Fly2HMO
Fuel Selectors: Why No Both Position On Low Wings?
Sun Nov 20, 2005 6:35 am
It just came to my attention that Cirrus and Lanciar don't have a both position for the fuel selectors. Why is this? I'd figure it would be pretty annoying to switch from left and right several times.
Thx  Smile
Alias1024
RE: Fuel Selectors: Why No Both Position On Low Wings?
Sun Nov 20, 2005 7:37 am
Low wing aircraft like the ones you described never have a both position because they would violate FAR 23.951.
FAR 23.951 basically says that no fuel pump can draw from more than one tank at a time, and provisions must be made to prevent air from being drawn into the fuel supply line.
In a low wing aircraft if one fuel tank ran out, the pump would suck air from an empty tank instead of fuel from the full tank.
A high wing aircraft like the C-172 can have a both position because they use gravity to feed a reservoir, and then the fuel pumps are downstream of the reservoir. If fuel runs out in one tank, fuel from the other tank still goes to the reservoir, preventing air from getting into the fuel line. Since low wing aircraft cannot use gravity to feed a reservoir, they cannot have a both position.
I hope this helps answer your question.
Mir
Sun Nov 20, 2005 2:14 pm
Quoting FLY2HMO (Thread starter):
You would figure correctly.  Smile
And not only that, but plenty have planes have done unnecessary forced landings because the engine stopped due to one tank being exhausted and the pilot forgetting that there was another tankload of fuel waiting to be used.
At UND, the fleet is all Pipers (low-wing). Rumor has it that the first thing ATC says after you declare an engine failure emergency is "Have you switched tanks?"
-Mir
Fly2HMO
Sun Nov 20, 2005 5:02 pm
Duh, I never thought of that.  dopey
Must be easy to feoget for people that are used to high wings and transition to low wings. I hope I never forget.  duck
erj-145mech
Mon Nov 21, 2005 12:30 am
Quoting Alias1024 (Reply 1):
Skyhawks don't have reservoirs or fuel pumps, everything else is correct. You won't get into a header or reservoir tank until the 205/206/210 series airplanes.
Alias1024
Mon Nov 21, 2005 6:41 am
Quoting Erj-145mech (Reply 4):
I should have been more specific. I am referring to the newer fuel injected models like the 172S. My PIM shows a reservoir along with 2 fuel pumps. I don't know if older 172's with carburetors need the fuel pumps or not.
[Edited 2005-11-20 22:45:00]
Stoicescu
Mon Nov 21, 2005 8:54 am
The Piper Warrior II I fly has only L/R and Off positions. Start on the fullest tank and check it from time to time. A nice way to do it is USE the clock. Say the time says x:xx I will stay on L until the minutes show y:yy check it and if applicable switch. Hey at least you don't have to worry about hitting the flaps with your head all the time  Smile
Quoting Mir (Reply 2):
it won't help at all... it probably sucked enough air to make it unusable
Mir
Mon Nov 21, 2005 9:35 am
Quoting Stoicescu (Reply 6):
Apparently not, because reportedly it fixes the problem most of the time.
-Mir
ShyFlyer
Mon Nov 21, 2005 9:46 am
In the TBM700, the fuel selector switches between the left and right tanks automatically.
ajd1992
Tue Feb 19, 2008 4:52 pm
You're right, it is annoying.
Even more so, because i'm really anal about having uneven tanks  Silly Thanks for explaining why low wing aircraft can't have a dual setting - I've always wondered why.
askr
Sat Mar 15, 2008 10:06 pm
My first post on a-net, so please don't bite  Smile
Couldnt it be possible to place a pump bellow the lowest tank?
Obviously, there woldn't be much space left for a reserviour, but could just the plumbing, with non-return valves just under the tanks be enough to keep the pump fed?
ATC-PL Wanabe :) - 2nd application is in... 11 July...
Mir
Sat Mar 15, 2008 11:40 pm
Quoting Askr (Reply 10):
I imagine it would, but then you'd have to have at least three fuel pumps in the plane (one for each tank to feed the reservoir and another to feed the engine - add another if you want a backup). That's just more things that can fail on you, as well as more weight and complexity. It isn't worth it - just remember to switch tanks every so often.
-Mir
BE77
Wed Apr 02, 2008 2:59 pm
BE77 Skippers (circa 1979-1981) are low wing, with an electric fual pump under the engine (just behind the nose wheel), and the tank options are simple...OFF and BOTH. There is no L or R option. Tanks cross feed themselves...when on a solo X-C you have to be sure to load as much of the baggage / misc stuff in the plane to the far right to counterbalance the pilot weight to keep things level (not really noticeable in flight - but the little offset is enough that by landing you have all the remaining fuel in the left tank!)
Tower, Affirmitive, gear is down and welded
Users browsing this forum: boeing767322er, Raventech and 20 guests
