AT
Pros And Cons Of "Plugged" Windows
Tue Oct 25, 2005 4:41 am
A number of airlines have their windows "plugged" in regions of the aircraft where there is a galley, toilet or other non-seating areas, for example
in this picture, just forward of Door 2L.
Photo © Nathan Zalcman
I wanted to ask, what are the benefits of doing so?
Does it affect the structure of the aircraft?
And are they permanent? Or can they be removed if the seating configuration changes and the windows are required?
B744F
RE: Pros And Cons Of "Plugged" Windows
Tue Oct 25, 2005 4:43 am
Saves weight, mx costs, with the windows gone. No windows are required if a seat is put there
bigsmile
Tue Oct 25, 2005 4:50 am
These aren't permanent. They are fitted the same way the windows are fitted. They are just cosmetic blanks. There is no more structural benefit from these blanks when compared to the windows. They are fitted usually behind galleys, toilets etc so you don't see the back of it from outside, galley's, toilets etc are not the most attractive things when you get behind them. Sometimes you do see some blanks fitted with aerials attached.
[Edited 2005-10-24 21:53:57]
garpd
Tue Oct 25, 2005 4:51 am
Quoting AT (Thread starter):
AFAIK, there is no real benefit. They just fill a gap where a window is not required, for example a toilet, a galley bulkhead etc.
Perhaps window plugs save a little weight, but I'd imagine it'd a negligable ammount in relation to the entire aircraft.
Quoting B744F (Reply 1):
Nope, think of them as windows made out a metal window. They are just as secure, perhaps even stronger.
Most plugs can be removed if desired.
arpdesign.wordpress.com
Crosswind
Tue Oct 25, 2005 4:53 am
It's a fairly quick and simple process to plug and unplug a window - in very simple terms the glass window panel is replaced with a sheet metal plug and vice versa.
My airline recently reconfigured 2 ex-Vietnam Airlines B767s. The first window aft of Door 2L & R was already plugged due to a toilet being located on each side - during reconfiguration stowages were installed aft of the toilets on both sides of the cabin so the second window on each side aft of Door 2L & R was also plugged.
Before and After;
Photo © Wu Shengpei
Photo © Darren Wilson
CROSSWIND
Tod
Tue Oct 25, 2005 5:18 am
There are also locations that plugged because the main conditioned air ducting is routed there. For example, three locations on each side of a 747 forward of door three. IIRC, two on each side of 767 and one on each side of 737NG (old 737 using mulitple small ducts routed around the windows instead). For all practical purposes, these locations cannot be changed.
Tod
garpd
Tue Oct 25, 2005 5:22 am
Quoting Tod (Reply 5):
Tod
I don't thinks these locations feature "plugged" windows. Rather, no window cutting at all. Simply clean sheet metal fuselage.
Tod
Tue Oct 25, 2005 5:29 am
Quoting GARPD (Reply 6):
That's correct, good clarification. Thanks.
Tod
aeroweanie
Tue Oct 25, 2005 10:18 am
Take a look here: http://www.liteair.com/
Tue Oct 25, 2005 5:23 pm
Photo © Charles Falk
Normally Blanked Window Plugs are replaced like Windows.Why put a window where its not needed.
regds
MEL
jeffry747
Tue Oct 25, 2005 8:14 pm
Let's not forget aircraft which have been converted from passenger to cargo configuration, which in some cases has the entire fuselage lined with window plugs.
Photo © Dmitry Kudryn
Photo © Ryan C. Umphrey
C'mon Big B, FLY!
VC-10
Wed Oct 26, 2005 7:01 am
Quoting GARPD (Reply 3):
You have to look at the big picture, weight saved = fuel saved over the life of the a/c.
A company I once worked for did a calculation of how much extra fuel was burned in course of a year by an extra sugar bag.
lincoln
Wed Oct 26, 2005 9:42 am
Forgive the layman for budging in here, but I beleive I read somewhere that window plugs require less MX than a real window. Is this correct?
Lincoln
Aviation
Wed Oct 26, 2005 9:49 am
I really dont think they are such a good idea.
Signed, Aaron Nicoli - Trans World Airlines Collector
474218
Wed Oct 26, 2005 10:18 am
Quoting Aviation (Reply 13):
So I guess you think stretched acrylic is stronger than aluminum?
OzLAME
Wed Oct 26, 2005 10:22 am
Quoting Lincoln (Reply 12):
That is correct, which is why the eyebrow windows are disappearing from the cockpits of 737s.
Why not? I have been involved in converting small twin-engined a/c into freighters. We would often remove windows and install metal blanks. The metal can still be checked from the inside and there is no longer any need to get out the prism and check the window for cracks, or to polish out scratches. There is a huge difference in maintenance requirements; there are guys working at QANTAS who do nothing but change windows.
Monty Python's Flying Circus has nothing to do with aviation, except perhaps for Management personnel.
Wed Oct 26, 2005 7:47 pm
Quoting OzLAME (Reply 15):
Also it contributes to a more silent cockpit too.
regds
MEL
Whiskeyflyer
Thu Oct 27, 2005 2:15 am
also metal plugs make washing and painting easier
you do not need to waste time ensuring no abrasive cleaners/stripper gets on the windows (masking windows prior to stripping/painting consummes a lot of manhours)
The MM specifies limits to scratches, nicks, abrasions (those little scratches) etc that a window may have (varies by aircraft type), if it exceeds limits, you replace the window (and hope the polishing shop can restore the windows within limits) Dusty climes and pollution result in abrasing of windows so best to put the metal in and keep your windows in stock for pax (boxes don't admire the view and they don't complain........... brings back happy memories of when I was a freight dog and left oil all over the ramp in our thrusty DC8-55F)
SkydrolBoy
Thu Oct 27, 2005 5:16 am
Quoting HAWK21M (Reply 16):
regds
MEL
It's the Vortex Generators that they install infront of the windshield that makes for a quieter cockpit, not the removal of the windows. You can see them in the picture below just behind the radome.
Photo © Jet City Aviation Photography
727EMflyer
Thu Oct 27, 2005 11:44 am
Quoting VC-10 (Reply 11):
So what was the verdict? I trust we're not talking a tsp sized packet for coffee...
Thu Oct 27, 2005 12:58 pm
Quoting SkydrolBoy (Reply 18):
Agreed The VG do contribute to noise reduction,But I've heard that the Elimination of the Eyebrow Windows too add to the Silence.
http://www.airliners.net/discussions/tech_ops/read.main/112446/
regds
MEL
Users browsing this forum: AAairplane, GloomyDe, nabla and 2 guests
