Corsair2
Cockpit Displays In B717
Thu Aug 11, 2005 3:44 am
What avionics display suite (i.e. Honeywell, Collins,etc) is installed in the Boeing 717 that provides the PFD, MFD, and EICAS display? Also what type of technology is it? (i.e. CRT, flat panel LED)
"We have clearance Clarence. Roger, Roger. What's our vector Victor?"
pilotpip
Thu Aug 11, 2005 10:57 am
It's the exact same system that's in the MD-11. On the overhead panel, were there were supposed to be switches for three systems (three engines) one of the switches is omitted.
DMI
Derik737
Thu Aug 11, 2005 10:58 am
It's Honeywell and I believe it's flat panel LCD.
MD95
Fri Aug 12, 2005 5:44 am
I can confirm they are Honeywell and they are LCD and the are the same as the MD11 and MD90.
dario
KFLLCFII
Fri Aug 12, 2005 9:04 am
Quoting Md95 (Reply 3):
Photo © Sam Chui
Photo © Ben Wang
MD-11 on the left, MD-90 on the right. Same?
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
N243NW
Fri Aug 12, 2005 9:28 am
Quoting KFLLCFII (Reply 4):
What I'm sure Md95 was talking about are the MD-90s that were specially outfitted with the Honeywell 6-display EFIS for Saudi Arabian Airlines. You are right, though; the vast majority of the -90s out there have the standard MD-88 flight deck with very few modifications.
-N243NW bigthumbsup
LMP737
Fri Aug 12, 2005 9:37 am
Quoting N243NW (Reply 5):
Another "commonality" between the 717 and Saudi Arabian MD-90 is that both use the Honeywell VIA system (Versatile Integrated Avionics).
gigneil
Sat Aug 13, 2005 12:31 pm
The MD-11's displays are CRT... otherwise, very similar.
N
amtrosie
RE: Cockpit Displays In B717
Sun Aug 14, 2005 2:05 am
The six display "screens" are LCD's and the MCDU's(2) are CRT's. The whole suite is Honeywells. Thus ends the alphabet soup description from the tech. manual
Boeing7E7
Tue Aug 16, 2005 7:10 am
The system has more in comon with the 737 and 777 than an MD bird...
http://www.honeywellaes.com/servlet/...tionServlet?heading=at&Operation=7
Honeywell’s Versatile Integrated Avionics (VIA) platform is an LRU-based system derivative of the Airplane Information Management System developed for the Boeing 777. Certified on the Boeing 737NG for flight display functions, VIA is additionally certified on Boeing 717 and MD10 aircraft for flight management, flight displays and fault warning. With a common hardware/software architecture, VIA is configurable to meet the needs of a variety of avionics applications. Lockstep processing for cycle-to-cycle concurrent monitoring and an ARINC 659 fail-passive communications path are among the features that assure high integrity processing for flight critical functions. The VIA architecture provides support without the expense of hardware voting monitors. Robust time and space partitioning (provided by hardware, ARINC 653 O/S and qualified tools) give VIA the flexibility to integrate multiple flight functions in one box.
[Edited 2005-08-16 00:14:10]
Users browsing this forum: Canuck600, INFINITI329, Murf, TZTriStar500 and 39 guests
