DColeMAN
No Power To Landing Gear Doors?
Fri Jul 15, 2005 5:33 am
Hi all,
A couple of times I've seen aircraft arrive with the landing gear doors down as though there's no power to them and they're (in a way) just hanging there in the retracting and extending position. I wanted to ask is this always due to a hydraulics failure? Sometimes the aircraft has just taxied to the gate as normal and others have requested a full emergency landing because of this. Also, what causes this to happen?
Here are a couple of examples of what I'm reffering too -
Photo © T Silgrim
Photo © Luis Gonçalves
Thanks in advance,
Dale
Topless Women Drink 4 Free
LimaFoxTango
RE: No Power To Landing Gear Doors?
Fri Jul 15, 2005 6:06 am
Most likely, it's a hydraulic problem. A possible cause is maybe the hydraulic pump that operates the gear doors have failed or maybe there was a break in the hydraulic line that leads to the doors.
You are said to be a good pilot when your take-off's equal your landings.
DH106
Fri Jul 15, 2005 6:12 am
When the hydraulic system that extends/retracts the gear fails the back up system to extend the gear is usually just a 'free fall' system where the gear's uplocks are removed and the gear just 'drops' into position under gravity and locks. The doors in this case are unpowered and remain open.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
320tech
Fri Jul 15, 2005 7:07 am
I beg to differ with LimaFox Tango. There is no hyd pump that specifically operates the doors.
I don't know about 757's (I'm sure it's the same), but on Dash-8's and A320's, when the aircraft lands with the gear doors down, it means the pilots have used the alternate gear extension. On the Dash-8, if a snag develops in the landing gear extension system, a caution light, "LG Unsafe" illuminates. The usual cause is either a Prox Sensor Electronic Unit (PSEU, the computer that controls the LG, amongst other things) failure, or a valve failure. The result, if you insisted on using normal extension, would be to have the doors fail to open in sequence, thus possibly jamming the gear. I've seen several Dash-8 snags like this.
I haven't seen any A320 snags, but it's probably not much different.
In the Dash, the pilot first opens a small overhead panel, which is connected to a bypass valve by a cable. He then pulls on a handle that's under the panel. The first notch opens the MLG doors, the second notch drops the gear by gravity. The nose gear is extended the same way, using a panel and handle on the floor.
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
B744F
Fri Jul 15, 2005 7:32 am
Quoting DColeMAN (Thread starter):
That caption with the Monarch picture is pointless. "can you guess?" What is the point of this rhetorical comment?
NKP S2
Fri Jul 15, 2005 10:01 am
Quoting 320tech (Reply 3):
Well actually on the 757, there sorta' is. A DC motor driven pump will extend the doors and unlock the gear during alternate extension. Actually, when opening the L/G doors on the ground for maintenance, you hit a momentary contact switch that operates the pump. It will run till a pressure switch is satisfied.
Based upon the photo taken above, I'd say one of two things are occuring:
1) The L/G are lowered but the picture was snapped at the instant just before the sequence where the L/G doors shut.
2) The L/G was lowered via alternate extension due to some problem, and the A/C will land with the doors open.
Newark777
Fri Jul 15, 2005 12:12 pm
It's a cheap attempt to get people to click on the photo, along with the "look more closely" part. You see that a lot in the db.
Harry
Fri Jul 15, 2005 2:39 pm
Quoting Newark777 (Reply 6):
Ways & Means of getting their Pics Viewed.
regds
MEL
DColeMAN
Sat Jul 23, 2005 4:07 am
Thanks to all who replied for your input.
Dale
Users browsing this forum: BoeingGuy, Elmdon and 22 guests
