TimePilot
Flashing Red Lights On Bottom Of Aircraft
Mon Sep 12, 2005 9:58 pm
(A question similar to this one: Rotating Red Lights On Fuselage & Blinking Ones (by Vimanav Aug 26 2003 in Tech Ops))
Are those lights called strobes? Or are strobes just the lights on the wing tips? Also do the red lights on the bottom rotate (like a fire engine's lights) when on the ground, then flash when up in the air? I seem to have noticed that.
DColeMAN
RE: Flashing Red Lights On Bottom Of Aircraft
Mon Sep 12, 2005 10:12 pm
That's right. The two flashing red lights on the top and bottom of the fuselage are the beacon lights and the white one's on on each wing tip are the strobe lights.
As far as I know it seems to be the older aircraft have rotating beacon light/s? Correct me if I'm wrong on that one.
Dale
Topless Women Drink 4 Free
AR1300
Mon Sep 12, 2005 10:19 pm
The strobes are the white flashing ones in the wingtips.
The Navigation lights are the red & green in the wingtips.
The beacon is that red one that you say, and is indeed used to tell that the engines are running.
Quoting TimePilot (Thread starter):
No, it rotates also in the air, but you don't notice it because you wont see that ''going around'' thing that reflexes on the ground, instead, if you are looking sideways and it's spinning, you'll see it go on and off cause you see the back part when its spinning and its pointing to the other side, thus making it look like flashing from the distance. I tried to be as clear as I could.  Smile
Mike
You are now free to move about the cabin
Mon Sep 12, 2005 10:48 pm
Quoting AR1300 (Reply 2):
Reffered to as the Anti collosion lights.
regds
MEL
aogdesk
Tue Sep 13, 2005 1:33 am
Pay heed to those anti-collision (beacon) lights. I've seen a few baggage carts get toppled after a careless ramper drove behind a running engine or two.
AsstChiefMark
Tue Sep 13, 2005 3:06 am
Strobes are a type of lighting system. You can have strobe beacons, rotating incandescent beacons, flashing incandescent beacons, and LED beacons. Similarly, you can have wingtip strobes, wingtip oscillating incandescent lights, wingtip flashing incandescent lights, and wingtip LED lights.
The bottom line: Not all beacons rotate and not all wingtip lights are strobes.
Here's a strobe tube:
Here's a strobe beacon:
Here's an incandescent bulb:
Here's an LED beacon:
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
Matt72033
Tue Sep 13, 2005 4:45 am
or the aircraft is a bout to move right?? we have beacons on when we tow aircraft, no engines running!!
northseatiger
Tue Sep 13, 2005 5:16 am
At my company you know when the a/c is about to taxi because they put the fixed floods on, when towing the a/c the anti-coll is switched on, this is also switched on prior to start, never heard of it refering to engines being running, the red and green lights at the a/c port/starboard side are nav lights or ordnance lights (including the white light at aft of a/c (reversing light)) the white flashing ones are strobes and red flashing/rotating are anti collision lights.
T's And P's look good....Rotate
TimePilot
Tue Sep 13, 2005 8:07 am
Gotcha'
And a quick refresher- green on the left wing, red on the right? And old flight sim manual said it was so that other aircraft could tell which direction the aircraft was flying in.
DC8FriendShip
Tue Sep 13, 2005 7:16 pm
Red on Left, Green on right. If you see a green light, he's flying from your left to your right. If its red hes flying from your right to left. If its white he's flying away from you, and if it's Green on your left and red on your right, then watch out 'cause he's coming straight at you!
Come fly the Friendly Skies of United
FredT
Tue Sep 13, 2005 7:26 pm
Mnemonic: "There's no red port left".
The rotating beacons on is the indication rampers are looking at to see if the engines are running. Pilots messing this up better be careful during their walk-around... I once got a dose of hot air down my neck when putting the blocks on an aircraft where they had turned off the beacons prematurely, and I was not a happy camper.
Tue Sep 13, 2005 8:31 pm
Quoting TimePilot (Reply 8):
Red on Port,Green on Starboard Wingtip.
Out here.Anticols are switched on as a reminder to personnel on grd that some system is being operated/Engines starting/Aircraft moving.
regds
MEL
AR1300
Wed Sep 14, 2005 9:10 am
Quoting Matt72033 (Reply 6):
maybe it means that they are about to turn them on! Big grin
Mike
Wed Sep 14, 2005 4:50 pm
Quoting AR1300 (Reply 12):
Mik
Means.Caution,some Mx related work in progress on the Aircraft  Smile
regds
MEL
Matt72033
Wed Sep 14, 2005 4:54 pm
no, we taxi from line to hangar, no engines at all!
Mir
Wed Sep 14, 2005 7:20 pm
Quoting HAWK21M (Reply 3):
At my flight school, the strobes are referred to as anti-collision lights (as part of a mnemonic for what is required for night flight). The Warriors that are used don't have beacon lights at all - the strobes are used during the day, and the navigation lights are used at night.
I've always used the terms beacon and strobes to avoid confusion.
-Mir
Users browsing this forum: fr8mech, frmrCapCadet, Okcflyer, zaphod42 and 2 guests
