AirWillie6475
Why Is The PW JT8D So Loud?
Tue Nov 15, 2005 4:14 am
After witnessing a rocket, or should I say an MD80 takeoff at BURs short runway, and amidst the ringing car alarms left and right, I wondered why the md80 engines are so loud. I have always associated the loudness with old engine technology but I found last night that the average age of the MD80 is the same as the 737-300. The 733 is not loud at all. What makes the MD80's engines so loud?
SlamClick
RE: Why Is The PW JT8D So Loud?
Tue Nov 15, 2005 4:46 am
One simple (partial) answer is in the bypass ratio of the engines. The JT8D is a relatively low bypass engine. That is, a higher percentage of the air going in the intakes actually goes through the engine core and exhausts at very high temperatures and velocities.
On the 737-300, the CFM-56 engine has a higher bypass ratio, so a greater percentage of the air entering the intakes just goes around the engine through the fan bypass ducts. This has the effect of wrapping the hot, high-velocity exhaust in a layer of relatively cooler, less disturbed air.
I'm sure there is more, even without considering hushkits etc. but I think this is a fair, simple answer.
ac21365
Tue Nov 15, 2005 6:13 am
One word:
Turbojet
access-air
Tue Nov 15, 2005 6:50 am
Actually,
the P&W JT8 engine is a 1st generation low bypass turbofan engine. The model of engine that powers the MD-80 series of aircraft is actually an updated version. Like the guys stated above the bypass fan diameter was increased to provide more thrust and increase the amount of bypass air flowing around the core to help silence the engine. Also notable but hidden by the huge clamshell thrut reverser buckets is a daisy petal exhaust nozzle that also helps deaden the sound. Believe it or not the MD-80 DOES meet Stage 3 noise regulations but it has been known under certain circumstances to actually slip into Stage 2 noise levels. The difference between the newer JT8Ds on the MD-80s noise-wise and the older JT8Ds on say a DC9 or 737-100 or 200 is that there is more crackle in the engine sound and more rumble.
The cooler air that bypasses the the core in the JT8D 200 series muffles the rumble and crackle.
The older JT8Ds have been hushkitted the best that they can be but they all still crackle.... Smile
What I have noticed is that the 737-700 and 800 engines on take off are Louder than engines on the 737-300/400/500. They 700 and 800 seem to rumble a lot louder....
Anyway, thats all I have to add...
Access-Air
Remember, Wherever you go, there you are!!!!
113312
Tue Nov 15, 2005 7:05 am
It was a lot quieter than the engines that came before like the JT3, JT4, CJ805 or the Rolls Royce Conway.
NKP S2
Tue Nov 15, 2005 8:10 am
Quoting AC21365 (Reply 2):
One word:
Turbojet
Wrong. TurboFAN, just a lower bypass one.
aeroweanie
Tue Nov 15, 2005 8:43 am
Turbojet
No, the JT8D-200 on the MD80 is a moderate bypass ratio turbofan. The JT8D-7 or -9 used on a DC-9, 727 or 737-200 is a low bypass ratio turbofan. The -200 is a "refan" version of the original engine.
Quoting SlamClick (Reply 1):
Jet noise (as opposed to inlet noise) is caused largely by the shearing of the high speed air coming out of the engine and the outside air. As you lower the speed of the air coming out of the engine, you lower the noise produced.
Turbojets accelerate a little air a lot to produce thrust. Low bypass ratio engines accelerate more air by a a lesser amount to produce the same thrust. High bypass ratio engines accelerate a lot of air by even less to produce the same thrust.
N766UA
Tue Nov 15, 2005 9:41 am
Because it's freakin' awesome that's why!  silly  I love when the Mad Dogs, DC-9s, 727s, and 732s depart!
This Website Censors Me
CRJonBeez
Tue Nov 15, 2005 12:29 pm
can't get enough of those lower bypass ratio fans! another personal favorite, though still ridiculously loud for being current, is the JT15D5's found on the beechjet...from the front of that engine comes a shrill like you wouldn't believe!
ac21365
Tue Nov 15, 2005 12:59 pm
Yall sure know how to flame someone  thumbsup
Tue Nov 15, 2005 5:42 pm
The JT8D is a low Bypass Turbofan with approx Bypass ratio of 1:1.
