Arniepie
737-200 Number Of Fuel Tanks
Thu Sep 08, 2005 3:16 am
Can anyone plz tell me how many fuel tanks there are on a 737-200 (+location) and how much fuel they contain?
P.S.
Is there a website somewhere where I could find things out about aircraft technical issues, I mean statistics and drawings?
[edit post]
miamiair
RE: 737-200 Number Of Fuel Tanks
Thu Sep 08, 2005 3:49 am
Two integral wing tanks holding 1,430 gal each (9,580LB) and a center tank that holds 2303 gal (15,430LB). There is a provision for an aux tank that holds 810 Gal (5,429LB) in aft baggage.
Matt72033
Thu Sep 08, 2005 4:13 am
Arniepie
Thu Sep 08, 2005 4:46 am
Much appreciated both of you.
I needed it to rewrite the flightcaracteristics on the FFX-SGA737-200 for msfs.
[edit post]
OPNLguy
Thu Sep 08, 2005 5:39 am
Keep in mind there are -two- types of 737-200s...
The original was a 737-200 "Basic" aircraft. The fuel tank info provided by someone earlier was for the newer (and more popular) 737-200 "Advanced" or "ADV". The "ADV" became the standard pruction aircraft after about 1973-1974, IIRC... Southwest started with "Basics" and swapped them out with "ADVs" in the first few years...
The fuel capacity on the "Basics" was less than the "ADV" and I seem to recall that the max capacity was around 23.000 lbs by use of one of those aux tanks.
Max weights for the aircraft were different as well.
amtrosie
Thu Sep 08, 2005 11:36 am
There are several aircraft out there that have added the PATS system STC allowing for additional fuel tanks (auxliary) that are placed in the fwd. or aft cargo compt. and have a capacity of 500 gal. each.
Thu Sep 08, 2005 2:44 pm
NZ1
Crew
Mon Sep 12, 2005 7:11 pm
Did the original 732 have the same JT8 engines as the Adv model??
NZ1
NZ1
Head Forum Moderator
Mon Sep 12, 2005 10:38 pm
Quoting NZ1 (Reply 7):
Basic had Two 64.5kN (14,500lb) JT8D-9As.
Advanced had two 68.9kN (15,500lb) JT8D-15s, or two 71.2kN (16,000lb) JT8D-17s,17As, or two 77.4kN (17,400lb) JT8D-17Rs with automatic reverse thrust.
regds
MEL
Users browsing this forum: 767333ER and 1 guest
