lastordu
Some Thing About Numbers
Sat Sep 10, 2005 1:57 am
I know that one knot is 1.15mph(that could be wrong). Dose anyone know how to covert mach in to knots or what ever.
"Remember, Remember the 5th of November" from V for Vendetta
curlyheadboy
RE: Some Thing About Numbers
Sat Sep 10, 2005 2:10 am
Quoting Lastordu (Thread starter):
Mach refers to the speed of sound, the speed of sound depends on air density and so varies with altitude. I'm sure someone can put this down a lot better though  Smile
If God had wanted men to fly he would have given them more money...
Jetlagged
Sat Sep 10, 2005 2:14 am
First you need to calculate the speed of sound, a. This is proportional to ambient temperature (OAT):
a = SQRT( OAT * 287 * 1.4) m/s (where OAT is in deg K)
Convert this speed into whatever units your true airspeed is in (mph, knots, etc.). Note this must be true airspeed, not indicated.
Mach number = TAS/a
BTW 1.15 is close enough for practical purposes to convert mph to knots.
dl757md
Sat Sep 10, 2005 2:50 am
Try this.
Dl757Md
Pihero
Sat Sep 10, 2005 3:37 am
There is a much simpler way, valid for subsonic aircraft, that I still use to check my instruments, as it is easily done mentally.
To get a true airspeed (in knots) from a mach number, take as basis a temperature of -35 degrees celsius.At that temperature, the airspeed is exactly equal to the Mach number x 600. Then add or substract 1 kt per degree, rerspectively above or below your -35° basis.
As our mach reading are presented with three digits after the decimal, I just multiply that figure by .6.
Example :Mach .845 and OAT -45° c.
.845 x.6 = 507 kts, from which I substract 10 kts, as -45° c is ten degrees colder than my -35° c basis.
Result : TAS = 497 kts.
It's surprisingly accurate.
Contrail designer
Users browsing this forum: No registered users and 16 guests
