rendezvous
Boeing 767 Cockpit Button Question
Tue Nov 01, 2005 6:14 pm
Hello
Just looking at pictures on here of 767 flight decks (also been doing a lot of flying in flight sim in the LDS 767 while I'm not doing any real flying at the moment). On the overhead panel, there's a series of buttons for cabin calls and ground request. I wondered what the right hand button is for that says "FLT INT". Any help? Thanks.
Rick767
RE: Boeing 767 Cockpit Button Question
Tue Nov 01, 2005 6:36 pm
This is the Pilot Call Panel, incorporating the SELCAL, CABIN CALL, GROUND CALL and FLIGHT INTERPHONE buttons.
Pushing the Flight Interphone switch (FLT INT) interconnects the flight and cabin interphone systems. The system is connected when the FLT INT light is illuminated.
This allows the pilots to communicate to the cabin crew via calls to / from specific cabin locations (FWD, MID AFT).
Tue Nov 01, 2005 6:44 pm
Photo © Tchavdar Kostov
Could it be to communicate with GRD on the Flt Interphone port.
Notice all except "Alert" button is white.Wonder why.
regds
MEL
[Edited 2005-11-01 10:47:54]
EI747SYDNEY
Tue Nov 01, 2005 8:13 pm
Alert is probably white so it stands out from the rest
Rob
''Live life on the edge, Live each and every day like it's your last, Hell you only live once''
2enginesonly
Tue Nov 01, 2005 8:23 pm
The flight interphone switch connects ALL interphonesystems to the cockpit....not only the cabin interphone system. In combination with a switch on the P61 panel ( behind the F/O.... the old 'flight engineer' station ) you can also communicate from several area's in and around the aircraft to the cockpit.....actually used this system last night during an APU run.
My company has a policy of switching on this switch right before pushback and you can hear the stewardesses talk to eachother during pushback and enginestart....very annoying Embarrassment)
Mel, those switches you're talking about are actually blue....don't know about the 'alert' switch...might be red. I'll check it out tonight and let you know.
Arjan
AJ
Tue Nov 01, 2005 9:59 pm
The alert is a black switch with 'ALERT' in blue visible when an alert call is made.
rendezvous
Wed Nov 02, 2005 8:35 am
Very interesting, thanks.
Wed Nov 02, 2005 2:32 pm
Quoting EI747SYDNEY (Reply 3):
I said all except the Alert switch is White  Smile
Quoting 2enginesonly (Reply 4):
Quoting AJ (Reply 5):
Ok.That makes sense.But what is it used for.
regds
MEL
cdfmxtech
Wed Nov 02, 2005 4:31 pm
It is an All-Call selection. PA handsets (Or pilot call panel) can make individual calls to either FWD, MID, AFt Stations. or an All_Call can be placed where everyone is Alerted. Usually used in Emergencies I think.
Wed Nov 02, 2005 5:20 pm
Quoting Cdfmxtech (Reply 8):
Interesting.When the Alert button is pressed.What happens to the other buttons mechanically.No change.
regds
MEL
cdfmxtech
Thu Nov 03, 2005 3:45 pm
I believe all switches are momentary action types. They are not Altn Action.
schooner
Thu Nov 03, 2005 9:07 pm
The Flight Intercom button is an alternate action switch, all the rest are momentary. It enables you to communicate on the intercom system with the crew. You have to be careful to not forget to turn it off when you have finished otherwise any crew using the intercom system could hear you talking about the really hot junior down the back in lewd terms Big grin .
Cheers.
Untouched and Alive
