julesmusician
Flapless Landings On Large Aircraft - When To Do?
Sun Oct 30, 2005 9:25 pm
Is there any time when a large commercial aircraft might come in and land without flaps? (other than a failure!) - are there any specific circumstances which require it or has any pilot done it for a specific reason?
African Civil Aviation Commission president "You don't want to fly out as a passenger and come back as cargo."
PhilSquares
RE: Flapless Landings On Large Aircraft - When To Do?
Sun Oct 30, 2005 9:41 pm
Quoting Julesmusician (Thread starter):
There really is no operational reason to do a "no flap" landing. There is a substantial increase in Vref which translates to a tremendous increase in the runway required.
Fly fast, live slow
LimaFoxTango
Sun Oct 30, 2005 10:03 pm
I remember hearing sometime ago that a flapless landing is considered an emergency procedure ie mechanical failure or loss of hyraulic pressure etc. Unless for training purposes, an aircraft would not normally land without flaps.
You are said to be a good pilot when your take-off's equal your landings.
SlamClick
Sun Oct 30, 2005 10:42 pm
Quoting LimaFoxTango (Reply 2):
It very well might be. In many cases the landing speed is near, or slightly above the tire speed limit. They are a very critical maneuver.
Mr.BA
Sun Oct 30, 2005 11:19 pm
Have there been situations that flaps fail on one wing but operate normally on another? What is the procedure in this case? I suppose it's too dangerous to fly 'unevenly'?
Boeing747 万岁!
Sun Oct 30, 2005 11:37 pm
Quoting Mr.BA (Reply 4):
Normally Asymettric protection will stop the Mvmt of the Flaps beyond a specific Difference.
regds
MEL
Qantas744er
Mon Oct 31, 2005 3:44 am
I think that when you haver an engine failure lets say on a 777 and you loose one engine, that you then do a flapless landing. correct me if wrong
cheers leo  Smile
You live and you die, by the FMA
SlamClick
Mon Oct 31, 2005 3:50 am
Quoting Qantas744ER (Reply 6):
Don't know anything about the triple-sev but I can tell you for absolute certain that you do not make a no-flap landing with an engine out on the 757/767 or A-330.
I cannot impress this upon you enough.
A no-flap landing is a very serious event. It is much more serious than an engine failure or fire.
You will have the crash trucks standing by. You will very probably blow all the maingear tires. You are about 70/30 going to have to evacuate the passenges down a slide, unless you flew around long enough for them to position a stair truck with the crash trucks.
In a big jet airliner you are never going to do a no-flap landing unless it is absolutely unavoidable.
edit: Will usually make a big difference if you can get the leading edge devices deployed.
[Edited 2005-10-30 19:51:38]
rendezvous
Mon Oct 31, 2005 7:51 am
With an engine failure on a twin I believe it is a reduced flap setting that is used (to allow better climb for missed approach etc).
SlamClick
Mon Oct 31, 2005 8:11 am
Quoting Rendezvous (Reply 8):
Reduced yes. Massive difference between that and NO flaps. May easily be a fifty knot difference in touchdown speed.
Typical for an engine out might be landing at the highest takeoff flap setting. Like maybe flaps 15 for a 737.
