yegbey01
How Do Airports Name Runways
Mon Sep 12, 2005 1:30 am
I was just thinking..hoe does an airport decide what to label a runways (15, 24...)
thanks
brokenrecord
RE: How Do Airports Name Runways
Mon Sep 12, 2005 1:35 am
It is based on their direction in degrees.
I.E., Rwy. 15 is 150 degrees North-West. From the other direction, it would be Rwy. 33, at 330 degrees South-East.
If there are parallel runways, then the L or R designation is tacked on to indicate left or right.
zrs70
The numbers are compass headings:
11 = 110 degrees
18 = 180 degrees
If there are parallel runways, then you would see:
25L
25R
If there are more than two parallels, then one (set) will be off by a degree.
[Edited 2005-09-11 18:39:55]
18 year airliners.net vet! 2000-2017
HaveBlue
Mon Sep 12, 2005 1:42 am
Runways are named by their magnetic heading, and the last digit is dropped. For instance Runway 25 is on a magnetic heading of 250. That is also why the same runway, approached from the opposite direction will be 180' different. So at DAB here its runway 25 if approaching from the east, and the same runway is runway 7 if approaching from the west. 70 (Rnwy 7) +180 = 250(Rnwy 25).
If there is parallel runways, such as here at DAB, then you have 25L and 25R, or 25 left and 25 right, and its reciprical 7L and 7R.
If there is more than 2 parallel runways, then you get, for example, Runway 9L, 9C, 9R or 9 left, center and right.
Where some people get confused is a situation like Orlando where you have 4 or more parallels. MCO has 4 runways with a 18/36 heading, but are labelled as 18L, 18C, 18R and 17. They all share the same heading but starting with the 4th runway they will name it 10' off for clarities purpose.
And runway names will change occassionally. Magnetic north changes slightly over time, and so every so often the runways will be renamed to the correct value as it shifts.
Hope this helps.
Here Here for Severe Clear!
brokenrecord
Haven't we all just said basically the same thing? :-P
yegbey01
Mon Sep 12, 2005 1:50 am
Thanks guys! very helpful
Mon Sep 12, 2005 2:00 am
Quoting Zrs70 (Reply 2):
Quoting HaveBlue (Reply 3):
As HaveBlue says More than Three Parallel runways,not Two necessatite the 4th to be offset by one Degree in naming.Remember C is still an option.
regds
MEL
Qantas744er
Mon Sep 12, 2005 2:10 am
If you had 5 parallel runways you could just call them 9Left, 9Center Left, 9Center, 9Ceter Right, 9Right. LOL
Cheers Leo
[Edited 2005-09-11 19:12:03]
You live and you die, by the FMA
brokenrecord
Mon Sep 12, 2005 2:57 am
HAHA good thought Qantas...
I can imagine ATC at an airport with that setup would be a nightmare...
HaveBlue
Mon Sep 12, 2005 10:19 am
Quoting Qantas744ER (Reply 7):
It would be more like 9L, 9C, 9R, 8L and 8R.
Quoting HAWK21M (Reply 6):
Not by one degree, but by 10 degrees. By one number maybe, as in 9 going to 8, but that represents 10 degrees, 90 to 80.
Mon Sep 12, 2005 4:07 pm
Quoting HaveBlue (Reply 9):
Thats correct.
 bigthumbsup
regds
MEL
vikkyvik
Mon Sep 12, 2005 5:34 pm
One should keep in mind, however, that though a 3rd parallel runway does not necessitate a different number, it is done anyway, especially in the case of airports with two distinct sets of runways that have the same heading. Examples:
LAX: 7L/25R, 7R/25L, 6L/25R, 6R/25L
DTW: 3L/21R, 3R/21L, 4L/22R, 4R/22L
PHX: 7L/25R, 7R/25L, 8/26
ATL: 8L/26R, 8R/26L, 9L/27R, 9R/27L (though with construction of another runway, I'm assuming there will be a 9L/27R, 9C/27C, and 9R/27L)
DEN: 16L/34R, 16R/34L, 17L/35R, 17R/35L
~Vik
jimpop
Mon Sep 12, 2005 6:56 pm
Quoting Vikkyvik (Reply 11):
I was just wondering about this the other day. The new 5th runway in ATL is a bit of a distance from the 8/26 pair. I don't think it would make good sense to change 8R/26L to 8C/26C, just to re-establish 8R/26L as the new runway, as I think this would cause a bit of confusion (not that it doesn't exist already today  cheerful  Wink. Wouldn't this be a good reason for using 7/25?
