EI321
MIN Runway Length Required For A330 And 777?
Sat Sep 03, 2005 7:22 am
Im trying to find the following info. What is the minimum take off distance required for the following aircraft, fully loaded, in normal conditions (average temp, wind and height above sea level)?
A332
A333
A343
A345 inc HGW version
A346
A350?
777 - all versions
787?
I cant find any of this on Airbus websit and little on Boeings site.
EI321
dw747400
RE: MIN Runway Length Required For A330 And 777?
Sat Sep 03, 2005 9:22 am
Looking around http://www.boeing.com/assocproducts/aircompat/plan_manuals.html should give you the information you need on Boeing aircraft. I'm not sure where to get similar information about Airbus.
CFI--Certfied Freakin Idiot
MD11junkie
Sat Sep 03, 2005 7:15 pm
Quoting EI321 (Thread starter):
Doesn't the FAA issue this "minimum runway length requirement" when it certifies the aircraft?
Cheers! wave
Gastón - The MD-11 Junkie
There is no such thing as Boeing vs Airbus as the queen of the skies has three engines, winglets and the sweetest nose!
OldAeroGuy
Sun Sep 04, 2005 7:01 am
Quoting MD11junkie (Reply 2):
No
LAXintl
Mon Sep 05, 2005 7:02 pm
One operater of a B777 wont operate the type to less then 7,000ft runways.
Not a Boeing limit, but a company policy.
NASBWI
Sat Jul 03, 2010 7:56 pm
I tried a quick search and found this from Boeing's website (PDF):
http://www.boeing.com/commercial/airports/acaps/777rsec3.pdf
It seems that from the graph shown on figure 3.3.1, most 777s (all versions) can, with minimum payload, leave the ground at just over 5,000 ft (I could be reading it incorrectly, however). Those numbers, of course, vary depending on weight, temperature/pressure, and altitude of the airfield - as well as flap usage (flaps 5/15/20). Hope this is helpful!
Fierce, Fabulous, and Flawless ;)
Users browsing this forum: mmo and 1 guest
