AmericanB763ER
"Double Bubble" Vs. Circular Cross Section
Mon Sep 19, 2005 4:17 am
I have done a search on this subject but it didn't return anything to my satisfaction so here goes (quite a simple question):
What's the benefit of a circular fuselage cross section vs. a "double-bubble"-layout. It almost seems to me the circular version is gaining ground as most of the newer aircraft types (all the airbus types + the 777) have that one (OK Emb170/190 and the A380 are exceptions here) - as opposed to the "double-bubble" found on the 767, the older Boeings + Douglas types which have a more or less visible "kink" between the cabin and the cargo hold? Sure there must be aerodynamic reasons behind this.
Photo © Javier F. Bobadilla - Iberian Spotters
Photo © Maartenw
Photo © Jeroen Hribar
Photo © Robert Matthews - FliteZoneImages
Photo © Denis Roschlau
Photo © Eduard Brantjes
Marco
411A
RE: "Double Bubble" Vs. Circular Cross Section
Mon Sep 19, 2005 5:20 am
No, not aerodynamics, just the desire to utilize older tooling left over from previous designs.
Boeing...for example.
The first truly sucessful design for very long range flights (Stratocruiser) used the B29 design plus an extra fuselage lobe, to enhance passenger appeal/space.
This was then ingrained in Boeing thinking, as it is slightly less expensive to design a double lobe fuselage, for the required space desired, yet keep the structure weight down.
This was carried over to the B707 design...and beyond.
Circular is all well and good, but it would appear that some may disagree.
Douglas, for example, when they developed the DC6.
The fuselage might look circular, but it is not (slightly taller than wide) and this was specifically done so that passengers would have more head/shoulder room.
How do I know?
My dear old Dad was the engineering project manager...DC6/DC7.
And, DC8.
Dougloid
Mon Sep 19, 2005 6:46 am
Quoting 411A (Reply 1):
The Curtiss C46 had a double bubble fuselage but I do not know what the range was....I remember putting my old man on a Stratocruiser for a flight to the UK back in 1956....
mrocktor
Mon Sep 19, 2005 10:16 am
This is not correct. The E170 cross section is a double bubble, and there was no use of old tooling whatsoever. The explanation lies in balancing the desired internal dimensions (pax cabin and cargo compartment) against the drag generated by the fuselage.
To fit the desired dimensions of the E170 into a circular cross-section would mean a significantly larger frontal area and commesurate increase in drag. The same goes for the A380, if the fuselage were circular it would be huge with a lot more volume than necessary, with the extra volume in places that are not practical to use.
The tradeoff is that a non-circular cross section will increase the weight of the fuselage slightly, since a circular section is the ideal shape to resist the pressurization loads.
Several other factors affect the cross section, such as the inclination of the "walls" in the passenger cabin (you want them to be as close as possible to vertical in the area adjoining the seats) and the required volumes for systems.
The crew rest areas in the 777 are a good example of using otherwise unproductive space in a circular cross section.
mrocktor
pilotpip
Mon Sep 19, 2005 11:32 am
The "double-bubble" is also a good marketing tool. Embraer has used this heavily to show the 170/190 family have a larger passenger cabin which would be appealing to Joe Public.
DMI
AmericanB763ER
Tue Sep 20, 2005 2:19 am
so in the end whatever cross section a manufacturer goes for- each one has its advantages + shortcomings.
Thanks to you all for your replies.
Btw the Vanguard/Merchantman is another great example for a double-bubble - just look how high above the ground the pax door is despite the low sitting fuselage.
Photo © Günter Grondstein
Photo © Brian Robbins
UAL747
Tue Sep 20, 2005 7:24 am
So am I to assume, aerodynamics and structural maters aside, that in fact in a perfect world for cargo and passengers, the best cross section design would be a square?
UAL
2H4
Tue Sep 20, 2005 7:53 am
Quoting UAL747 (Reply 6):
Shorts certainly thought so:
Photo © Danny Fritsche - Airplanespotters
Photo © Joule
Photo © E.S
Photo © Peter Unmuth - VAP
2H4
Intentionally Left Blank
ZSOFN
Tue Sep 20, 2005 8:41 am
One issue not raised is that of pressure. Obviously the most resistant cross sectional shape to the pressures of the cabin vs external pressures in high altitude flight is the circle. So with a "double bubble" are there weaknesses/pressure points to overcome? Are they serious considerations?
Jetlagged
Tue Sep 20, 2005 11:49 am
Quoting ZSOFN (Reply 8):
Mroctor touch upon this in reply 3. It is a factor in the design decision, which will be a trade off with other demands. Also there can be in service issues, such as the 747 fatigue problems in the area where the forward fuelage is not circular (resulting in section 41 mods).
Where the cabin shape is not circular the skin will not be in pure tension, but will have bending loads as well trying to force the skin circular. Either the cabin structure will have to be heavier, or the differential pressure limit will be less. It's possible that the shape can lead to local stress concentrations which will lead to premature fatigue failure.
