Lee
Holding Patterns
Wed Jul 13, 2005 9:08 am
As many will know when landing at LHR you are often put in a holding pattern. How many other airports suffer these problems, I've never experienced it anywhere else if i recall correctly, thanks
YYZatcboy
RE: Holding Patterns
Wed Jul 13, 2005 9:20 am
Most Major Airports have Holding Patterns in their STAR Procedure. If they get used or not depends on how busy the airport is.
DH1/3/4 MD11/88 L1011 A319/20/21/30/80 717 727 735/6/7/8/9 744 762/3 77E/W E40/75/90 CRJ/700/705 CC150
J/S DH8D 736/7/8
geoffm
Wed Jul 13, 2005 4:45 pm
The odd thing is, I've only once been in a holding pattern on approach to LHR - and that was one circular circuit (not racetrack) which suggested spacing rather than holding. Flown in numerous times, both short and long haul.
Geoff M.
goinv
Thu Jul 14, 2005 2:56 am
Flying into LAX a few years ago from JFK, ATC started to sequence planes from almost as far out as Las Vegas. We were told to reduce speed to fit into ATC restrictions. I suppose when there's more ground (area) to play with they can do things like that.
At Heathrow (and many other British/European) airports, the space is quite limited - I can't imagine ATC advising a northbound bound service (from Africa for example) to start sequencing as far out as Geneva!
Be who you are, The world was made to measure for your smile. So Smile.
727EMflyer
Thu Jul 14, 2005 3:04 am
When stapelton was in operation at Denver, I remember they were notorious for making planes circle. I haven't heard of any real traffic jams in the U.S. of late, though.
Woodreau
Thu Jul 14, 2005 7:10 am
In the US at least, if there is going to be a delay at major airport, ATC will institute a ground delay/ground stop program in which it controls the departures of aircraft headed into the affected delay area. The idea is to hold people on the ground rather than having them hold in the air. So hopefully this minimizes the amount of time aircraft have to hold.
MrChips
Thu Jul 14, 2005 11:52 am
Quoting YYZatcboy (Reply 1):
Adding to that, I would wager good money that nearly every airport throws aircraft into the hold more often than most people think.
Also, holds can be given to aircraft transiting the airspace as well, not just arrivals...Don't know how many times Edmonton Centre has done that to me, but it's more than I like, I'll tell you that.
Time...to un-pimp...ze auto!
planespotting
Thu Jul 14, 2005 12:50 pm
a hold is actually quite rare. even on busier days, the odds that you get a hold are pretty pretty remote. Pretty much holds are issued when airports are closed, and/or bad weather is in the area. I heard a Pinnacle CRJ get one near O'hare a few months ago and he had no idea what was going on...heres what it sounded like:
ATC: Pinnacle XYZ hold 10 miles north of the O'hare VOR on the 360 radial, expect further clearance 10 mins from now.
Pinnacle XYZ: okay so, hold 10 miles north of O'hare on the 360 radial...so, is the 360 the outbound of the inbound heading?
ATC: Pinnacle XYZ okay, the 360 is the inbound heading in the hold, and you make right turns, your outbound heading is 180, and you make a direct entry. think you can handle that?
Pinnacle XYZ: hey thanks, okay so hold 10 North of ORD 360 radial, EFC time one-zero mins from now.
you talk to some pilots and they won't see a hold for 3 years and then one day they get like 3 or something awful like that, and then anothe hold dryspell
Do you like movies about gladiators?
Ralgha
Thu Jul 14, 2005 1:32 pm
Quoting Planespotting (Reply 7):
That clearance is missing some critical information. If that's really what the controller said, then the pilot is justified in asking the question.
On the other hand, that's probably not what ATC really said, and that pilot was probably one of the 500 hour wonders from Gulfstream who paid a fat wad of cash to warm a seat that is required to have a pilot in it on an airplane with paying passengers. I wonder what the passengers would think if they knew that anyone with a big enough checkbook could "fly" that airplane?
efohdee
Thu Jul 14, 2005 1:35 pm
On many occasions I hear aircraft talking to Atlanta reading back holding instructions for holding at LaGrange as published (as in the STAR), 15 mile legs, expect further clearance at whenever, etc. I cant hear the controller but I hear many of the aircraft.