Tornado82
Tue Sep 13, 2005 1:40 am
Why? You could put them at 86, and call those the 9L/R/C, and then at 84 and call them the 8L/R/C, right? 2 degrees of difference would be alot less problematic geographically/geometrically than 10.
BR076
Tue Sep 13, 2005 5:21 am
Quoting Brokenrecord (Reply 4):
It must have be something to do with your username Big grin
ú
atlamt
Tue Sep 13, 2005 6:01 am
Quoting Jimpop (Reply 12):
The FAA allowed ATL to use 10/28 for the fifth runway. Left to right during an approach 10/28 makes the most sense. You've got 8L/R 9L/R 10 and 28 27L/R 26L/R.
Fwd to MCO and Placard
flyf15
Tue Sep 13, 2005 7:42 am
Remember, there are other designations for runways aswell. E/W/N/S for the cardinal directions, G for glider, etc.
Feasibly, you could have 18W/36W, 18L/36R, 18C/36C, 18R/36L, 18E/36E.
At my local airport, we have two parallels, 8G/26G and 8/26. 8G/26G is a glider runway while 8/26 is the normal powered runway.
vikkyvik
Wed Sep 14, 2005 1:08 am
Quoting Flyf15 (Reply 16):
Interesting, I never knew that. SO E/W/N/S would designate the easternmost/westernmost/northernmost/southernmost runways? Or runways whose heading is directly east/west/north/south?
Meaning, would it be 9E/27W (due east/west), or 18E/36E (easternmost runway)?
~Vik
Jetlagged
Wed Sep 14, 2005 3:58 am
Quoting Tornado82 (Reply 13):
The runways aren't physically aligned on a different heading. Usually they will all have the same heading. It's only the runway designation which changes by one digit (10 degrees) either way. The approach plate will show the actual inbound heading to use to the nearest degree.
timz
Wed Sep 14, 2005 4:35 am
So does any airport use E/W or N/S instead of R/C/L?
lorm
Wed Sep 14, 2005 4:59 am
ANC had an interesting runway number choice until this June or July. Previously the two parallels were 6L/24R 6R/24L, both with a 068 degree heading. The numbering was changed to 7L/25R 7R/25L. On one of the audio archives from the liveatc archives, a pilot asked the tower how the new runways were working out..... in jest of course.  Smile
Brick Windows
unattendedbag
Wed Sep 14, 2005 6:09 am
you sure about that? It should be 6L/24R and 6R/24L.
Slower traffic, keep right
vikkyvik
Wed Sep 14, 2005 11:32 am
Quoting UnattendedBag (Reply 21):
Whoops, sorry about that. I thought I checked over all the runway numbers I typed, too. Oh well, thanks.
~Vik
citationjet
Thu Sep 15, 2005 8:42 am
LHR is one of the few recent examples where runways have had to be renumbered because of magnetic variation. They used to be angled 275/095 degrees, meaning they were numbered 28R/10L and 28L/10R. However due to magnetic variation the direction now is 274 degrees so they were renumbered.
http://www.airliners.net/discussions...eral_aviation/read.main/1832780/4/
Reply 13.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
Jetlagged
Thu Sep 15, 2005 12:00 pm
Miami's runways were renumbered when the third parallel runway was added.
27L/09R became 27/09
27R/09L became 26L/08R
The new runway was designated 26R/08L
Not sure why they chose to designate the existing runways as they did, other than to ensure the two runways closest together (the new one and the old 27R/09L) had the same heading numbers.
Buyantukhaa
Thu Sep 15, 2005 10:12 pm
Well, everybody's talking about numbers, but the title says "naming" runways. To my knowledge, only AMS gives real names to its runways (Buitenveldertbaan, Kaagbaan, Aalsmeerbaan, Zwanenburgbaan, Polderbaan, Oostbaan).
Anyone knows another example?
I scratch my head, therefore I am.
ZRH
Fri Sep 16, 2005 3:54 am
Quoting BuyantUkhaa (Reply 25):
Yes, in Zurich the runways have names, I am not sure if they are official:
16-34 is "Blindlandepiste" (blind-landing-runway) because it was the runway which had the first ILS many decades ago. 14-32 is "V-Piste" because it forms a V with the 16-34. 10-28 is simply "Westpiste" (west runway).
bond007
Sat Sep 17, 2005 1:08 am
yes, and the question was ....
Quoting Yegbey01 (Thread starter):
Or didn't you actually read the question  Smile
At least from an FAA standpoint anyway, runway naming implies the 'numbering' of runways.
Jimbo
