Luis777
Fuel Flow Of Wide Bodies, Deep Analysis
Fri Nov 04, 2005 12:43 pm
Hello Everybody
I want to share some of my research about fuel consumptions of big birds, this information is not official, I've made a research of airplanes performance by reading some technical books, watching photos of readouts, talking with pilots and other aviation enthusiasts. This is only average fuel flow on cruise, and it's important to notice that this data depends of many factors, including, weight of the airplane, center of gravity, wind, temperature, flight level, engine type, use of APU, ice accumulation, use of thermal anti-ice, and even how the crew uses the FMC and a lot of things more.
If you can correct me and share more detailed information I will appreciate it a lot, thanks.
Fuel Density 1 litter = 0.8029 kg
Boeing B747-400 9,200 kg/hr 11,458 lt/hr
Boeing B767-300ER 5,100 kg/hr 6,352 lt/hr
Boeing B777-200ER 6,900 kg/hr 8,529 lt/hr
Airbus A310-300 5,000 kg/hr 6,227 lt/hr
Airbus A330-200 5,000 kg/hr 6,227 lt/hr
Airbus A340-300 6,800 kg/hr 8,469 lt/hr
Airbus A340-600 8,800 kg/hr 10,960 lt/hr
MD-11 6,800 kg/hr 8,469 lt/hr
LG
Loran
RE: Fuel Flow Of Wide Bodies, Deep Analysis
Fri Nov 04, 2005 4:47 pm
Quoting Luis777 (Thread starter):
Strange, I always had the figure of approx. 12.000kg/h in my head. Your number would allow the 744 an endurance of 19.5h flight (assuming 180.000kg of kerosene are onboard), which appears to be a bit too much to me. Where exactly did you get that number from? I remember many discussions about the longest commercial flight of a 744 and 744ER, I think there was hardly a flight over 14h. Wasnt MEL-LAX one of the longest flights?
Why are they exaclty the same? Coincidence? It could make sense though, due to the design improvements of the A332 compared to the A313.
Loran
703 717 727 732-9 747 757 767 777 788 AB2/6 310 318-321 330 340 380 D8M D91/3/5 D1C M11 M81-90 L10 IL1/8/6/7/W/9/4 TU3/5/2 YK4/2
CCA
Sat Nov 05, 2005 1:39 am
Loran,
You have to remember to take 10-12T off for the climb and to arrive with 10-14T for diversion and holding fuel that leaves 155+ and my longest flight was 15hrs 45mins LAX-HKG.
Fuel flow at the start can be 12T/hr or more but at the end 8T/hr, so 10T/hr is probably a good average.
P1 in A330, A340, A346, B742, B744, B748.
kaddyuk
Sat Nov 05, 2005 4:50 am
My understanding was about 10,000kgs/hr for a B747-400... 2500kg's per hour per engine.
Luis777
Sat Nov 05, 2005 6:13 am
Watch this:
Scenario
Route: LAX-MEL G/C Distance: 6902 NM
Alternate:CBR G/C Distance: 251 NM
FL350
Mach 0.85 = 490 TAS
Average W/C = M080
Ground Speed = 490kts - 80kts = 410 kts
Flight Time LAX-MEL = 6902NM/410kts = 16.83 hrs = 16:50
Flight Time MEL-CBR = 251NM/410kts = 0.51 hrs = 00:31
5 per cent en-route time = 0.84 hrs = 00:50
Holding over Alternate Airport (1500 ft AFE) = 00:30
Total Flight Time 16:50 + 00:31 + 00:50 + 00:30 = 18:41 = 18.6833
If my average fuel flow is 9,200 kg/hr, then my minimum fuel for this trip is:
9,200 kg/hr X 18.6833 = 171,886 kg
Fuel Capacity on Boeing 747-400 (No ER) is 164,073 kg and others 174,101 kg
747-400
MTOW = 362,880 kg - 396,900 kg
OEW = 182,000 kg (variable)
a 747-400 can takeoff with MTOW at LAX, so my payload is going to be:
Payload = 396,900 kg - 182,000 kg - 171,886 kg = 43,014 kg
If the average american-australian passenger is 80 kg plus 25 kg checked baggage then final weight is 105 kg.
43,014 kg / 105 kg = 410 pax
I can make this trip with a load full of pax and zero cargo, but if my average wind component is bigger than 80 kts head I'll have to unload some pax or make a fuel stop at Nadi or somewhere else. I think that LAX-MEL is one of the longest flights made by a 747-400, that's why Qantas requested the 747-400ER with fuel tanks of 183,278 kg - 193,130 kg and MTOW = 412,770 kg.
Please notice that I still use an average fuel flow of 9,200 kg, for real life the plane will utilize more fuel for holding at 1,500 ft above alternate and the trip to CBR as is very short I think that would fly at FL280 or lower where the fuel flow is larger.
