pilotaydin
Strange Lights On 727
Wed Oct 26, 2005 5:46 pm
I recently saw a B727 for Buraq airways departing out of istanbul. The lights that would normnally be red for the beacon were strobe white, quite bright as well, and there were no strobes being used on the wing tips...
i know that beacon and anti collision are used synonymously, but is that the case? and which other a/c have white beacon lights on the belly like this 727 did?
The only time there is too much fuel onboard, is when you're on fire!
jeffry747
RE: Strange Lights On 727
Wed Oct 26, 2005 6:56 pm
I occasionally see various light twins flying around with white strobe beacons on their bellies. If anyone knows what models, feel free to specify.
C'mon Big B, FLY!
Wed Oct 26, 2005 7:21 pm
I've seen UK manufactured Aircraft having White Anti collision lights on the Fuselage top & Bottom in lieu of the Red Lights by most other operators.Is there a reason.
Out here Both types are permitted by DGCA.
regds
MEL
DC8FriendShip
Fri Oct 28, 2005 7:30 pm
Quoting Pilotaydin (Thread starter):
Quoting HAWK21M (Reply 2):
The origanal Anti-collision lights on a 727 were red rotating beacons. they were replaced by strobes as they wore out in the '80's and 90's in the US. (1980's aircraft were delivered with strobes). If it had the original lights, it could have been replaced witha white strobe instead of the customary red.
Come fly the Friendly Skies of United
OzLAME
Fri Oct 28, 2005 8:59 pm
Beech 1900Ds and later model King Airs, and Fairchild Metro 23s were/are delivered with white flashing beacons that use Halogen lamps instead of strobe flashtubes (a dispensation letter is needed from the regulatory Authority in this country in order for them to remain on the a/c, as the local Regs specify red beacons). I think it is just a matter of the white beacons being cheaper and more reliable than the Grimes motor-driven Tandem Oscillating beacons that Metro IIs and IIIs and earlier King Airs had fitted.
Monty Python's Flying Circus has nothing to do with aviation, except perhaps for Management personnel.
Users browsing this forum: Baidu [Spider], BlueLine and 1 guest
