HT
Why May Bags On Oxygenmasks Not Inflate?
Tue Oct 18, 2005 3:59 pm
After a couple of flights the last days I´ve watched the usual safety demonstration over and over, however one question came up in me:
Everytime the use of pax-oxygenmasks is demonstrated it is said that "the bag may not inflate".
Q: Why is it so ? Which purpose does the bag have ?
-HT
RE: Why May Bags On Oxygenmasks Not Inflate?
Tue Oct 18, 2005 5:15 pm
O2 mask for GA Aircraft.
Quoting HT (Thread starter):
If the Bag is Punctured or connecting hose Disconnects.Though very rare.Thats why a stby mask is provided in each PSU.
The bag holds a fixed qty of O2 when the Flow is activated.
regds
MEL
bri2k1
Tue Oct 18, 2005 5:33 pm
My understanding was that it's a rebreather system. The bag holds mostly exhaled air, and inhaled air comes from a mix of the supplied oxygen and oxygen that was exhaled and stored in the bag.
Position and hold
SlamClick
Tue Oct 18, 2005 11:51 pm
Quoting Bri2k1 (Reply 2):
Not exactly as that usually implies the presence of carbon dioxide scrubbers in the system.
Actually the system is constant-flow, but the flow rate is not very high - a liter a week or so. (kidding) So while you are not inhaling, oxygen will pool in the mask. When you do inhale the first part is high O2 content, but when that is gone the little flapper valve in the back of the cup opens and you are inhaling cabin air plus smoke or whatever else it contains.
If you breathe rapidly the bag will never inflate because the flow rate is not high enough to fill the cup, then inflate the bag.
If you are not breathing rapidly you obviously have not grasped the seriousness of the situation.
TimT
Wed Oct 19, 2005 2:11 pm
Just about all systems (commercial aircraft) are NOT using bottled 02- they use solid chemical generators. I remember the early days they F/A's briefing included the words, "you may notice a slight burning smell". I don't think the generators can make enough volume to get the bag to inflate, but do cause enough flow to keep you going until the altitude gets to a level the atmosphere can sustain you. The cup has a small exhaust valve built into it, and the supply line. When you inhale, the valve closes and you get whatever is in the bag, and then on exhale the valve opens, letting out the C02.
Loggy
Wed Oct 19, 2005 3:34 pm
So, if you breathed reeaaall slow the bag would inflate because you wouldn't be using all the ? Pure o2 ?, or just plain old high altitude, say 10000 Ft, air being supplied ? .
If it were pure o2 then the supply would be quite low ? . Enough to keep you conscious, panting, or enough to keep your vital systems going ? .
Obviously if the supply were low then unfit and smoker pax would suffer more, albeit temporarily, than fit healthy people.
Wed Oct 19, 2005 4:20 pm
Quoting TimT (Reply 4):
Quoting Loggy (Reply 5):
Unfit ok.But why would a Smoking Pax would suffer more.
Loggy
Wed Oct 19, 2005 4:54 pm
Quoting HAWK21M (Reply 6):
Well depending how long they have smoked would determine their lung capability for extracting the necessary oxygen from any air supply into the blood stream. I would imagine a moderate smoker noticing the effects of a reduced oxygen supply moreso than a non smoker due to the damaging effects on the lungs through smoking.
Wed Oct 19, 2005 5:47 pm
Quoting Loggy (Reply 7):
Because of collapsed lungs.
regds
MEL
Tod
Wed Oct 19, 2005 11:39 pm
744 use gaseous oxygen and it is a customer option 772 and 773.
Tod
bri2k1
Thu Oct 20, 2005 12:08 am
rebreather
Your'e right, that was the wrong word. What I was trying to describe is that the flow of oxygen goes into the mask, and the bag is filled by exhaled air, which still contains oxygen. Then, eventually, inhaled air will be a mix of the supplied pure oxygen plus the exhaled air from the bag. When we breathe normally, we don't inhale pure oxygen, so this approximates normal breathing.
