Ryfly777
Unusual Noise During Takeoff In A330
Tue Nov 08, 2005 3:00 pm
During a normal t/o in a A330, i hear somthing that sounds like rocks rolling down the plane when taking off in the ceiling. Every A330 i've been on does that sound. I hear this sound when i fly in China on Cathay Pacific, Singapore, etc. Does anyone know what it is?
zarniwoop
RE: Unusual Noise During Takeoff In A330
Tue Nov 08, 2005 5:37 pm
Hi Ryfly777.
I also noticed a similar noise on a CX 330 from SIN to HKG on both the outward and return legs. I noticed it more just before landing, sounded like the ceiling creaking.
buckfifty
Tue Nov 08, 2005 5:59 pm
It's probably the overhead luggage lockers creaking, or the contents inside.
Jkw777
Tue Nov 08, 2005 10:29 pm
I have also experienced this on Thomas Cook's A332. I'm pretty certain it's something to do with the overhead lockers moving. You think it's bad on the A330, try the A340!
Justin  Smile
jkw6210@btopenworld.com or +447751242989
SlamClick
Tue Nov 08, 2005 11:40 pm
If it sounds like very small rocks rolling it is probably ice crystals in the air conditioning ducts.
Going to takeoff power provides much more airflow for the packs and the temp may go below that commanded. I've seen other types do this, and even blow snow out of the cockpit air vents.
It will usually sort it out rather quickly, especially once you go back to climb power.
That's my guess, not having been on board your flight.
vzlet
Wed Nov 09, 2005 12:45 am
Quoting SlamClick (Reply 4):
Insightful as usual, SlamClick. It's probably only the second time I've seen that term used in a technical explanation.
"That's so stupid! If they're so secret, why are they out where everyone can see them?" - my kid
Wed Nov 09, 2005 1:23 am
Won't the Water seperator take care of it.
I'd vouch for Airflow thru the distribution ducts when T/O power is used.
regds
MEL
SlamClick
Wed Nov 09, 2005 2:34 am
Quoting HAWK21M (Reply 6):
I don't know the answer to that. I can't imagine any kind of water separator that would be 100% It may be that the ice forms downstream from this component. I just don't know. I have seen it happen on a number of different types though.
VC-10
Wed Nov 09, 2005 5:25 am
Quoting Ryfly777 (Thread starter):
Why do you sit in the ceiling for T.O.?
CCA
Wed Nov 09, 2005 8:04 am
It's ICE that formed in the airconditioning ducts due due high humidity.
P1 in A330, A340, A346, B742, B744, B748.
Thu Nov 10, 2005 1:54 am
Quoting SlamClick (Reply 7):
Quoting CCA (Reply 9):
Post the Water Seperator Isn't that a bit difficult.Im referring to Commercial Aircraft only In case there are Exception.
regds
MEL
SlamClick
Thu Nov 10, 2005 2:04 am
There is a common mistake people make in thinking about water and this might help to understand this.
We all know water has three form: Liquid (water) Solid (ice) and vapor - steam, right?
Wrong. Steam is liquid. Free steam in the air is tiny droplets of superheated liquid water suspended in the atmosphere. Water vapor is a gas and thus, is not visible to the eye at all -except as a reduction to atmospheric visibility on days of high humidity. For example, where I live, on a clear day I can see a mountain range about fifty miles away as if it was just across the valley. Anywhere on the eastern seaboard of the US that mountain range would not be visible at all except on maybe one or two extraordinarily dry days a year.
Water separators will take out the liquid droplets and the ice crystals but it will not take out the water vapor. If conditions still exist downstream from the water separators where the water vapor will freeze, it will form ice crystals. I don't know if this is what was happening on the takeoff in question but I'll say it again. It is common at high power settings for the cockpit vents to be blowing snow.
Thu Nov 10, 2005 7:27 pm
Quoting SlamClick (Reply 11):
What equipment/Circumstanses would cause that to occur.
Vapour would have some filteration requirements vis-a-vis dry air.
What would the Temperature regulation circuit be doing in this case.
regds
MEL
CCA
Thu Nov 10, 2005 10:24 pm
Sorry I should have explained, the humid air is from open doors on the AC at the gate, not from the AC packs. This humid air gets mixed with the aircon pack air which is in the order of 2-3 degrees C which forms condensation which gets into the ducts and eventually forms frost, you can tell it's going to happen when you walk on the AC and you can see moisture forming from the mixing of relatively warm humid air with the as SlamClick said very cold pack air. I've only ever noticed it during the humid months in Hong Kong and Australia.
SlamClick
Fri Nov 11, 2005 12:54 am
Quoting HAWK21M (Reply 12):
It is a gas!
To separate one gas from another takes mechanical sophistication more at home in a laboratory than in an airplane. Water separators, coalescer bags etc. just take the big drops or ice crystals out. They are really pretty coarse.
Furthermore they don't want to take out ALL the moisture from the air. People already dehydrate badly on long flights. Most of the moisture in the cabin comes from other passengers exhaling!
What "conditions?" Temperature, dewpoint, water content.
Fri Nov 11, 2005 6:06 pm
Quoting SlamClick (Reply 14):
So Moisture to an extend is good.
regds
MEL
Users browsing this forum: Flow2706 and 2 guests