The CFM56 is a high Bypass Turbofan,with a Bypass ratio of 5:1.
Turbojet
Quoting Access-Air (Reply 3):
The JT8D is a Low bypass Turbofan.
Any Link/Details on this Diameter Increase.
regds
MEL
NKP S2
Tue Nov 15, 2005 10:46 pm
Quoting AC21365 (Reply 9):
Well this isn't the civil av forum. If you make a declarative statement, you'd better know of which you speak. Call it "know-it-all burn-out".
If you don't know....feel free to ask questions ( after using the search function of course Wink )
[Edited 2005-11-15 14:59:20]
Sinlock
Tue Nov 15, 2005 11:56 pm
Quoting HAWK21M (Reply 10):
The JT8D-200 series found on the MD-80 has a bypass ratio od 1.74 to 1 The other "older" JT8D modals have a bypass ratio of .96 to 1.
Okie
Wed Nov 16, 2005 12:14 am
Quoting AeroWeanie (Reply 6):
Just add a little more here, it takes less energy to accelerate more air at less velocity hence, the core (the largest noise producer) can be smaller to produce an equal amount of thrust.
Okie
sovietjet
Wed Nov 16, 2005 5:33 am
JT8Ds are pretty decently loud. But you should go hear some NK-8, NK-86 and D-30 Series 3s to experience some raw power and sound.
lightsaber
Crew
Wed Nov 16, 2005 12:28 pm
Did anyone think I wouldn't answer this?
Yes, it is due to the moderate bypass ratio. Also, the nacelle isn't that great a damper on the JT8D-200's. (Note, there is a kit to improve that, but it adds weight for the sound absorbing material.)
As to the physics. Specific noise energy is produced to the 7th to 8th power of the velocity of the exhaust gas. Yes, its very non-linear! That is why high bypass engines are so much quieter than low bypass engines. This is also why mixing the turbine stream gas with the fan gas helps. The turbine gas might exhaust to the same pressure as the fan gas which means they'll be at the same mach number. But... Since the turbine gas is hotter, it will be going faster. (The speed of sound goes as the square root of temperature.) Faster=noisier This is why some nacelles are "mixing nacelles." Its purely to minimize noise. (e.g., some Trents, V2500, etc.)
Quoting Okie (Reply 13):
True! And I was trying to point out, the core exhaust (turbine exhaust) is faster and hence noisier than the fan air.
Lightsaber
Wed Nov 16, 2005 6:15 pm
Quoting Sinlock (Reply 12):
Agreed.I guess I was thinking of the JT8Ds -1 to 17Rs,You are correct on the -200.
regds
MEL
BR715-A1-30
Fri Nov 18, 2005 2:49 am
The JT8D-1 through 17 also have 2 Fan Stages as opposed to 1 fan stage on the JT8D-209 through 219. (Which means that they have 2 fans instead of 1). I guess that is to accelerate more air.
A Little Trivia, but before the BR715-A1/C1-30 was selected for the 717, It was originally going to sport JT8D-218/219 engines.
Puhdiddle
NKP S2
Fri Nov 18, 2005 3:10 am
Quoting BR715-A1-30 (Reply 17):
I don't know about that. The earlier JT-8's ( at least the dash 7's through the 17 anyway ) did indeed have 2 fan stages. I remember well the challenge of "dressing" the C-2 fan blades though the IGV's and C1 blades, and we used to R&R C-1 and C-2 discs regularly ( engine on wing / tail pylon ).
It's been about 5 years since I've worked on one. They could break your balls sometimes but they were/are good engines. I'm sure the 717/MD-90 would've been a good performer with the "big block" JT-8's but really, the design has long since reached it's developmental apogee that even my own nostalgia can't ignore.
[Edited 2005-11-17 19:11:26]
Fri Nov 18, 2005 2:51 pm
Why wasn't a JT8D upgrade to replace those on the B732s ever suggested,considering the Fuel burn.
regds
MEL
Pyrex
Fri Nov 18, 2005 9:46 pm
Not exactly. The lower the by-pass ratio the higher the optimum fan pressure ratio, so on the earlier ones a 2-stage fan was necessary. With the increase in by-pass ratio the fan doesn't need such a high pressure-ratio, so you can do it with just one stage.
Plus, I imagine newer technology on the -200 version allows for a higher fan pressure ratio per stage.