Am I closer?
Position and hold
Electech6299
Fri Oct 21, 2005 8:25 am
Try this LINK from a report on the oxygen systems of a MD-11. It is supporting information for the TSB crash investigation of SR111.
It explains the masks in detail, and will answer most of the questions about the generators. It is a little thin on info about the reservoir bag, tho:
Each passenger oxygen mask is fitted with a reservoir bag that is attached to the oxygen generator with a flexible hose. When a generator is initiated, the reservoir bag unfolds and may inflate (depending on the altitude) until breathing begins.
I assume this means cabin altitude- which is obviously above 14,000 feet if the masks have deployed. But basically, it is as described by Slamclick- a reservoir bag, that will inflate to provide pressure relief and a reservoir of O2 until the passenger starts breathing, but the bag is not intended to supply the breathing air. The passenger breathes cabin air, supplemented by O2 from the generator supply tube (or reservoir bag if any has accumulated there). Exhaled air is vented through the exhalation valve in the mask directly to the cabin, not into the bag.
But to answer the question directly- based on altitude. That's what the report says. I don't know which way the altitude affects it- I would think high altitude, thinner atmosphere, the bag inflates more. But perhaps lower altitude, denser atmosphere, more efficient operation of the canisters which provide more O2, inflating the bag more. I dunno
[Edited 2005-10-21 01:34:17]
Send not to know for whom the bell tolls...it tolls for thee
erj-145mech
Fri Oct 21, 2005 11:02 am
The most important function of the mask is that it muffles the screams of the wearer, other than that, it will provide enough oxygen to sustain life, not necessary consciousness.
SlamClick
Fri Oct 21, 2005 12:13 pm
Quoting Bri2k1 (Reply 10):
Am I closer?
Well, my only hangup was the word "rebreather" which, to me, conjures images of underwater or firefighter breathing gear using CO2 scrubbers.
I think we were thinking of the nosebags the same way, though.
Tod
Sat Oct 22, 2005 12:11 am
Quoting Electech6299 (Reply 11):
Oxygen generator canisters are self contianed and effiency is not impacted by altitude.
Tod
Electech6299
Sat Oct 22, 2005 8:40 am
Quoting Tod (Reply 14):
Well, you can see that I didn't read all the info in my link  embarrassed  Oops... I was more interested in the aneroid switches and door release, and glossed over the canisters. Glad somebody knows...
Quoting SlamClick (Reply 13):
Most of the firefighting gear I have worked with is strictly compressed air SCBA, I haven't personally seen or heard of rebreathers outside of underwater/submersible vehicle or contained HAZMAT site use (Like chemical dump cleanup). Do airport firefighters use them? Or cockpit crew? Any info you have on this would be welcome.
HT
Sat Oct 22, 2005 2:50 pm
Thanks for all the input !
-HT
DC8FriendShip
Sat Oct 22, 2005 11:07 pm
Quoting Tod (Reply 9):
For the flight crew, maybe. but i doubt that there are tanks onboard that hold enough O2 for over 250 people. They most likely use generators like most pax aircraft do.
Come fly the Friendly Skies of United
Sun Oct 23, 2005 5:44 pm
Quoting DC8FriendShip (Reply 17):
Didn't the B742 have Piped O2 for the Pax system.
regds
MEL
Tod
Sun Oct 23, 2005 11:27 pm
Nope.
The pax oxygen tanks on 747 are located in the forward cargo compartment, right side just aft of the cargo door, next to the halon tanks. Additional oxygen tanks are sometimes installed between the main deck floor beams in the forward cargo compartment. I designed the installation of two extra tanks for the Corsair 744 fleet of ex-UA planes. Some of the asian operators such as SQ have as many as 14 extra bottles on their 744 to facilitate high pax loads and long range requirements.
On 777 gaseous oxygen is an option. About half the ones I've work on have gaseous systems.
Quoting HAWK21M (Reply 18):
Yes
Tod
