kaitak744
Lines On Top Of The Door
Mon Oct 31, 2005 10:10 am
Does anyone know what these lines are on top of each door? They all seem to at a different angle, and are present on almost all aircraft.
Photo © Jay Piboontum
Photo © Dominik Zimmermann
Photo © John Tavendale
EMBQA
RE: Lines On Top Of The Door
Mon Oct 31, 2005 10:13 am
They are just rain gutters that prevent rain water from getting in the door ways when the doors are open...
[Edited 2005-10-31 02:20:44]
Mir
Mon Oct 31, 2005 11:05 am
Quoting EMBQA (Reply 1):
 checkmark
Not too much of an issue when using a jetway to board, but it makes a big difference when you're using open stairs.
-Mir
ChiGB1973
Mon Oct 31, 2005 11:07 am
Makes a big difference with a jet bridge at many places. At TZ, I noticed it kept a lot of water out. They are not an exact fit in most places. Of course, could have been the bridge operator too.
M
EMBQA
Mon Oct 31, 2005 11:21 am
Quoting Mir (Reply 2):
Not really true as jetways do not offer a rain tight seal.
jsposaune
Mon Oct 31, 2005 12:31 pm
Correct, but more specifically, they prevent de-icing fluid from running down over the doors. Type I deicing fluid, heated to upwards of 170 degrees will damage door seals. De-icers are trained to spray the top of the fuselage, not directly at the door. Those little ridges will deflect the fluid away from the sensitive areas.
Hope that helps...
(first a.net post, by the way...hello, everybody!)
There are no stupid questions....only stupid people!!!
kaitak744
Mon Oct 31, 2005 12:49 pm
Yup! thanks, that surely helped.
Quoting Jsposaune (Reply 5):
Welcome aboard!
legendDC9
Mon Oct 31, 2005 3:24 pm
HA! That has to be one of the most optimistic comments regarding airport training I have ever heard. I would say I have seen it closer to: Here, deice this and keep it away from your nose and mouth.
Mon Oct 31, 2005 10:40 pm
Welcome.
Amazing what a single piece of metal can achieve.
regds
MEL
jsposaune
Tue Nov 01, 2005 1:34 am
Quoting LegendDC9 (Reply 7):
Hehe...I seem to remember my training a few years back...it included the question "um...you're not afraid of heights, are you?!?!"
Heck..a little type 1 never hurt anybody, as long as you don't make cocktails with it!!!
kc135topboom
Tue Nov 01, 2005 1:39 am
Hope that helps...
That is correct, and welcome aboard.
Quoting ChiGB1973 (Reply 3):
The jet bridge awning will also collect rain water, but often is not sealed against the aircraft, thus the gutters still are useful.
HPRamper
Tue Nov 01, 2005 2:42 am
On the picture of that ANA plane you can clearly see the imprints where the jetway sits against the aircraft. Very strange, the jetway must be filthy.
positiverate
Tue Nov 01, 2005 3:08 am
One addendum: I have been told that the gutters are positioned at the angle the airflow goes over the airframe at that point. Thusly, they provide minimal if no drag.
andz
Tue Nov 01, 2005 4:49 am
Quoting Positiverate (Reply 12):
Not sure about that, if you look closely at some aircraft you will see they angle in both directions over different doors.
Tue Nov 01, 2005 5:58 pm
Its more to do with the Aircraft Pitch on Ground & the Fuselage surface.
regds
MEL
474218
Tue Nov 01, 2005 11:53 pm
On the early L-1011's the rain gutters over the two forward doors were parallel with the top of the door. At some point (I don't know where) they were installed at an angle, with the front being lower than the back. This was done to improve drainage.
OldAeroGuy
Wed Nov 02, 2005 12:20 am
Quoting HAWK21M (Reply 14):
No, it really is a reflection of the local surface streamlines in cruising flight.
Wed Nov 02, 2005 2:08 pm
Photo © Manas Barooah
Quoting OldAeroGuy (Reply 16):
I still feel its required while on Ground & not in Flight.For Eg Take the B737 Fwd Door Gutters.
regds
MEL
CCA
Wed Nov 02, 2005 7:58 pm
Quoting HAWK21M (Reply 17):
regds
Exactly, it is inline with the local airflow in flight, just ask yourself where are A/C designed to be for the majority of their life on the ground or in flight?
The 747 is the perfect example to show the local airflow in flight. Door 1 from the minimal effect over the nose, Door 2 from the bow wave of the wing, Door 3 inline with the air flow over the wing, Door 4 as the flow evens out and Door 5 is even set up for the bow wave flow for the stabilizer. Even the main deck cargo door and it's negative pressure relief valve doors are done.
Photo © Juan Carlos Guerra Aviation Photography of Mexico
Photo © Joel Vogt
You can see the local airflow dirt marks here.
Photo © Javier Guerrero
Photo © Simon De Rudder
KLM seemed to have the perfect shots  Smile
Rgds CCA
P1 in A330, A340, A346, B742, B744, B748.
LongbowPilot
Thu Nov 03, 2005 2:47 pm
Maybe that is the way they do it in your country.
Users browsing this forum: Acey and 20 guests
