taguilo
Duct Pressure For Engine Start
Sat Oct 29, 2005 9:57 pm
Hi,
Does any of you recall which was the minimum duct pressure where it was possible to start the engines? In this case, did you need almost the "standard?" 2 min starter ON for the spool process, I mean, was it a low spool rate?
Many Thanks
Tom
SlamClick
RE: Duct Pressure For Engine Start
Sat Oct 29, 2005 10:50 pm
Well, an old MD-80 manual I still have says minimum of 36 PSI, minus 1 PSI for every thousand feet of airport elevation.
I have started DC-9 engines at Flagstaff Arizona and at Mexico City and don't recall them taking much more time to wind up than they did at lower elevations. Maybe some, but it really doesn't stand out in my memory.
Most pneumatic systems deliver plenty of pressure and volume.
fr8mech
Sat Oct 29, 2005 11:05 pm
Different aircraft/engines have different pressures. The norm is somewhere around 35 psi with the valve open. Start times also differ with engine type and temperature.
PhilSquares
Sat Oct 29, 2005 11:55 pm
Quoting Taguilo (Thread starter):
744 is 30 PSI. Start limit is 2 minutes from fuel on to stabilized at idle rpm.
Fly fast, live slow
320tech
Sun Oct 30, 2005 12:14 am
A320 is minimum 28 psi, I believe, don't have the book handy. Max starter engagement is 2 minutes. Usually you see 30-35 psi from the APU, and 44 psi from the engine. Lots of pressure available.
If the starter's running for two minutes, there's a problem. I would say most starts are complete within 30 - 40 seconds.
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
taguilo
Sun Oct 30, 2005 12:37 am
Thank you for the replies.
Now, minimum psi is measured BEFORE or AFTER switching starter to GND??
Sun Oct 30, 2005 2:14 am
B737 Min 30psi.Ideal 40psi.
regds
MEL
B747FE
Sun Oct 30, 2005 3:36 am
30 PSI (minus 1 PSI x 1,000 FT airport elevation) and time limit is 90 seconds to accelerate from "fuel on" to idle rpm, in the 747 Classic.
Quoting Taguilo (Reply 5):
Pressure must be checked after start valve is open.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
NZ1
Crew
Sun Oct 30, 2005 7:17 pm
767 is normally 34psi.
NZ1
NZ1
Head Forum Moderator
Users browsing this forum: GolfBravoRomeo, N353SK, speedbored and 2 guests
