aerlingus330
How Do Winglets Differ From Each Other?
Sat Jul 30, 2005 9:23 am
Hi,
I have always wondered this....How do different winglets perform compared to others, and what makes them different (performance wise)?
The main winglets/wing fences-
A310/A320/A380
Photo © Sam Lambert
747/A330/A340
Photo © Andrea Nolano
MD-11
Photo © Corey Karls
737NG
Photo © Misha Popov
Thank-You In advance
AerLingus330
Aer Lingus Airbus A330-300
AirWillie6475
RE: How Do Winglets Differ From Each Other?
Sun Jul 31, 2005 2:13 am
The winglets help reduce the turbulent airflow that is found at the end of the wings. They found that if you make the airflow smoother at that section the plane has better performance. The airbus probably knew this from the beginning and installed winglets on all their planes. The heavy aircraft need something there because they produce a lot more turbulent air at the end of the wings. Boeing was a little late to recognize the benefits of winglets.
It would be hard to see the performance of airbus winglets since they already came with the plane and they contributed to the AC performance specs, so we wouldn't know how the plane would have done without the winglets. But judging from the A380 winglets which are the a319/320 style winglets, those might be better than the a330/340 winglets since they chose that type for the new plane. We can however, see the benefits of the new 737 winglets.
http://www.b737.org.uk/winglets.htm
Jetlagged
Sun Jul 31, 2005 4:05 am
Not quite. Turbulence is random vorticity, the flow at the wingtip is a predictable strong vortex. Winglets reduce induced drag caused by the wingtip vortices by adjusting the airflow and locally rotating the lift vector. They also increase aspect ratio and so improve efficiency.
The original winglet designs were all variations of the kind seen on the 747-400. Airbus discovered they could get nearly the same benefits on the A310 and A320 with the smaller wingtip fences, a kind of low drag endplate. On the A330 and A340 it's more a case of increasing aspect ratio, and hence range, without having excessive wingspan. The A380 has a reverted to a larger version of the wingtip fence design.
The 777 wing was designed to be optimal without winglets. Adding winglets might even reduce overall efficiency. Boeing seem to have abandoned traditional winglets in favour of the raked wingtip design.
Sun Jul 31, 2005 4:53 am
Quoting AirWillie6475 (Reply 1):
Actually the A320-100 did not have fences, so it is possible to know how much more efficient the wing became.
Quoting Jetlagged (Reply 2):
Only if wingspan is not a problem. On the A380 and 737, wingspan cannot be increased due to gate clearance, thus forcing a vertical variant.
Jetlagged
Sun Jul 31, 2005 5:48 am
Quoting Starlionblue (Reply 3):
The A380 is not a Boeing, which my comment you quoted referred to. Airbus have not adopted raked wingtips in any form so far as I'm aware. Boeing addressed the wingspan issue by offering folding wingtips on the 777, but nobody bought them. They would have made great billboards at the gate  Smile
Sun Jul 31, 2005 3:36 pm
Quoting Jetlagged (Reply 4):
Folded when parked.
Pls elaborate.
regds
MEL
Jetlagged
Mon Aug 01, 2005 7:03 am
When the 777 was first launched, there were concerns that the wingspan would be too great for some operators so Boeing came up with the idea of folding wingtips to reduce wingspan on the ground. No one specified that option and I guess it's been quietly dropped.
troubleshooter
Mon Aug 01, 2005 9:24 am
Quoting Jetlagged (Reply 6):
I´ve read in a german aviation magazine that these foldable wings are designed especially for operators flying to New York - La Guardia as there are very narrow parking positions. As no operator ordered this system Boeing used the space for increasing the wing fuel tanks on later versions.
This job sucks!!! I love this job!!!
aeroweanie
Mon Aug 01, 2005 10:27 am
This thread covered this topic back in March: What Difference Does Each Type Of Winglet Make? (by RootsAir Mar 18 2005 in Tech Ops)
To reiterate my summary:
For a first-order analysis of the benefit from a winglet, lay it down flat as if it was a span extension. Hence, taller is better. Then, look at whether the winglet joins the wing in a sharp break or a smooth flow. Smooth is better.
Using this criteria, I'll rank the winglets (and raked tip):
1) The A3100/310/318/319/320/321/380 "winglets" are the least effective, but also increase wing bending moments the least. I have never seen a published number for how much they reduce drag (even Jupp's patent US4,714,215 says little), but I'd guess they are worth 1-1.5% drag improvement.
2) The MD-11 winglets come next. They are a direct outgrowth of Whitcomb's original designs. I have some NASA reports on the flight testing of a similar winglet on a DC-10. According to CR-3704, these winglets are produce a 2-2.5% drag reduction in cruise.
3) The Valsan/Quietwing 727 winglets are a latter Whitcomb influenced design. Coupled with a flap droop on the 727, they are reputed to be worth about 5%. The flap droop reduces wing bending moments and helps reduce wave drag, so the 5% is a mixture of effects. The winglet by itself is probably worth about 3%.
4) The 747-400 and A330/340 winglets are rather similar. They fall on the wing span extension line. I've read that the 747-400 winglets produce about a 3.5% drag reduction.
5) The 776-400ER/777-300ER/777-200LR raked tips also fall on the span extension line. They produce varying amounts of drag reduction, depending on their span. They also increase wing bending moments quite a bit.
6) The API/APB blended winglets produce better results than the span extension line indicates. The 737NG winglets are first generation and I've read that they produce about a 4.5% drag reduction. Later API/APB winglets improve on this.
Mon Aug 01, 2005 2:42 pm
I think the Mechanism involved in the Folding of the wings would also have contributed to unwanted Weight.
regds
MEL
Tue Aug 02, 2005 12:12 am
Oops, didn't mean to do that. I knew you were only referring to Boeing.
Users browsing this forum: Google [Bot] and 14 guests
