B752 LE Slat Rotary Actuator O'load Indicator Pin
Fri Aug 19, 2005 10:08 pm
Anyone with Information on the Red Overload Indicator pins on the LE Slat Rotary Actuator.What circumstamces causes its indication & how is it reset.
Any Photos.
regds
MEL
dl757md
RE: B752 LE Slat Rotary Actuator O'load Indicator Pin
Sat Aug 20, 2005 12:50 am
They are simply pushed in and they usually indicate a bad or underserviced actuator. Sometimes inadequate lubrication of the slat tracks and rollers is the culprit.
Dl757Md
air2gxs
Sat Aug 20, 2005 1:49 am
Just push it in and determine the cause of the overload. As stated, it can be a bad actuator or more likely, the rollers and tracks are getting dry.
avioniker
Sat Aug 20, 2005 2:25 am
One thing to keep in mind, the overload could have been caused by any of the system parts anywhere downstream of the popped pin. If you have the older magnetically latched type it might be simply a firmer than normal landing.
Every company has adopted their own procedures for dealing with the pins being popped from "just push it in" to a complete friction/torque check and everything in between. Make sure your company doesn't have some sort of monitoring requirement before you just sign it off.
I haven't seen you asking questions about the 757's before. Here's a fair starting point
http://www.757.org.uk/index.html
Good luck
 Smile
cdfmxtech
Sat Aug 20, 2005 3:01 am
Quoting Avioniker (Reply 3):
That site has sure come a long way!
Sat Aug 20, 2005 6:26 pm
Thanks Folks.
Have been asking a few last few months.
My Company might get B752SFs next year,So was doing some Advanced Studies.So many doubts keep creeping up.So I might have a lot more questions on the B752s in the next year until I get my notes or work Practically on the Bird  Smile
Any Photographs of the Pin.
BTW Thanks for the link.
regds
MEL
Users browsing this forum: radarvector, SJL and 1 guest
