alasdaironeil
Flight Management Computer
Mon Nov 14, 2005 8:00 am
Hello
I was looking though the photos on airliners.net, and i notice that the learjet doesn't have an obvious FMC, if any at all. This is also the case for the Dassault Falcon 900EX.
I was wondering what kind of planes use an FMC??
Alasdair
失去在翻譯 - Lost in Translation
avioniker
RE: Flight Management Computer
Mon Nov 14, 2005 11:07 pm
Flight Management Systems may be added at the manufacturer's discretion or as an aftermarket STC. Some companies decided to "save" money in manufacture by not adding that particular system into the original build Type Certificate.
It all comes down to "who's your customer", and "what's your market"?
Ryanair737
Tue Nov 15, 2005 3:14 am
Quoting Alasdaironeil (Thread starter):
The Learjet's have their FMC/GPS units on the aft side of the throttle quadrant (see below).
Photo © Miguel Snoep
The Falcon 900s also has a FMC unit, it is located on the left/right side of the throttle quadrant in the case of the older flightdeck versions (see below).
Photo © Steven Pam
On the Falcon 900EX with the brand new EASy (Enhanced Avionics System) flight deck (see below), they have a single or dual 12-channel global positioning system rather than a FMC unit.
Photo © Sam Chui
Every single commercial aircraft in the skies uses some sort of navigation unit, obviously Cessna 152s etc. won't have a complex FMC, they might just have a simple GPS.
Its a requirement for the larger aircraft that fly at high altitudes to have some kind of more complex navigation unit e.g FMC/GPS.
Ryanair737
LAST FLIGHTS= Ryanair LPL-BGY-LPL - EI-DPS/DWV - MAY 08 // NEXT FLIGHTS= TBC
Users browsing this forum: No registered users and 23 guests
