last post you include a picture of a L-1011's horizontal tail. The L-1011 is an exception, in that it has no elevators. The entire horizontal tail moves for trim and to provide control. This is commonly called a stabilator. Most jet fighter aircraft have stabilators.
Otherwise, on most transport aircraft, the forward part of the horizontal tail (the stabilizer) moves for trim and the aft part (the elevator) moves for control. Other exceptions, in the business jet category, are the Lockheed JetStar, where the entire tail (including the vertical tail) moves for trim, while the elevator provides control and the HS.125/Hawker 800 series, where the stabilizer is fixed and the elevator provides both trim and control.
Photo © Johan Ljungdahl
Photo © Asgeir Sigurdsson
Mr Spaceman
Wed Jun 29, 2005 4:03 am
Hello AeroWeanie.
Thanks for your information. Big grin OK, I understand now that an L-1011 is an exception .... it has no elevators. The entire horizontal tail moves to provide both pitch control & trim. (My first ever airliner flight was to {& from} Atlantic City (KACY) on this Worldways Canada L-1011 - a GREAT aircraft!  spin  )
Photo © Trevor Ogle
Your comments .........
Quoting AeroWeanie (Reply 10):
Yeah, it's amazing to watch the stabilators on a fighter jet moving so quickly (with the left & right sides moving individually) from computer commands during short final .... especially during an aircraft carrier landing!
I guess an L-1011's stabilators don't move individually .... L-1011's don't get into to many "Dog Fights!"  Silly
Question .......
Does the MD-11 also have a stabilator like an L-1011? The one in this photo sure looks like it does.
Photo © Fabio Laranjeira - Contato Radar
Chris  Smile
aeroweanie
Wed Jun 29, 2005 5:53 am
Quoting Mr Spaceman (Reply 11):
The MD11 has a conventional stabilizer/elevator combination. In the picture you refer to, the elevator is in trail with the stabilizer, so its hard to see. Look closely at the tip and you can see evidence of the elevator.
Mr Spaceman
Thu Jun 30, 2005 3:37 am
Hello AeroWeanie.
OK, Thank You Sir, for letting me know that an MD-11 has a conventional stabilizer/elevator combination.
Here's a few photos that show the separate elevator a bit better.
Photo © Justin Idle
Photo © Benedikt Pressburger
After a photo search, it appears to me that the horizontal stabilizer (not the elevator) plays a more active roll in pitch control during landing than during takeoff. But then again, it may not actually be that way, it may just look like that because of when the photos were taken.
Photo © Roy Loyson
Chris  Smile
aeroweanie
Thu Jun 30, 2005 9:41 am
A pilot uses trim to reduce the control forces required to maneuver the aircraft. In landing, large control deflections are required to flare the aircraft. The stabilizer is moved to trim the aircraft so as to minimize the amount of force the pilot needs to exert to move the elevator to perform the flare.
Mr Spaceman
Fri Jul 01, 2005 1:10 am
Hello AeroWeanie.
Thank You, for that explanation.
It feels good to have confusion about how an aircraft works "removed from my mind!!!"  spin
Chris  Smile
474218
Sat Oct 22, 2005 11:07 am
Thanks for your information. OK, I understand now that an L-1011 is an exception .... it has no elevators.
The L-1011 is the only airline with a flying stabilizer, the entire horizontal stabilizer moves to provide both pitch and pitch trim control. It also has two elevators in the trailing edge. The elevators are geared to stabilizer movement. When the stabilizer moves nose down, the elevators move up. This aids in low speed pitch control. When the stabilizer is moved full nose up the elevators are faired.
crjmech
Sat Oct 22, 2005 12:27 pm
Mr. Spaceman- just FYI, the horizontal stab trim actuator is barely visible in the first pic you posted. It's the black device just aft of the elevator pitch feel assy. It's partially obscured by the small bulkhead.
Thou shalt mind thine altitude,lest the ground reach up and smite thee.
Users browsing this forum: 747classic, blogdoguib, gcskye, njxc500 and 27 guests
