B752 AC Control Panel Related
Tue Jul 05, 2005 11:09 pm
On the B752 Air Condition Panel,Is the Compartment Temperature Indicated in Deg F or is it optional for Indications in Deg C.
regds
MEL
AvionicMech
RE: B752 AC Control Panel Related
Tue Jul 05, 2005 11:27 pm
Here at BY all our compartment temp indications are in degrees C, this includes the A/C temps on the Eicas ECS/MSG page, such as the pack out temp.
Tue Jul 05, 2005 11:43 pm
Is there a selectable option or does it come installed.If it needs to be changed over Is there a Software change.
Whats the procedure.
regds
MEL
air2gxs
Wed Jul 06, 2005 12:04 am
Our overheads are in F, but I seem to recall a few of the parameters on the maintenance pages are on C. I'm sure it's just a software issue.
cdfmxtech
Wed Jul 06, 2005 2:20 pm
Customer Option set by the vendor. The option is set inside the Compartment Temp Ind Panel.
Wed Jul 06, 2005 4:24 pm
Quoting CdfMxTech (Reply 4):
Whats the Option procedure like.Presume I need Indication in DegC & the Existing ones are in DegF.
regds
MEL
cdfmxtech
Sat Jul 09, 2005 1:55 am
Ref WDM 21-65-01. Option is et by either opening or shorting pins 12 and 13 on connector D3578 at the Compartment Temp Ind Panel.
An open circuit btwn pins 12-13 would give you °C and jumping the 2 would give you °F.
I should have said AT the panel.
SlamClick
Sat Jul 09, 2005 2:23 am
IIRC an informal standard for US delivered aircraft was oF for passenger spaces and oC for ducts and packs where temperatures were of more interest to engineers.
Exceptions to this probably outnumber confirmations.
Sat Jul 09, 2005 7:21 pm
Quoting CdfMxTech (Reply 6):
Thats Very Good Information.Thanks.
regds
MEL
Users browsing this forum: geologyrocks and 2 guests
