Stealthz
QF 734 - Strange Marks?
Sun Sep 11, 2005 7:43 pm
Hi all,
A friend of mine took this photo Friday, He is(I am as well) curious as to what these marks on the rear fuselage may be.
The grey lines..
http://www.pbase.com/chrisg/image/49072373.jpg
Chris
RE: QF 734 - Strange Marks?
Mon Sep 12, 2005 2:22 am
Could it be a part of a new Livery/Paint Scheme,Or some Mod comming up [Creasebeam].
Photo © David Knudsen
Photo © Chris Van Lint
Not Visable on these Pics too.
regds
MEL
[Edited 2005-09-11 19:34:59]
RedDragon
Mon Sep 12, 2005 3:11 am
This reminds me of the marks on some ancient FR 732s:
Photo © Steven Grace
Photo © Fred Seggie - WorldAirImages
Photo © Gary Watt - AirTeamImages
The upper mark on the QF bird appears like it might be running along the top of the window belt, as the FR marks do.
Incidentally, the second FR picture caption reads "This is one of four grounded Ryanair 737-200's at Prestwick due to scratching of the fuselage that was discovered during maintenance checks". You'd have to hope that the scratching that caused the grounding wasn't the incredibly obvious lines that would hardly need "maintenance checks" to notice, wouldn't you?  Smile Or was it just a question of the severity of the damage?
Rich
AR1300
Mon Sep 12, 2005 7:55 am
looks like worn out paint, IMO.  Smile
Mike
You are now free to move about the cabin
rendezvous
Mon Sep 12, 2005 8:42 am
Do you have to remove some of the paint in order to check the joins properly?
Mon Sep 12, 2005 4:12 pm
Quoting Rendezvous (Reply 4):
Ultrasonic testers work fine.
I Feel the lines are the ends of a Structural repair carried out.Anyone with Different angle views. Or Worn Paint.
regds
MEL
NZ1
Head Moderator
Mon Sep 12, 2005 7:07 pm
It is an area over the lap joints that has been paintstripped for inspection purposes. Our aircraft have had the same thing done recently to inspect for corrosion over a similar area, though at the front of the aircraft.
NZ1
NZ1
Head Forum Moderator
Mon Sep 12, 2005 10:34 pm
Quoting NZ1 (Reply 6):
Any Details on the Inspection.Why wasn't it recoated after check.
regds
MEL
jumbojim747
Tue Sep 13, 2005 6:54 am
Quoting HAWK21M (Reply 7):
that's what i was going to ask.
Having bare metal is not a good idea as i know it.
On a wing and a prayer
RedDragon
Tue Sep 13, 2005 6:59 am
Presumably in the case of my grounded 732s then, the sequence went: paint stripped, damage found, aircraft in doghouse.
I'd wondered where these mythical lap joints were...
Rich
Tue Sep 13, 2005 9:07 pm
This is one Interesting Topic.Im curious & Eager to know the Answer.
regds
MEL
miamiair
Tue Sep 13, 2005 10:08 pm
I doubt that they are bare. It looks like some sort of lap seam inspection for S-10L & S-20L. Curious why they left out S-14L. Standard parctice is to re-seal the lap seam if the sealant was removed, and at the very least, prime it with BMS-10-11 primer (which is green).
jumbojim747
Wed Sep 14, 2005 12:18 pm
Quoting HAWK21M (Reply 10):
So am i as I've always been told that the paint helps in the strengthening of the aircraft because the metal is so thin.
Quoting Miamiair (Reply 11):
I was wondering the same thing why wasn't it primered.
RedDragon
Thu Sep 15, 2005 3:34 am
Quoting JumboJim747 (Reply 12):
Er, try strengthening something with paint. And then look at an AA aircraft.
 Wink
NZ1
Head Moderator
Sun Sep 18, 2005 2:36 pm
I must admit it is strange, as our aircraft had 3M adhesive film applied over the bare patches until their next inspection, to protect the bare metal surface.
While I can't speak for QF, the inspection on our aircraft was due to knife marks, and corrosion from previous decal applications. The operator had obvious;y used a stanley knife to trim them, and damged the skin at the same time.
NZ1
NZ1
Sun Sep 18, 2005 10:27 pm
Quoting NZ1 (Reply 14):
This looks much more different.Its def a Structural Repair related.Maybe I'll take a pic to Work & try to get some Answers.This is one tough doubt.
regds
MEL
Wed Sep 21, 2005 5:10 pm
Quoting HAWK21M (Reply 15):
Not much luck.
Most ppl opinion is if its a Repair.Why was it not Finished totally.This is one Tricky Post.
regds
MEL
MD11Engineer
Wed Sep 21, 2005 5:43 pm
To me it looks as if the joints have been sealed but not yet painted over.
Jan
Wed Sep 21, 2005 6:16 pm
Quoting MD11Engineer (Reply 17):
Exactly.But is that Advisable.
regds
MEL
miamiair
Wed Sep 21, 2005 8:22 pm
Quoting HAWK21M (Reply 18):
Is what advisable? Sealing and not painting? IMO, sealing is the bare minimum. Some primer would be nice.
ps, try using question marks (?).
Wed Sep 21, 2005 9:24 pm
Quoting Miamiair (Reply 19):
Exactly to reduce corrosion.
Not until 31st Dec 2006.Its a long story  Smile
regds
MEL
Users browsing this forum: Bing [Bot], BlatantEcho, KGRB, meecrob, NPeterman, PSAjet17 and 25 guests
