TheSonntag
Noise Levels Of The A380
Sat Oct 08, 2005 6:53 pm
Are the operational noise levels of the A380 already available? I heard it is pretty quiet for its size, but what about its absolute noise levels? Is it louder than a 747?
A342
RE: Noise Levels Of The A380
Sat Oct 08, 2005 11:09 pm
Quoting TheSonntag (Thread starter):
Do you mean the noise footprint on the ground ? I highly doubt it would be bigger than the 747´s one.
Exceptions confirm the rule.
Slarty
Sat Oct 08, 2005 11:11 pm
Quoting A342 (Reply 1):
I thought I read that it was actually quieter ... at least with the current engines  Smile
TaromA380
Sun Oct 09, 2005 7:54 pm
So, any data in that sense officialy available ?
gigneil
Mon Oct 10, 2005 5:05 am
The A380 is significantly quieter than the 747.
Its even quieter per pound of MTOW than the 777-200ER, and meets stricter QC levels if I'm not mistaken.
N
rendezvous
Wed Oct 12, 2005 12:18 pm
You'd imagine it would be with newer technologies and newer engines.
Wed Oct 12, 2005 4:18 pm
Whats the A380 Noise levels at T/O Thrust.
regds
MEL
Sinlock
Wed Oct 12, 2005 9:32 pm
Keep in mind that noise during landing is also a big factor. A time when engine settings are lower. Plus what power setting an engine is at also is a factor in the noise it makes, Just take the A320. At Idle on the ground the V2500 VERY quiet compared to it's CFM-56 sister. But on takeoff both are pretty equal, and anyone worth their salt can pick out a V2500 flying overhead, Hell my feiace can and she wouldn't know a A320 from 707 by sight. (I'm working on that)
Thu Oct 13, 2005 12:47 am
Quoting Sinlock (Reply 7):
Yeah the APU sounds louder  Smile
regds
MEL
airfoilsguy
Sat Oct 15, 2005 1:28 pm
I heard that the 380 is rather quiet. Since the engines on this plane are rather huge, they are much quieter then the 747. Typically, the larger the jet engine, the quieter it is due to the fact that it spins at a slower RPM.
It's not a near miss it's a near hit!!
TheSonntag
Sat Oct 15, 2005 10:05 pm
Quoting Airfoilsguy (Reply 9):
Yes, but the MD11 is still pretty loud compared to the much smaller A320, so while its relatively quiet for its size, it still makes a lot of sound, therefore I am really curious about the noise levels of the A380...
Sat Oct 15, 2005 10:17 pm
The "A380 Airplane Characteristics for Airport Planning" document has one answer.
http://www.content.airbusworld.com/S...a/docs/AC/DATA_CONSULT/AC_A380.pdf
Check section 6-2-1.