Aviation
Tue Sep 20, 2005 1:09 pm
Here is the ultimate Double-Bubble design:
Photo © Ralph M. Pettersen
StratoFreighter is the ultimate in the double bubble design
Aaron J Nicoli
Signed, Aaron Nicoli - Trans World Airlines Collector
HiFi
Tue Sep 20, 2005 10:08 pm
With a double-bubble, your fuselage is usually heavier, since it needs to be thicker.. Internal volume is reduced (but of course you have the second bubble to add even more volume than with a simple circular cross-section).
no commercial potential
mrocktor
Tue Sep 20, 2005 10:48 pm
Quoting Jetlagged (Reply 9):
Exactly. Double bubble designs mitigate this issue by placing the "floor" at the level where the bubbles connect. The floor acts like a cross beam and helps to bear the pressure load. In a circular cross section the floor structure is practically unloaded.
Still, the double bubble design will be heavier than a circular design of the same internal volume. The thing is, sometimes the shape of the volume is very important. In airliner design you will be most likely comparing a larger circular cross section versus a smaller double bubble cross section - for the same useful volume.
It boils down to a drag vs weight vs manufacturing cost analysis.
mrocktor
zvezda
Thu Sep 22, 2005 6:23 am
In both circular and double-bubble (assuming the floor attaches exactly where the two bubbles meet) designs, the skin is simply in tension where metals are strongest. In other shapes (including the WhaleJet's ovoid), the pressure loads change the shape (not just the size) of the fuselage. Resisting such deformations requires extra strength which adds extra weight.
Note that the surface area/volume ratio is higher for a double-bubble than a circle. Increasing the surface area increases the weight. A circle would definitely be the best design if all the volume inside could be used effectively, but that is not always the case.
Also note that all the nearly square fuselage cross sections pictured above are unpressurized. A pressurized nearly square cross section would be excessively heavy.
LeanOfPeak
Thu Sep 22, 2005 7:32 am
Quoting Zvezda (Reply 13):
Witness the 3.3 psi differential pressure limit on the Cessna P337 and P210, 3.9 psi on the Beech 58P Baron, and 5.1 psi on the Piper Malibu/Mirage series, which rose to 5.5 psi for the Meridian.
Such low differential pressure limits are not practical for aircraft cruising at jet altitudes. Therefore, the shape of the cross-section becomes more important.
prebennorholm
Wed Sep 28, 2005 4:22 am
The A380 is a triple bubble design. It uses both floors as cross beams - one floor exactly at each junction between the three bubbles.
Neither double bubble nor triple bubble designs require extra strength, except that the floors must be designed to take the tension at the bubble junctions.
The A380 triple bubble design makes it a lausy outsize cargo plane. It needs the two floors to keep the three bubbles in perfect bubble shape. If anyone of the floors were removed the fuselage would break apart when pressurized.
The mostly circular fuselage on the 747 (especially with front loading door) is in a totally different league concerning outsize cargo. Even if the floor on the upper deck also is a cross beam on the forward double bubble part. The "problems" on the 747 is where the double bubble part blends gradually into the circular (single bubble) part. That is one very complicated piece of structure.
The British military Nimrod is also a very obvious double bubble, but different. The upper bubble is an ordinary Comet circular single bubble, and the lower bubble is not pressurized. No cross beam needed.
And the A300 Beluga: Not pressurized at all. Only the flight deck is pressurized.
Jetlagged
Fri Sep 30, 2005 12:49 pm
Quoting Prebennorholm (Reply 15):
I doubt that very much. The floor contributes to the strength of the structure, but is not a critical part of the design, or shouldn't be.
mrocktor
Sat Oct 01, 2005 5:29 am
Quoting Jetlagged (Reply 16):
All certification tests are performed with the floor in place, given the geometry, the floor is loaded - thus the floor's contribution is used for certification purposes.
Maybe the fuselage would not burst with the floor removed, since all structures are overdesigned by a specific safety margin, however the structure would certainly not meet certification specs without the floor.
mrocktor
[Edited 2005-09-30 22:30:45]
MD-90
Sat Oct 01, 2005 8:30 am
It wasn't much of a moneymaker, though. The DC-7 seemed to be better at that, although they all had the engine reliability issues (-7C, 1649A, Stratocruiser).
And I'm not sure if describing the A380 as a triple bubble design is quite accurate. I've lost the picture, but I saw a graphic (from Airbus) showing how they came up with the A380's cross-section. It was two large circles, with two smaller internally tangent circles. It basically is a double-bubble design.
stirling
Sun Oct 02, 2005 11:53 pm
Quoting Mrocktor (Reply 12):
Then that explains the differences I've felt underfoot walking in a B737 and A320....no one has been able to explain the "flimsier" feeling of the A320 when compared to the B737....until now. Now, it makes perfect sense.
I love how answers to questions get answered in such roundabout ways! Wink
Delete this User
Users browsing this forum: Alcaeus and 20 guests