UbiDenmark
Thu Jul 14, 2005 3:29 pm
For what it's worth, I fly into LHR every week (as a passenger) and I can only recall very few occasions over many years when we have not had to fly a holding pattern over Bovingdon or Lambourne for at least five minutes and more often ten to fifteen.
planespotting
Thu Jul 14, 2005 10:13 pm
Quoting Ralgha (Reply 8):
as i said, it has been a few months since i overheard this situation, and therefore i am not able to cite ATC or the pilot word for word. i was simply stating that in the United States for the lay airline pilot holds do not happen on a regular basis.
Ralgha
Fri Jul 15, 2005 12:51 am
Quoting Planespotting (Reply 11):
I'm just saying that you may have heard wrong, because airlines usually place an emphasis on knowing how to hold, especially regional airlines since they fly to places that require holding more often than mainline airlines do. If you're flying into an airport with no radar coverage under IFR conditions, and you're not the only one there, then chances are good that you'll have to hold. Screwing up the hold can be punished by death.
ajaaron
Fri Jul 15, 2005 6:17 am
Quoting Geoffm (Reply 2):
Sometimes ATC at LHR ask inbound flights to make 1 orbit over LAM, BNN, BIG or OCK and then leave on the assigned heading.
They do this when they dont require the flight to fly the complete racetrack pattern, as orbiting is slight quicker.
Pihero
Fri Jul 15, 2005 7:31 am
To answer the thread starter's questions :
1/-As many will know when landing at LHR you are often put in a holding pattern
Yes, a hold is quite common at LHR and it is used mainly as a spacing procedure.An ATCO from London could correct me on that but the main reason is that airplanes arriving into Heathrow come generally from very close international airspaces/controls and there is basically no time to manage these traffics on an en-route speed schedule spacing.
Most pilots I know don't mind at all and most consider the UK controllers as the best there are as they always keep you in the picture ,telling you how much hoding time you'd be expecting to spend before your approach... and then there is absolutely no surprise in terms of their handling of your own traffic.
2/- How many other airports suffer these problems, I've never experienced it anywhere else if i recall correctly,
I fly just about everywhere in Europe and LHR is alone in this league.
(It's just a matter of different procedures)... Until about two years ago, holds were in use in FRA and then the Germans changed their STARs, the trajectories of which now look like a flat double S (they could be more than 70 nm long) with a lot of numbered waypoins... The beauty of this system is that when the controller clears you to one of these waypoints (with a speed constraint), you can easily deduce your remaining track distance to the runway, allowing you to conduct your flight to the required low noise final.
Paris is about as nightmarish as you could dream : vectors and speeds and I challenge anyone to manage one's flight in these conditions :you have lost your SA.
Hope this answers your questions.
Contrail designer
B744F
Fri Jul 15, 2005 8:14 am
Maybe where you are from, but are you speaking about the entire US region in general or just based on your scanning observations?
PHLapproach
Fri Jul 15, 2005 9:02 am
I completely disagree, holding is a very common procedure. Each airport probably has holds put on the arrivals about 3-5 times a week. Especially in the summer, when you have to deal with cells or even traffic volume, then the Tracon simply runs out of airspace so the Center has to hold them. Happens more often then people think.
Alias1024
Fri Jul 15, 2005 11:38 am
As PHLapproach said, holding can be pretty common when the weather turns bad. It's been occurring quite often the last few days in the northeast (along with some very long ground delay programs), with all the thunderstorms blocking the departure and arrival routes into the New York, Philadelphia, and DC area airports.
The sequencing of arrivals can start very far away from the actual airport. Very easy to see if you have access to a program like flight explorer. LGA arrivals from the west are often sequenced over Ohio. On most days you can pick out a line of EWR arrivals extending south all the way to North Carolina.
ba299
Sat Jul 16, 2005 6:37 pm
Coming from the west to LHR it really depend where the exit point from the NAT is. If it is "near" you destination the ATC have some difficult to slow you down. Sometimes as soon as you get in contact with London control the first instruction are: " reduce to minimum clean".
