wrighbrothers
Why Is Fuel Coming Out The Wing?
Sun Oct 23, 2005 8:49 pm
Hello all, Just a quick one
Photo © Mark A Harris
"Fuel pouring out left side wing as she rotates."
It surly can't be fuel can it ?
I am here to be corrected but, why would there be fuel coming out the wing, was dumping fuel?, or is it one of those optical allusions ?
Cheers, Wrighbrothers
whitehatter
RE: Why Is Fuel Coming Out The Wing?
Sun Oct 23, 2005 9:02 pm
If you mean the trail from the tail area, it looks like it could be smoke from a chimney under the R5 door area in the picture.
There is a fuel 'overflow' mechanism in the outer wing though. You might be better off asking in tech-ops about it, and there is a picture in the database somewhere of an overfueled Air Atlanta 742 with fuel streaming from its outer left wing.
Lead me not into temptation, I can find my own way there...
EMBQA
Sun Oct 23, 2005 9:28 pm
Quoting Wrighbrothers (Thread starter):
It's fuel. With longhaul flights the aircraft is often fueled to it maximum fuel load. Fuel will sometimes make it into the surge tank and due to heat expansion. When the aircraft starts its take off roll a NACA duct allows air into the surge tank and can force the excess fuel out. Altough not common, it can happen with some flights.
HMUcfm56
Sun Oct 23, 2005 10:07 pm
Quoting WhiteHatter (Reply 1):
http://www.airliners.net/open.file/789603/L/
wrighbrothers
Sun Oct 23, 2005 11:53 pm
Thank you to who ever moved this thread  Smile
Quoting HMUcfm56 (Reply 3):
WOW,  Wow!
Wrighbrothers
Mon Oct 24, 2005 1:22 pm
Quoting EMBQA (Reply 2):
Thats the Answer.
Although on a B744.Is the Centre tank vented to #1 or #2 Tank Vent.
regds
MEL
wrighbrothers
Mon Oct 24, 2005 7:20 pm
Thanks  Smile
Wrighbrothers
wingscrubber
Mon Oct 24, 2005 10:40 pm
This a/c, G-BNLM was in Cardiff for it's C-check while I was on my engineering scholarship there - is flying with a booster pump held in with my wire-locking, spinner on no. 1 engine fitted by me, crack in no. 3 pylon repaired by me...and that pic taken in sydney while I was still working there, just days afterward in fact... Quite humbling for a trainee engineer, was just hoping that fuel leak wasn't my fault Embarrassment
Resident TechOps Troll
wrighbrothers
Mon Oct 24, 2005 11:27 pm
Hi Wingscrubber
Quoting Wingscrubber (Reply 7):
Realy!, Must have been quiet sureal !.
Please don't answer if you don't want to , i'll fully understand but, Are you going to work for BA engineering ?
Wrighbrothers
Tue Oct 25, 2005 12:16 am
Whats a Trainee Engineer out there.What Qualification.You Still cannot certify right.
regds
MEL
Users browsing this forum: A388, Calder, N415XJ and 1 guest
