Glom
New Wings, Old Wings, Up Wings, Down Wings
Sat Oct 08, 2005 12:18 am
This matter seems to have caused a bit of confusion of late. What wings are new and what are tweaked?
I was under the impression that the 737NG had an all new wing, but others have recently said it was just tweaked. I definitely know the flaps are new.
I was also under the impression that the A340NG had an all new wing, partly because it wasn't designed as a compromise to allow either two or four engines to be used.
Many say the A350 has an all new wing, although some say it's just a tweaking of the flaps and slats.
Apparently the 747 has had the same wing since the start although the wingtips were changed for the -400 and for the ADV, which will also have new flaps.
The 787 is supposed to have a wing for the -3 and another for the -8 and -9. Are the wings totally different or is it just the wingtips?
The 777 and 767 have always used the same wing although the souped up variants got raked wingtips.
SlamClick
RE: New Wings, Old Wings, Up Wings, Down Wings
Sat Oct 08, 2005 4:05 am
737NG may have the same airfoil section, shape etc. (I don't know.) but it is absolutely, positively new sheet metal built in new jigs and whatnot. It is much longer and of considerably greater chord at any station than the original 737 wing.
OldAeroGuy
Sat Oct 08, 2005 4:41 am
Quoting SlamClick (Reply 1):
The airfoil is an improved, supercritical section. Consider that cruise speed went from .74M (Classic) to .80M (NG) while wing sweep was held at 25 deg.
phollingsworth
Sat Oct 08, 2005 5:28 am
Quoting Glom (Thread starter):
Two things change on the -3 wing over that for the -8 or -9. The -3 wing has the winglets versus the swept tips and uses thinner gage materials. The big aerodynamic difference between the -3 and the -8/9 is the larger vertical stabilizer with the tabbed rudder. This was, as I understand it, determined by an "icy/slippery" runway requirement.
TheSonntag
Sat Oct 08, 2005 6:55 am
I am no techician, but as far as I have read, the A340-600 wing is a modified wing with greater wing area, but it is not entirely new...
aeroweanie
Sat Oct 08, 2005 8:13 am
The 737NG has a brand new wing compared to the 737 Initial and Classics. The planform is different, with more chord and span and as OldAeroGuy indicated, the airfoils are improved.
I take it you are referring to the A340-500 and -600. This wing has a plug added to extend the chord, but otherwise the wing is the same as the earlier A340 models. The chord plug is rather novel - this has never been done before.
Its hard to know what the A350 wing will be. It started out as a minimum change A330 wing, but I think it started changing to gain performance.
The 747-400 has a span extension, along with winglets, that the earlier models didn't have. The SP had a simplified flap system. The ADV is supposed to gain a raked wing tip (replacing the winglets) and a trailing edge wedge.
Nothing official has been announced.
All 767 models share the same wing, except the -400, which has a raked wing tip added. Simlarly, all 777 models share the same wing, except the -300ER and -200LR, which have a raked tip added.
vikkyvik
Sat Oct 08, 2005 9:44 am
Quoting AeroWeanie (Reply 5):
The wingspan is also greater on the A345/346 than the A342/343, so there's gotta be something more than just an extended chord plug, right? A chord plug is pretty cool though...
~Vik
aeroweanie
Sat Oct 08, 2005 1:22 pm
Quoting Vikkyvik (Reply 6):
You're right - the A340-500/600 wing also has a span extension that I forgot about.
Sat Oct 08, 2005 2:08 pm
Apart from Deletion of the TE Fore flap what is the Mod.
Whats the new Flaps about.
Any Details.
regds
MEL
mrocktor
Sun Oct 09, 2005 1:27 am
Quoting AeroWeanie (Reply 7):
As far as I know, it has a plug at the root of the wing, which increases span and chord. The whole structure outboard of this plug is identical to the original A340 wing though - which is pretty clever from the industrial point of view.
mrocktor
aeroweanie
Sun Oct 09, 2005 4:13 am
Quoting Mrocktor (Reply 9):
The outboard structure of the A340-500/600 wing is not identical to the earlier A340 wing. To quote the a.net info page: "The wing is based on the A330/A340's but is 1.6m (5.2ft) longer and has a tapered wingbox insert, increasing wing area and fuel capacity." I've seen info on this tapered wingbox insert (a chord plug) in several engineering publications. Also, the wing has a tip extension, not a root plug.
Glom
Sun Oct 09, 2005 6:44 am
I suppose another question would be at what point does a wing become a complete redesign? We are talking about the swept supercritical variety these days. If they alter the chord, the length etc, at what point does that become sufficient for the wing to be called different rather than just modified?
phollingsworth
Mon Oct 10, 2005 1:41 am
The 200LR/300ER also have a modified trailing edge. Boeing borrowed this from the MD-11. It is easier to manufacture and actually produces less drag.
The MD-80 wing is a basic DC9-30 wing with a root plug. It is pretty obvious when looking at the wing where the plug is.
Quoting HAWK21M (Reply 8):
I think Boeing also changes the actuation mechanism. The old 737 has flap carriages that resembled those on the 727 and 747. I think Boeing went to a design that is more similar to the 757, 767, and 777, though I could be wrong.
As for a new wing. My metric is any time you change the airfoil substantially at every cross section.
David L
Mon Oct 10, 2005 2:35 am
Quoting Glom (Reply 11):
Very simple. According to many on the Civil Aviation discussions, if your favourite manufacturer changes the wing in any way it's all new but if "the other lot" do it, it's a desperate tweak of old technology.
mrocktor
Mon Oct 10, 2005 5:29 am
Quoting AeroWeanie (Reply 10):
Interesting, my sources are clearly wrong in this case.
mrocktor
gigneil
Mon Oct 10, 2005 5:38 am
Quoting TheSonntag (Reply 4):
See below.
Well, it is now going to be constructed almost entirely of composites, which is fairly new.  Smile
It also will feature the droop nose from the A380 which drastically improves low speed lift and replaces the inboard slats. The leading and trailing edges of the wing will be completely new. The winglet is also all new.
The 747-400ER's wing already features the trailing edge wedge... this will port to the ADV I have no doubt.
No it definitely has a root plug. This was as much for fuel capacity as it was for span.
Quoting Phollingsworth (Reply 12):
They don't, actually, feature the MD-11's trailing edge wedge or any other aerodynamic improvements other than the raked tips which add 13 feet to the total span.
N
aeroweanie
Tue Oct 11, 2005 1:28 am
Quoting Gigneil (Reply 15):
According to the drawing publisehd in Flight International in the June 12-18 2001 issue, there is a 1.6m wingtip extension, not a root plug. The 2001-2002 Jane's All The World's Aircraft concurs.
Users browsing this forum: BravoOne and 1 guest
