scbriml
Tu-154 Pointy Thing
Wed Oct 12, 2005 6:11 am
Does the "pointy thing" at the top of the tail of a Tu-154 have a proper name?
Photo © Steve Brimley
Does anyone have any history on the "pointy thing"? I have some shots of very early 154s that I took in Russia in August where the "pointy thing" is very different.
RE: Tu-154 Pointy Thing
Wed Oct 12, 2005 7:04 am
It's to poke holes in A380s!!! Big grin
No seriously I think it's some sort of counterweight for the stab. Or something.
corey07850
Wed Oct 12, 2005 7:40 am
Looks like an HF antenna??? Maybe, perhaps???
320tech
Wed Oct 12, 2005 8:18 am
Well, the name is "bullet fairing" for the obvious reason. What it houses, I don't know. It might also just be aerodynamic.
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
prebennorholm
Wed Oct 12, 2005 8:23 am
No, Stallionblue, the pointy thing cannot house a tailplane balance weight. The pointy shape would not allow enough movements up and down. But it is almost sure that the top of the leading edge of the fin - where the sweep-back ends - contains a tailplane anti-flutter balance weight.
I think that the pointy thing has two purposes:
1. It gives some drag reduction by "area ruling" the otherwise rather draggy tailplane / fin intersection.
2. It houses the VHF antenna.
Looking at the MD-80 we see that area ruling thing done in a somewhat different way. In front of of the tailplane the leading edge of the fin is excessively thick and seems to slim down - or at least not get thicker - at the tailplane leading edge.
I am pretty sure that this feature produces a slight drag reduction compared to the DC-9 which seems to have a more or less unchanged fin airfoil section from root to tip. But only at high cruising speed where the DC-9 has a widening fin profile combimed with widening tailplane profile and that way may produce high, local transsonic drag.
MD-80
Photo © Vasanth Dharmarajan
DC-9
Photo © Remi Dallot
KevinL1011
Wed Oct 12, 2005 12:35 pm
Maybe is a jackscrew faring?
474218, Carl, You will be missed.
TripleDelta
Crew
Wed Oct 12, 2005 3:51 pm
As far as I know, it's an HF antenna, similar to the one on the 707, but faired in. Some other Russian aircraft, notably 60s-80s civil jets, have it as well:
Tu-134:
Photo © Alan Lebeda
Il-62:
Photo © Roel van der Velpen
Il-76 and Il-78:
Photo © Christian Waser
Photo © Voortmans Dirk
No plane, no gain.
Wed Oct 12, 2005 4:13 pm
Most likely an HF Antenna.
BTW How would the Horizontal Stablizer Srewjack rod be mounted.
regds
MEL
jush
Wed Oct 12, 2005 6:02 pm
no no HF antenna.! Defenitely the new anti missile system Big grin
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
sovietjet
Thu Oct 13, 2005 7:47 am
HF antenna but on the initial production Tu-154(before the Tu-154A, B, B-1, B-2 and M) it is smaller like on this one here
Now please....post those pics of the old Tu-154s!!!!  Smile  Smile  Smile  Smile
Thu Oct 13, 2005 2:45 pm
Do Models count  Smile
regds
MEL
gkirk
Fri Oct 14, 2005 3:27 am
Quoting Scbriml (Thread starter):
Well you know how daddy planes and mummy planes make baby planes?  duck
scbriml
Fri Oct 14, 2005 6:25 am
Thanks for the input guys - apart from Kirky!  wink
I'm not sure I'm any the wiser.
A350
Sat Oct 22, 2005 1:27 am
Isn't it a trim tank?  twocents
A350
scbriml
Wed Nov 02, 2005 4:04 am
Quoting Sovietjet (Reply 9):
Took a while, but here you go:
BEG2IAH
Wed Nov 02, 2005 4:16 am
This is what you need:
Photo © Milan Vladisavljevic
BEG2IAH
Aviation is not so much a profession as it is a disease.
Wed Nov 02, 2005 2:14 pm
So what Exactly is It Finally.Anyone having worked on them.
regds
MEL
Users browsing this forum: 69bug, DFWflightpath and 4 guests
