Vio
Dash-8 Pilots - Landing Without A Main Gear
Tue Nov 08, 2005 11:55 pm
Hi,
This question is mostly aimed at Dash-8 pilots. What's the procedure for landing without a main gear? Looking at the design of the aircraft, having one of the main gears fail to deploy, I'd imagine the aircraft will be quite off balance. Would you opt to have the other main gear down, or retracted?
Photo © Daniel Wojdylo
If I'd have to guess, I'd say you'd leave the good gear down, touch down on that one to absorb the shock. However, wouldn't it be very hard to control the plane after lift is gone? If you recall, there was an incident of a USAir 737 that had to land with a main gear up...
Thanks for your answers,
Vio
jamesbuk
RE: Dash-8 Pilots - Landing Without A Main Gear
Wed Nov 09, 2005 3:31 am
im not a pilot but most aircraft would be off balance with only 2 gear so what id imagine they'd do is if the right gear failed to deploy they'd shut down the right engine a couple of mins before landing so the prop doesn't keep hitting the ground
if they landed on the belly it would be a simpler landing also
You cant have your cake and eat it... What the hells the point in having it then!!!
EMBQA
Wed Nov 09, 2005 6:44 am
I really can't think of a situation were you would need to do that. The landing gear have a free fall design built in, so even without hyd. power you can still get the gear down.
TripleDelta
Screener
Wed Nov 09, 2005 6:53 am
Quoting EMBQA (Reply 2):
There were a few instances where even the gravity drop wouldn't extend the gear properly. One such occurrence was some years a go (in the 70s I think), on a Fairchild FH.227 (a lengthened Fokker F-27) where the nose gear failed to extend despite having the same gravity drop system as the main gear. The pilot was forced to make a two-wheel landing with some nose scraping.
"Well, none of it makes any sense. You just have to send in the right number of forms" - Radar, MASH 4077
LimaFoxTango
Wed Nov 09, 2005 7:38 am
Quoting TripleDelta (Reply 3):
A simular incident happened to a Tobago Express Dash 8 in Trinidad earlier this year. The nosegear failed to extend and the manual release didnt help. So, they had to land without it. I'm not sure if the aircraft is back in the friendly skies as yet.
You are said to be a good pilot when your take-off's equal your landings.
Users browsing this forum: Miguel1982 and 9 guests