Read this very carefully, I shall write this only once!
Oryx
Fri Nov 18, 2005 10:54 pm
Speaking of rockets....
The Aerion super sonic business jet will (if ever build) be powered by Pratt & Whitney JT8D-219 (Flight International, 19 Oct 2004).
Does anybody have an idea why there is no more modern design for a Mach 1.4-1.6 civil turbofan?
KALB
Sat Nov 19, 2005 2:08 am
Ya want noise? Listen to non-hush kitted RR Speys on BAC 111! Now, those babies can scream.
lapa_saab340
Sat Nov 19, 2005 2:26 am
Indeed. I remember when the MD-80s came out, I thought they were incredibly quiet in comparison to the likes of the 1-11. The crackling sound of the exhaust felt like combustion in that engine was really a string of explosions. An early morning 1-11 flight that would climb out over my house every day was one of the most effective alarm clocks I ever had... Big grin
I only wish I could have heard a Trident...
TheSonntag
Sat Nov 19, 2005 3:39 am
Quoting Oryx (Reply 21):
I guess the answer is that supersonic airplanes must be relatively low-bypass turbofans, as the core thrust is important at supersonic speeds. Thats the reason why military airplanes and Concorde were so loud, they cannot have a high bypass ratio as this would make it impossible to go up to high supersonic speeds (don't ask me why exactly).
As conventional engines are designed for subsonic speeds (so it is tried to get higher bypass ratios), they are not suited for supersonic speeds.
The JT8D, on the other hand, meets the existing noise criterias (it isn't great, but it is legal), and its bypass ratio is low enough for supersonic speeds, I guess...
Pyrex
Sat Nov 19, 2005 5:30 am
I did my final thesis at University on the design of an engine for a supersonic business jet and in the introduction I mention all the factors behind that (economic analysis, etc.). If you want a copy just e-mail me.
stirling
Sat Nov 26, 2005 1:45 am
Quoting N766UA (Reply 7):
Could not said it better myself.
Quoting CRJonBeez (Reply 8):
It makes me sad they closed the staging area at SFO, at the end of runway 1R...great place to get behind a departing MD-Something...
I suppose re-engining older MDs with the BR715 has already been explored and deemed not cost-effective?
Quoting KALB (Reply 22):
Is there anyplace in the world they are still flying?
Living on the West Coast much of my life...the 1-11 was hard to catch...and when Pacific Express operated them in the early 1980s, I was living in Texas; missing them, Again! Doh!
Delete this User
717-200
Sat Nov 26, 2005 5:40 am
I love seeing and hearing especially the 737-200 Combis of AS taking off
out of SEA when I am out on the South Satellite ramp. Which subseries
of the JT8D does Alaska use on their -200's?
72S 733 734 735 73G 738 742 752 763 E190 M82 M83
Sat Nov 26, 2005 9:44 pm
Whats the Restrictions on JT8Ds Worldwide Hushkitted or Not.Which cities have banned the B732s.
regds
MEL
TheSonntag
Sat Nov 26, 2005 9:55 pm
Quoting HAWK21M (Reply 28):
It depends on the actual noise levels. In Europe, Stage 2 airplanes are banned completely, except for humanitarian or military flights. That's why the 727 was phased out early, as well as other louder airplanes.
The 737-200 is Stage 2, so it is not allowed anymore. Hush-Kitting is not allowed as far as I know, only airplanes that are already hush-kitted are allowed to remain flying in Europe.
That's why there are no hush-kitted planes from the US coming to Europe, there was a trade dispute between the US and Europe around this issue, as well if I remember correct, as this act understandably reduced the value of the existing fleets of 737s and 727s.
The Ryanair 732s are allowed to stay, because they were flying before hush kitting was prohibited, therefore this rule does not apply to them.
Why was hush-kitting prohibited? The problem was, it was only reducing the noise marginally, therefore these airplanes remained the loudest legal airplanes flying. As this was not wanted, this ban was imposed.
Sat Nov 26, 2005 10:08 pm
Quoting TheSonntag (Reply 29):
Its true On Grd.The Hushkitted & non Hushkitted Engines sound the same  Smile
regds
MEL
Users browsing this forum: Baidu [Spider], BravoOne, DaBuzzard, Starlionblue and 2 guests