LG
Loran
Sat Nov 05, 2005 4:34 pm
Quoting CCA (Reply 2):
Loran,
Ok, that makes sense. I thought the fuel flow in a holding pattern is higher compared to cruise, is this correct? I assumed the wrong amount of fuel anyway.
Loran
fly707
Sun Nov 13, 2005 12:08 am
Nice topic,
As I know the:
Boeing 767-300ER Cons : 4000 kg per hour
Boeing 777-200ER Cons : 5500 KG per hour
Boeing 757-300 Cons : 3000 KG pe hour
Airbus 330-200 : 6000 kg PH
Airbus 310-300 & 300-600R : 5000 kg PH
Airbus 300B4-200 : 6000KG PH
Airbus 340-200 & 300 : 6000kg ph
Other types you mentioned are almost the same .
Regards.
Without mistakes we will never learn
jush
Sun Nov 13, 2005 1:13 am
I'm interested how come you get any vague figures out ouf your sources when you say it's depending on THAT many factors.
Thank you anyway i have never seen figures like that before so it is really interesting to compare plane for plane.
jush
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
peterinlisbon
Sat Nov 01, 2014 1:58 pm
This shows why it doesn't make sense to fly ULH. During the first few hours of the flight at such high weights the fuel flow is ridiculous.
Does anyone have a comparison between the fuel flow of a 744 and an A330-300 in terms of fuel and in terms of $? I would be interested to know how much Delta will be saving per flight and per month/year by retiring their 744s early.
mmo
Sat Nov 01, 2014 2:59 pm
Quoting peterinlisbon (Reply 8):
Isn't that like comparing apples and oranges? With the reduction in seats, you would be better off looking at CASM. If you want to compare just fuel burn then a better comparison would be the 747-400 and the 777-300ER.
Sun Nov 02, 2014 1:42 am
Quoting Loran (Reply 5):
It depends but I think the burn would be less. For fuel planning purposes the hold is assumed to be at 1500ft AGL over the destination airport. AFAIK three factors are at play.
- Lower altitude than cruise gives higher burn assuming the same IAS and weight.
- Ideally you'd hold at lowest drag speed, minimizing fuel burn over time. This gives lower burn than in cruise where you want to minimize burn over distance. (Actually in cruise you'd typically want to go faster than the min. burn over distance speed in order to decrease the length of the flight.)
- Most important factor IMHO: For long distance flights you'd be holding a much lower weight than the average during cruise, which would decrease burn significantly.
In reality, of course, it depends a lot on the altitude and speed of the holding pattern.
[Edited 2014-11-01 19:04:08]
RetiredWeasel
Sun Nov 02, 2014 3:19 am
Don't know how they do it now, but back in the 747 classic days, we used to do a reasonableness burn check. For the 200, we used an average of 25,000 lbs per hour. If the flight plan said it was 10 hours from T/O to touchdown, then the total burn should be somewhere around 250,000 lbs of fuel and we'd check that against the flight plan burn to ensure no gross errors by the computer or dispatcher.
Then you'd further make sure additional fuel was added that met your comfortable 'fuel on arrival' number which included reserve requirements and wx concerns.
And in case it hasn't been mentioned, every engine on the big birds burned at a slightly different rate. So the computers used this analytic historic data to figure the burn on a flight plan; not (I'm pretty sure) a generic Boeing burn chart.
Sun Nov 02, 2014 3:26 am
Quoting RetiredWeasel (Reply 11):
Methinks the use of a generic burn chart would cause the beancounters to go apoplectic.
sunrisevalley
Mon Nov 03, 2014 8:37 pm
from Piano-X
For a 767-300ER with winglets , 238 passengers, 6070nm ; 4706kg / hr. at cruise
For an A340-600 308 passengers, 7682 nm; 7752 kg /hr. at cruise
seabosdca
Mon Nov 03, 2014 10:15 pm
Quoting sunrisevalley (Reply 13):
And worth noting that 6070 nm is a longer mission than 767-300ERs have ever flown, with just one or two exceptions.
5000 kg/hr seems too high for that frame no matter what the assumptions are.
sunrisevalley
Tue Nov 04, 2014 5:03 pm
Quoting seabosdca (Reply 14):
767-300ER with winglets 12hr sector at MTOW burn at cruise 4769 kg/hr. Is that better?
mandala499
Tue Nov 04, 2014 7:34 pm
on RR Trents... LRC speeds
That would be... about FL390 at just above 220 tons... it's actually cheaper to go at FL350 and FL370 at that weight... which are about 6.8tons/hr.
that's about 155 tons at FL340/350... if on PW4060s...
Anyways...
Quoting Starlionblue (Reply 12):
Yes... indeed!
seabosdca
Tue Nov 04, 2014 9:41 pm
Quoting sunrisevalley (Reply 15):
I suppose it depends on the definition of "better..."    Certainly a more realistic sector length.
Users browsing this forum: WyomingWind and 2 guests