In the past I remember that arriving in FRA we had to hold quite often.
SlamClick
Sun Jul 17, 2005 12:33 am
I'd have to say that for domestic US airspace a holding pattern is pretty rare. Over my whole career I'd say I was given an actual racetrack hold maybe as seldom as once every thousand hours or so. Went more than two turns maybe five or six times in forty years. Went seven turns, descending, once, with Hughes Airwest F-27 above me and some bonehead in a Bonanza below us, getting sequenced for an at-minimums VOR circling approach.
Delay vectors and assigned speeds on the other hand were common, more common than just getting straight in.
Now in Europe - different matter! LGW, it seems, uses a couple of published holds as a hopper from which they draw their traffic.
geoffm
Sun Jul 17, 2005 2:10 am
Quoting PHLapproach (Reply 16):
I think perhaps you are interpreting the comment in a different way. Note the words "you get a hold" - I take that to mean you as a passenger/crew - NOT you as an airport. In that context it is certainly not common to hold if you average out holds per flight. In my near 100 flights from and to various points in the world, I've only been held twice.
Geoff M.
Ralgha
Sun Jul 17, 2005 5:00 am
Quoting SlamClick (Reply 19):
It all depends on where you're at Big grin
In radar environments, holds are pretty rare, they like delay vectors and the like. Non-radar environments when the weather is low, holds are much more common.
zarniwoop
Mon Jul 18, 2005 11:05 am
I was on a BA flight from LHR to SIN last year cruising pretty high over Afghanistan. Couldn't sleep so was watching the map on the IFE when I noticed that plane had done a 180 turn and was heading back to europe! I was pretty relieved a few minutes later when it did another 180 and headed back on the normal course, so must have been in a holding pattern.
CX777
Mon Jul 18, 2005 2:06 pm
Over the years I have experienced HOLDING on a flight about dozen times. However, the most unusual was last month.... I flew QF107 SYD-LAX-JFK sector. On LAX-JFK, I was sleeping and was awaken 1/2 way only to find out we were in a HOLD at cruise FL370 somewhere over Wisconsin 150nm west of Chicago!!. There were severe thunderstorms at JFK area and the traffic was backed up. As the captain came on for the third time to explain why we may divert, he got the green to continue! All in all we HELD for over 35 minutes and were in a 3 min race track with 090/270 headings.
Raj
brettbrett21
Tue Aug 02, 2005 7:06 am
Are there such things as departure holds, I think I've seen something like these on charts before but I've never heard of them in practice.
I mean a hold in congested airspace where you would climb to a high altitude.
Anyone?
Brett
i'm so excited i wish i could wet my pants!
Tue Aug 02, 2005 8:20 am
Whoa. Well as others have said, LHR has a hold most of the time. I fly in there twice a month nowadays and am very surprised if we don't do a couple of laps.
As has been said, in the US this is the case.
Quoting UbiDenmark (Reply 10):
Same experience as mine.
BTW don't you hate pilots who don't keep the pax in the loop? You're circling over Atlanta for 45 minutes and the pilots say nada. Is it so hard to get on the PA and tell us what's going on, or is the hold taking ALL your attention? Kudos to the AA pilots on JFK-LHR, who always tell us when we enter and when we exit, and update the arrival time.
milski
Wed Aug 03, 2005 1:45 am
Quoting Brettbrett21 (Reply 24):
There are (at least in the USA) holds which are parts of obstacle departure procedures where you are expected to climb to your minimum enroute altitude before proceeding enroute. But this is strictly for terrain avoidance and mostly about small single engine planes - the altitudes to which they have to climb are in the lines of 5-10 thousand feet. I'm not aware of anything similar done for airliners on departure - it somewhat makes sense to get them out of the way as soon as possible to decrease the congestion.
Users browsing this forum: Google Adsense [Bot], Harry99 and 32 guests
