BR715-A1-30
How Do You Start 737 Engine?
Sun Nov 20, 2005 10:35 am
I was reading Gordon Bethune's book, and he was talking about how Boeing engineers suggested a new start control panel with 2 switches for the 737NG instead of the current 8-switch model.
So my questions is. What 8 switches do you have to press, and how do you start a 737 engine from step 1 to whenever...
Puhdiddle
RE: How Do You Start 737 Engine?
Sun Nov 20, 2005 5:28 pm
Quoting BR715-A1-30 (Thread starter):
What 8 switches.Are you talking of the Wafer assy behind the Switch.
regds
MEL
brownbat
Sun Nov 20, 2005 7:56 pm
Position the engine start switch to "GRD" and at 20/25% N2 RPM position the engine start lever to idle, those things below the thrust levers. That's it.
mandala499
Sun Nov 20, 2005 10:50 pm
Don't forget you need bleed pressure...  Smile Switch the APU on first and set the bleed feed  Smile
BR715-A1-30
Sun Nov 20, 2005 10:59 pm
I dunno, there was a mention in 'From Worst to First' about a current 8 switch model.
Puhdiddle
SlamClick
Sun Nov 20, 2005 11:45 pm
Maybe he is referring to the whole startup from cold, dark, quiet airplane to ready-to-fly, including starting the APU. In that case if it can be done with only eight switches that is not bad.
Mon Nov 21, 2005 12:01 am
LINK
regds
MEL
miamiair
Mon Nov 21, 2005 12:17 am
Battery power for the fuel pump, Crank the APU, bring it online, provide bleed air, select ignition switch, start valve, fuel on at appropriate N2, monitor EGT, FF, OP.
BR715-A1-30
Mon Nov 21, 2005 1:02 am
HAWK21M, Thanx for the link... Very interesting reading material
Puhdiddle
Mon Dec 18, 2006 1:16 pm
Quoting BR715-A1-30 (Reply 8):
Now the print version is available too.
regds
MEL
nonfirm
Mon Dec 18, 2006 7:20 pm
Good link MEL.Thanks  airplane
N231YE
Tue Dec 19, 2006 2:29 am
Quoting HAWK21M (Reply 6):
Thanks for the link...
